eBay: Super duper Sega Master System package--AV mod, Everdrive, more
jasonbar
https://www.ebay.com/itm/164954006156
Lot: Sega Master System-SCART RGB + Mod for S-Video/Composite/"Stereo" + Everdrive Flash Cart
3D Glasses + Spare, 2 Control Pads, Light Phaser, All Cables-ALL TESTED GOOD
This listing is for a very special SMS system console setup. small mountain of Medical School & Step Test & Match books.
SEGA MASTER SYSTEM/POWER BASE. FIRST GENERATION. US MODEL
Clean, minor scratches.
Very tidy & slick mod to output SCART RGB, or S-Video, or Composite. All 3 outputs tested working. S-Video has some bleeding, but Composite & RGB look *fantastic*. Also "stereo" output jacks (the SMS puts out mono, so I believe that this mod duplicates the mono sound to both the left & right channels).
RF Out jack not tested.
MASTER EVERDRIVE FLASH CART
Works great. Set up with OS rev 5, firmware rev 1.
Can hold the entire Master System library & SG-1000 library on a modest SD Card.
Housed properly in a cartridge shell, with a classic-style label.
This alone costs $129-$152 new online! (see Amazon, Stone Age Gamer, or EverDrive.me).
SANDISK 1.0GB SD CARD
Works with Everdrive.
More than enough to hold the entire system library, & then some.
Formatted correctly to work w/ Everdrive.
3-D GLASSES SET
a) 3-D Adpater. Plugs into Card Input slot, glasses plug into it. Clean, works great.
b) Sega 3-D Glasses. Good condition. Work great. Right temple had broken about 3/4 of the way towards the temple tip. I repaired this by sandwiching taped-on plastic splints to both sides of the earpiece & securing it all with heat shrink tube to keep the splints in place, to provide a comfortably smooth surface, & to blend the colors. It's all good.
c) New Shutter Glasses. Simple modern unit purchased a few years ago & used just a few times. Use these if you want to preserve your original Sega brand glasses!
LIGHT PHASER LIGHT GUN
Very good condition
Works swell!
2 CONTROL PAD CONTROLLERS
Very good condition.
All functions tested good: up, down, left, right, all 4 diagonals, both buttons.
AC ADAPTER POWER SUPPLY
Sega Model 3025.
"Plug-in power supply for use with power base".
In: 120V 60Hz, Out: 9VDC 1A, 15W, tip negative.
Original power supply, no hum, no issues.
RGB SCART + AUDIO CABLE
Professional quality cable, purchased from a cable shop.
Provides exquisite video & audio for your RGB gaming monitor!
S-VIDEO + AUDIO CABLE
Provides good video (some images have right-facing shadows) & audio for your RGB gaming monitor!
COMPOSITE + AUDIO CABLE
Provides very nice video & audio for your standard TV!
Thank you,
-Jason
Edited by jasonbar
Every console has AV out of some sort. Mods provide other AV out options. I prefer to up my consoles to RGB when possible. I think I bought this one with the composite & S-Video mods already executed, perhaps before I got my RGB monitor(?)
Thanks,
-Jason
