atarilux Posted July 13, 2021 Share Posted July 13, 2021 Hello, I have been playing around mainly with FastBasic and some limited assembler (mainly WUSDN tutorials). I have had some success playing with display lists, so excuse the perhaps silly question. So far all the demos I've seen only use the display list to change the background colour, and not any of the foreground colors (to increase the overall number of screen colours). The only way I can see to get potentially may colours "on screen" is to use page flipping, or have I misunderstood how display lists (interrupts) work? I am mainly using Antic Mode 4 with character set mods to achieve the results on screen. Ideally, having more colours via changing what is available on a (character) line by line basis. The machine being used is a stock 800XL, so no fancy mods! All other aspects seem quite straight forward e.g. sprites. So thanks to the many excellent pages online including Atariprojects etc. A (for now) still a newbie 1 Quote Link to comment Share on other sites More sharing options...
popmilo Posted July 13, 2021 Share Posted July 13, 2021 Interrupts just run piece of code that can do many different things. Nothing is stopping you from changing any of color registers. You can change colpf0-3, colbk, pm 0-3 colors, player xpositions, character set chbase etc... Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted July 13, 2021 Share Posted July 13, 2021 You can even have a DLI that runs different code depending on which line your on, the only limit of DLI's is they have to be very short otherwise you get undesired effects on screen. Quote Link to comment Share on other sites More sharing options...
zzip Posted July 13, 2021 Share Posted July 13, 2021 1 hour ago, atarilux said: Hello, I have been playing around mainly with FastBasic and some limited assembler (mainly WUSDN tutorials). I have had some success playing with display lists, so excuse the perhaps silly question. So far all the demos I've seen only use the display list to change the background colour, and not any of the foreground colors (to increase the overall number of screen colours). The only way I can see to get potentially may colours "on screen" is to use page flipping, or have I misunderstood how display lists (interrupts) work? I am mainly using Antic Mode 4 with character set mods to achieve the results on screen. Ideally, having more colours via changing what is available on a (character) line by line basis. The machine being used is a stock 800XL, so no fancy mods! All other aspects seem quite straight forward e.g. sprites. So thanks to the many excellent pages online including Atariprojects etc. A (for now) still a newbie You can change any or all of the color registers in a DLI, this is the most common technique to increase the on-screen colors You could also do stuff like change the horizontal position of a Player sprite in a DLI, which effectively can create two sprites with different positions on the top and bottom of the screen Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted July 13, 2021 Share Posted July 13, 2021 Have a look at this, was just something I wrote to see how many players I could get on screen at one time let it run for a bit and you can see they separate, change colour and position. I used a VBI to calculate the the player positions, then used a multi-dli to position the sprites and change the colours. PLAYER.XEX 2 Quote Link to comment Share on other sites More sharing options...
Preppie Posted July 17, 2021 Share Posted July 17, 2021 If your using FastBasic you can use the DLI command to setup display list interupts instead of writing your own assembly routines. Also, there's a great DLI tutorial here https://playermissile.com/dli_tutorial/ Quote Link to comment Share on other sites More sharing options...
atarilux Posted July 21, 2021 Author Share Posted July 21, 2021 On 7/13/2021 at 3:38 PM, TGB1718 said: Have a look at this, was just something I wrote to see how many players I could get on screen at one time let it run for a bit and you can see they separate, change colour and position. I used a VBI to calculate the the player positions, then used a multi-dli to position the sprites and change the colours. PLAYER.XEX 1.82 kB · 20 downloads Thanks for this demo. It is impressive to see so many players with so much color. Also, the frame rate remains high. I shall have to figure out how to do similar things myself. Quote Link to comment Share on other sites More sharing options...
