+Propane13 Posted March 1, 2002 Share Posted March 1, 2002 Hi there, Was browsing through some legacy 6502 code, and came across this block: LE4F9: LDA $81 LDY #$12 CMP #$1F BMI LE50B CMP #$18 BMI LE50B CMP #$27 BPL LE50B LDY #$11 ;2 LE50B: JMP $F026 ;3 Now, the code obviously sets Y to $11 or $12, and then jumps to address $F026. The question, though, has to do with the input $81. Am I mistaken, or is there dead code in here (basically, one of the compares will always render that condition true or false based on a previous comparison's result)? Am I looking at this too late, or am I correct in this assumption? Input would be appreciated Thank you, -John K. Harvey Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted March 1, 2002 Share Posted March 1, 2002 maybe i just woke up... but as far as i can see... depending on $81 you will have $11 or $12 in Y-register...then the code jumps to $f026 so i don't see a "dead code" here... it would be more interesting what is happening after $f026 and what is stored in $81??? Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted March 1, 2002 Share Posted March 1, 2002 if you have $81 => $80 then you will get in Y=$12 otherwise $11 (and not being catched by one of the CMPs) Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 2, 2002 Share Posted March 2, 2002 I agree...this part of the code reveals too little to make any conclusions. The obvious things are that the Y register is held at a value equal to #$12 if one of the following three comparisons happens to be true...at which point the program branches to the JMP. You might be asking yourself "why not just place JMPs where the BMI's are?". First off, each branch acts as an IF-THEN statement...testing the value held at $81 (which is now in the accumulator) to see if it falls within acceptable parameters. CMP will NOT change the value held in the accumulator...so all the comparisons are checking the original value fetched from $81. Secondly, it's easier to change the JMP memory location when it only appears in the code at one spot. If none of the tests are positive, the value of Y changes to #$11 before the JMP is made. The LDA $81 is definately not "dead code", as all of the following tests and the jump itself depend on the value held there to decide on what to do next. [ 03-02-2002: Message edited by: Nukey Shay ] Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 2, 2002 Share Posted March 2, 2002 By the way, an easy way to see what the branches accomplish is to edit all of them. In this code, there is two ways to do this... Each BMI statement uses 2 bytes, so just EA EA over all three of them and run it to see what changed when the tests always come up negative. Here's the edited code : LE4F9: LDA $81 LDY #$12 CMP #$1F NOP NOP CMP #$18 NOP NOP CMP #$27 NOP NOP LDY #$11 ;2 LE50B: JMP $F026 ;3 (NOP is like REM in Basic...it does nothing at all). The second way is to stick your own value in for Y...like this : LE4F9: LDA $81 LDY #$11 CMP #$1F BMI LE50B CMP #$18 BMI LE50B CMP #$27 BPL LE50B LDY #$11 ;2 LE50B: JMP $F026 ;3 ...or this : LE4F9: LDA $81 LDY #$12 CMP #$1F BMI LE50B CMP #$18 BMI LE50B CMP #$27 BPL LE50B LDY #$12 ;2 LE50B: JMP $F026 ;3 ...try both and see what happens. By far, the best method of hacking games to discover what each routine does is to look for a jump table. These usually show up as a number of JSR's in succession, and appear like this : JSR $E02B JSR $8450 JSR $846E JSR $A0DF JSR $B99C To find out what each routine does, just put NOP's over one of them to see what changes when it is run...like this: JSR $E02B NOP NOP NOP JSR $846E JSR $A0DF JSR $B99C (this one is checking what the instructions at $8450 do...each JSR instruction uses three bytes, so you will need to use three NOP's.) If it is something crucial to the game's engine...you may find that it won't run at all. If it is something exotic (like checking your inventory for a particular object, for example)...you may not notice a difference until you try to use that object. Editing jump tables can mean the difference between tracing reams of data to just a page or two. Just don't forget to write down the original values (or save a backup file). [ 03-02-2002: Message edited by: Nukey Shay ] Quote Link to comment Share on other sites More sharing options...
+Propane13 Posted March 4, 2002 Author Share Posted March 4, 2002 Hello, I see I may have confused some people. By "Dead code", I was referring to a condition check that will always be true or false, and therefore is a useless check on its own. For example (per pseudocode): Input X If X < 5 Then GOTO Endline If X < 3 Then GOTO Endline Endline: Obviously, the second conditional check is useless in this situation, since any number less than 3 is inherently less than 5. So, does this happen in this snippet of code? -John K. Harvey Quote Link to comment Share on other sites More sharing options...
calamari Posted March 5, 2002 Share Posted March 5, 2002 Maybe, then again maybe not.. look for an instruction that might jump to that 2nd test. calamari Quote Link to comment Share on other sites More sharing options...
