Timmy Two-Step Posted July 18, 2021 Share Posted July 18, 2021 Hi all...... I recently did a composite mod on a 1977 Coleco Telstar ALPHA which was very simply to do as it uses the same chip as most of these other Pong and pong clones from the time....(looks amazing) My problem is that my reset button is broken -- seems to be in this half pressed down mode all of the time -- I need to replace it. I'm sure they don't sell an exact replacement for it anymore, but what kind of reset button / switch am I looking for? Is there a certain name to describe the type of button / switch it is? As far as I can tell, when you push the reset button, it temporarily bridges two points on the PCB sending the reset signal back to the main chip..... any ideas? Suggestions? Links to what I need? Thanks!! Quote Link to comment Share on other sites More sharing options...
Voxel Posted August 9, 2021 Share Posted August 9, 2021 You need a "momentary push switch". You want something like: https://www.ebay.com/itm/114618635604?_trkparms=ispr%3D1&hash=item1aafcd9554:g:V7oAAOSwp29f92JE&amdata=enc%3AAQAGAAACkPYe5NmHp%252B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSR84A%252FGMxXIqJzFmDq6lDLl7JVoP%252BnicsNeLAFK4z0l%252BWNGivef9pi%252FzdLtjo5MKd0MAI939lRxl9doVZeXErlSKOH9GNfIPq0HfTa8sXa4XHHeXcLEwbevUtIkbqyp1oQv8oOgmb5lbrcIEbqGKwrYzT8VVMZcrFizHVhFVzHAYf9FYNX%252BblaGNWI3v8W%252FO2wjBKFNnEhitQpeH%252FMtqn3QVBTKiG7ItsUsGCljDjJ%252BBGhZVbB4H5rw06UUngkrpD8x9VE%252FDeQZzHXPRBK3RLxPtP8oc5IQiNLzwn%252F2cDXM87iTshBQLe7KW1YIGTfpuK%252FtR28tNRJVILsr6LvkiwgifFXJR5BuRWwxtuVJT%252B0dkvPr%252B5CQZmVvmVyD0LrdoY5V5GgBrxA6OXXaaDGgXXdmTADTJgL5gLtXCOINLinuj1ruJ6ruV25A3FlDhbilk3b4N4IamKkDmA6AdCWEgNqW6iqcMNaI8HetRJZASSNEs2bQpUfnFIG8dasjeAQ4hJo3cbLzeVKeXHc4MQ62ggCPj0yQuGOckELZsWzjsaLE040nzBYcIVV7J%252F5mYOpq6gazSNDzgn8tvDfdooHniSxMIq3l3exp3vFZAV9P2p7op4lTvsPwWc8z7O1osWWy6p8g2nHctpc4QiuirX2bGp0Mg6V73oEvzxam7sYbUmymEgXtBi2GqzGAPnl3tS2HaK%252BILk%252FLSif36ot7MJE35ILF%252BaW8Mv6k4PNnfxcpZuRzso9qOfrP5BbX9OdU0aAGijqMttlgz0DwrjVyZmmES74WT1XorMOFRToZV3Z4ZI9sSiU7bN0yjgKDwJGeNGB8Z3%7Campid%3APL_CLK%7Cclp%3A2334524 Quote Link to comment Share on other sites More sharing options...
