Mik's Arcade Posted July 20, 2021 Share Posted July 20, 2021 (edited) Hi - I made several edits to games while on the Emulationstation menu itself. I always use the "save on exit" option when I am editing my lists (and uncheck it when I am not so it wont always update the times played and reload every boot). Typically, I will edit a few games and then restart Emulationstation so as to make sure the changes get saved to file. However, I edited several games and called up another game to test it but it froze on the screen. It just froze. I could not get it to exit back to the emulationstation. After waiting a few minutes, I finally had to just power down Raspberri Pi. Unfortunately this will not trigger the 'save on exit' option so I lose my edits. This happens on occasion and it's is annoying to lose progress. So, two questions: (1) When this happens, it there any other way to kill the process when CTRL-C and all the other keyboard and control button presses don't work? Is there any way I can connect to the machine from the laptop and issue a command to kill the process? I was going to try to delete the ZIP file that crashed or try to at least end the mame2010 process trying to run it. I was trying to connect to my Pi (using the IP address) from my laptop and on some nights for some reason it won't connect...it's really annoying. I connect directly to my Pi when I want to make bulk edits to any GAMELIST.XML or edit any configuration files (EMULATORS.CFG) or copy new images over, so I can get around using my laptop when it wants to work. (2) By any chance, is this updated text dumped into a file anywhere on the system before they get saved to the GAMELIST.XML, or are these changes just kept in memory and lost when you power down ? thanks Edited July 20, 2021 by Mik's Arcade Quote Link to comment Share on other sites More sharing options...
Mik's Arcade Posted July 20, 2021 Author Share Posted July 20, 2021 Anyone? Bueller? Bueller? Bueller? I'll poke around the folder in a bit later and see if I can find a text dump of the changes I made......otherwise, I'll just have to make them again....oh well. Small problem to have when I have such a robust library of arcade coin-ops. I really love the golden age of the arcades. So many awesome, simple games. Quote Link to comment Share on other sites More sharing options...
John Stamos Mullet Posted August 23, 2021 Share Posted August 23, 2021 On 7/20/2021 at 5:18 PM, Mik's Arcade said: Anyone? Bueller? Bueller? Bueller? I'll poke around the folder in a bit later and see if I can find a text dump of the changes I made......otherwise, I'll just have to make them again....oh well. Small problem to have when I have such a robust library of arcade coin-ops. I really love the golden age of the arcades. So many awesome, simple games. There's no way to recover those lost changes, and this will happen if you try to make a lot of changes (10 or more at a time). honestly the best thing you can do is use an offline editor like EsGme. https://www.jeffersoftware.com/esgme/index.php Also keep your gamelist relatively short. If you have thousands of ROMs, editing it in Emulation Station will always be a problem. I keep mine limited to only games I actually play and like, so it's only about 120-150 classic era golden age arcade games only. Quote Link to comment Share on other sites More sharing options...
Mik's Arcade Posted August 23, 2021 Author Share Posted August 23, 2021 (edited) 10 hours ago, John Stamos Mullet said: There's no way to recover those lost changes, and this will happen if you try to make a lot of changes (10 or more at a time). honestly the best thing you can do is use an offline editor like EsGme. https://www.jeffersoftware.com/esgme/index.php Also keep your gamelist relatively short. If you have thousands of ROMs, editing it in Emulation Station will always be a problem. I keep mine limited to only games I actually play and like, so it's only about 120-150 classic era golden age arcade games only. yeah, it's a bummer, but I have moved on and re-entered the changes. I've got about 1600 arcade games in my XML file. I keep the list in sort order and I only experience slowdown if I literally try to just keep scrolling through the entire list. I keep the descriptions down to just a few lines per game and don't add videos to bog it down. I had a bigger scare the other day when the Pi didn't boot at all. We had a massive storm and I was terrified a power surge fried the board. But, after some testing it was only the power cord itself. I had a spare and it worked fine....whew Edited August 23, 2021 by Mik's Arcade Quote Link to comment Share on other sites More sharing options...
