Synthpopalooza Posted August 2, 2021 Share Posted August 2, 2021 OK, so I decided to try an experiment: 16-bit C distortion using mod 5 frequencies. These will either produce a 33% duty cycle wave, or silence. The 16-bit notes are playing on first two channels, with first channel silent, second one playing Distortion C @1.79 mhz clocked from first. I tried a poly reset code (RESETPOLY routine in the .s file) to reset the polycounter before each note play, but I think it's not working, as the bass notes will still occasionally drop out. Any ideas how I can improve the code to get a solid note each time? pacland-homeward2.asm pacland-homeward2.s pacland-homeward2.xex 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 2, 2021 Share Posted August 2, 2021 Is your delay sufficient when doing the SKCTL = 00 then 03 ? And when setting that low AUDF value, the delay should be considered to start at that point shouldn't it ? And how are you getting the desired/stable type C notes - are you doing the trick to ensure the cycle alignment is right or doing the Pokey Init each time ? Can't say I've really played with this stuff much at all and not for some time either. 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 2, 2021 Author Share Posted August 2, 2021 My routine to reset the polycounter takes 18 cycles. It may need more because of 16 bit mode. I am using mod 5 tones here instead of the 3's so I can more easily hear the instability. In this case you get either 33% duty cycle, or silence. 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 2, 2021 Author Share Posted August 2, 2021 (edited) My idea was to be able to select three tones at will in 16-bit C distortion. Using standard 8-bit, there are three tones available in mod 3. Using channel 3 gets you the 20% duty cycle every time. But in 16-bit mode, you only get 2nd or 4th channels. So my idea was mod 3's to get the 01100 and 01011 patterns, and mod 5 to get the 010 pattern which is fairly close in timbre to 01000. If I can get this to be reliable every time, the rest should fall into place. Edited August 2, 2021 by Synthpopalooza 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 3, 2021 Author Share Posted August 3, 2021 So I made a few changes. It's 95% there, but a couple of notes still get dropped. I added in a couple of calls to the poly reset routine RESETTIMER, and played with the frequency settings in the routine. RESETTIMER lda #0 sta SKCTL lda #5 sta AUDF0 nop nop sta STIMER lda #3 sta SKCTL rts Changing the AUDF0 value seems to shift which sections have dropouts. Anybody have any other ideas on this? pacland-homeward2.asm pacland-homeward2.s pacland-homeward2.xex 3 Quote Link to comment Share on other sites More sharing options...
