+Random Terrain Posted August 9, 2021 Share Posted August 9, 2021 DPC+ 176 rows and DPC+ 88 rows will not display properly in Stella or a real Atari 2600 without tricks developed by Lillapojkenpåön here at AtariAge. Problem is that a DPC+ driver update made a change that caused the tricks to stop working using Stella 6.0 through 6.5.3 AND the Harmony cart. Thanks to SpiceWare, if you put the following file in your bB includes folder, the tricks will work again using the latest version of Stella and the Harmony cart: DPCplus.arm After you put that file in your batari Basic includes folder, any programs that you compile from now on that use the tricks for DPC+ 176 rows and DPC+ 88 rows will look like they're supposed to. [Behind-the-scenes info: In a PM, Rogerpoco tested two programs that were compiled using the updated driver. Photos show that the tricks work on a real Atari 2600 using a Harmony cart.] Speaking of the tricks, the trick for 176 rows looks like this: ;*************************************************************** ; ; Simple fix for the top and bottom rows (only for 176 rows). ; asm lda DF6FRACDATA lda DF4FRACDATA lda DF0FRACDATA lda DF1FRACDATA lda DF2FRACDATA lda DF3FRACDATA end The trick for 88 rows looks like this: ;*************************************************************** ; ; Simple fix for top two lines of 88 rows having same color. ; asm lda DF6FRACDATA lda DF4FRACDATA end Below are two test example programs with quickly scribbled pixels and colors that show the tricks in action. DPC+ 88 rows .bas file: test_bb_dpc_88_rows_driver_update.bas DPC+ 88 rows .bin file for use with Stella emulator or Harmony cart: test_bb_dpc_88_rows_driver_update.bin DPC+ 176 rows .bas file: test_bb_dpc_176_rows_driver_update.bas DPC+ 176 rows .bin file for use with Stella emulator or Harmony cart: test_bb_dpc_176_rows_driver_update.bin Quote Link to comment Share on other sites More sharing options...
