gorf68 Posted August 14, 2021 Share Posted August 14, 2021 (edited) So I'd just put the latest version of Circus Vectrex on to my VecFlash for testing on the Vectrex before burning it to eproms for the cartridges, turned it on and... Nothing, no picture, no sound, no buzz, no dot in the centre of the screen, no glow from the back of the tube. Nothing. Is it likely that this is just the on/off switch that's gone? Before it died it was taking a bit of time to show the screen after it was switched on, and the vectors had a lot of drift until it was left for a few minutes to 'heat up.' I'm wondering whether this is worth me taking a look at myself or if there is anyone who does Vectrex repairs in the UK? If it is the switch can I just short this out with a bit of wire? Unfortunately development of the 'Circus Vectrex' cartridge, and anything else, is pretty-much dead in the water without a working Vectrex! Any thoughts? Edited August 14, 2021 by gorf68 1 Quote Link to comment Share on other sites More sharing options...
+jgkspsx Posted August 15, 2021 Share Posted August 15, 2021 Did you take the VecFlash out? I think this has happened to me while using it occasionally… I have stopped using the volume switch to turn it on. I leave it on and plug it in and unplug it. Those switches just die too easy. Quote Link to comment Share on other sites More sharing options...
gorf68 Posted August 15, 2021 Author Share Posted August 15, 2021 Yes, tried it with nothing attached, no power whatsoever. I suppose I could see if any power is coming out of the transformer, then see if anything is coming through the switch. if it is the switch I can live with just bypassing it. If it's more complicated than that I may need to get someone else to look at it. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted August 16, 2021 Share Posted August 16, 2021 There is a fuse inline on the power inside by the transformer. It is worth looking that over. Also based on the other conditions were you describing, it sounds like your Vectrex was in need of new caps. Quote Link to comment Share on other sites More sharing options...
gorf68 Posted August 16, 2021 Author Share Posted August 16, 2021 Well I can handle a fuse or probably even the power switch myself. I can solder but replacing all the caps myself wouldn't by my first choice. I solder when I really, really, have to but I've never really wanted to... Just never liked soldering! Quote Link to comment Share on other sites More sharing options...
