TheGreatZubari Posted August 20, 2021 Share Posted August 20, 2021 Hello all, I just want to clear up some confusion. Where could i find the 1.06 eeprom PAL 60 bin? I think it doesn't exist at this point. I have the Harmony Encore, whether or not I flash it to PAL, the colors are still inconsistent and wrong at times. What is the LATEST and where could i find it? I found a beta 2.0 updater from Dec 2020 but it had 1.05 which doesn't work with every game(and the colors are still wrong) I have a PAL 2600(Heavy sixer) Regards and many thanks! Quote Link to comment Share on other sites More sharing options...
KnightNZ Posted August 22, 2021 Share Posted August 22, 2021 As far as I'm aware, there's no newer EEPROM Loader for any revision other than 1.04e, which is in the .ZIP with the 1.05 firmware package (from 2010!) I ended up using the NTSC ELoader with the PAL60 BIOS, was the only combination to make the menu appear correctly with my RGB modded 2600. As far as I can tell, the latest updater is here; The latest (unofficial) NTSC 1.07 firmware is here: And the latest 1.06 firmwares for NTSC and PAL are in the OP at the top of this forum; Good luck! Quote Link to comment Share on other sites More sharing options...
TheGreatZubari Posted August 22, 2021 Author Share Posted August 22, 2021 1 hour ago, KnightNZ said: As far as I'm aware, there's no newer EEPROM Loader for any revision other than 1.04e, which is in the .ZIP with the 1.05 firmware package (from 2010!) I ended up using the NTSC ELoader with the PAL60 BIOS, was the only combination to make the menu appear correctly with my RGB modded 2600. As far as I can tell, the latest updater is here; The latest (unofficial) NTSC 1.07 firmware is here: And the latest 1.06 firmwares for NTSC and PAL are in the OP at the top of this forum; Good luck! Thank you so much, this was very helpful. However, which specific hbios did you use? Quote Link to comment Share on other sites More sharing options...
