Joust for the CoCo 3
JamesD
Williams uses the 6809, so the game logic is largely intact as is.
However, the arcade game has custom hardware for a lot of stuff that has to be replaced with the CPU.
This includes a blitter, sound chips, and the graphics support more colors.
So the sounds are samples that are played through the DAC with a timed CPU interrupt, sprites are drawn with optimized 6809 code, graphics are adapted to the CoCo 3.
And on top of that, the arcade game had copy protection that had to be patched, and the change in screen aspect ratio had to be dealt with.
The author may have some discussion on his blog, and it was discussed on an episode of CoCoTalk!, though I haven't gotten to watch it yet.
He has a largely completed version of Defender as well, but he hadn't tracked down an issue in it.  From his comments it was the same copy protection so he should be able to finish that soon.
Trying to get this running on my COCOSDC, but I'm getting a blank screen.
I put the joust.dsk file on the SD, then DIR- to list, shows the file, then
DRIVE 0,"JOUST"
OK
LOAD "JOUST"
OK
but then EXEC gives me ?FC ERROR
So I try RUN, that goes to a black screen, then eventually a garbled pattern of blinking graphics?
DRIVE 0,"JOUST"
OK
LOAD "JOUST"
OK
Wait am I dumb? Do I need more than 128K RAM?
  • 3 weeks later...
