Tillek Posted August 27, 2021 Share Posted August 27, 2021 (Reposted as a new topic) I would like to announce the startup of a real Atari 8 Bit BBS , at telnet christfollowersbbs.ca at port 1985, my other BBS is still running on the same address at port 23, same name. I do have a ready setup set of atr files for Forem XE Pro 5.2 with the BBS initialized with sysop as the main user (only 1 user) , pw:0000 , phone number is 000-000-0000, so when you run everything , all you have to do is type in L for local login, and 0000 for password, then 0000 for phone number, that will get you in. I hope that you enjoy this setup, everything is untouched, you can either run it on Alterra , real hardware with or without Fujinet. Here are the files , each one 720 kb long and in Spartados 3.2d Forem XE Pro 5.4 Master Disk Updated With Docs.atr 719.64 kB · 0 downloads Forem XE Data Disk 1.atr 719.64 kB · 0 downloads Forem XE Data Disk 2.atr 719.64 kB · 0 downloads Forem XE Data Disk 3.atr 719.64 kB · 0 downloads Forem XE Data Disk 4.atr 719.64 kB · 0 downloads Forem XE Data Disk 5.atr 719.64 kB · 0 downloads Forem XE Data Disk 6.atr 719.64 kB · 0 downloads Forem XE Data Disk 7.atr 719.64 kB · 0 downloads There you go, all files are there and set up, all you have to do is configure Altera or run it on a really good set of Atari hardware. (Fujinet, APE, Atari Max?). 1 Link to comment Share on other sites More sharing options...
moonlight_mile Posted September 9, 2021 Share Posted September 9, 2021 I take it this bbs (port 1985) isn’t up? Link to comment Share on other sites More sharing options...
Tillek Posted September 9, 2021 Author Share Posted September 9, 2021 3 hours ago, moonlight_mile said: I take it this bbs (port 1985) isn’t up? I honestly haven't even tried calling it yet. I'll check tomorrow and let you know what I find (tonight is a release night at work). Link to comment Share on other sites More sharing options...
moonlight_mile Posted September 10, 2021 Share Posted September 10, 2021 I tried my last two bbsing sessions no answer. The port 23 bbs answers but I think that might be a pc bbs. Link to comment Share on other sites More sharing options...
