VicViper Posted August 28, 2021 Share Posted August 28, 2021 Just picked up a couple of dirty 800XLs, I've always cleaned the dust and grime between the keys with a toothbrush, or Q tips. Any one have any special tips or tools they use? Quote Link to comment Share on other sites More sharing options...
Papalapa Posted August 28, 2021 Share Posted August 28, 2021 The best solution is dissasemble the keyboard, release all the keycaps and put them into a container with dishwashing detergent. After two hours clear out and put the keycaps again. Once the keycaps has been release you'll see a lot of dust and dirty in the keyboard surface that can be cleaned using an brush. Usually when I buy a retrocomputer, I always do this job. Quote Link to comment Share on other sites More sharing options...
VicViper Posted August 28, 2021 Author Share Posted August 28, 2021 5 hours ago, Papalapa said: The best solution is dissasemble the keyboard, release all the keycaps and put them into a container with dishwashing detergent. After two hours clear out and put the keycaps again. Once the keycaps has been release you'll see a lot of dust and dirty in the keyboard surface that can be cleaned using an brush. Usually when I buy a retrocomputer, I always do this job. Yeah, seems like the slow way is the best way. Just ordered some key pullers. Thanks. Quote Link to comment Share on other sites More sharing options...
Tanooki Posted August 29, 2021 Share Posted August 29, 2021 It's that or you just only bother with the surface dust you can get from the top and between the cracks using a brush or one of those dinky keyboard vacuums which I imagine probably aren't that great anyway. Quote Link to comment Share on other sites More sharing options...
CatPix Posted August 29, 2021 Share Posted August 29, 2021 https://youtu.be/CQgqf6_i44U?t=520 (8:40 if the timestamp doesn't work) *insert "In Soviet Russia" joke here* I advice against doing that on your keyboard if this hasn't been tested before Quote Link to comment Share on other sites More sharing options...
