Kyan Pascal 2.0x
Materion
Hello,
I have problem with running programs written and compiled on Kyan Pascal 2.0x.
For example I write code
PROGRAM HELLO;
BEGIN
	Writeln('Hello world!');
END.
Save it as Hello.P. I run compiler write Hello.P - it compiles file without errors. It generates file Hello without any extension. I copy that file to new disk (formatted earlier). After that I copy LIB file from side B of Kyan Pascal disc to new disk. So now I have on new disk Hello and LIB files. When I try to run Hello file I got error message "Error loading Pascal Library". Manual says that library have to be on same disk with compiled program and it is. What I am doing wrong? I can't get it to work.
Same thing happen on example programs on side B of Kyan Pascal 2.0 disk - for example there is compiled Prime program. Trying to run it gives same error. LIB file is on side B of Kyan Pascal 2.0 disk so it should in theory run.
Thanks in advance for replies! :)
Edited by Materion
Copy your source and lib files on D2:
What you need to do is at the % prompt type
compile your program i.e. % pc D2:HELLO.P
type ls D2:
you should see file HELLO
CD d2:
then type the name of the program to run <RETURN>
It will work fine, basically it will look at the default drive for the LIB, so you have to change that before you run.
