VicViper Posted September 6, 2021 Share Posted September 6, 2021 Trying to launch the 128K version of Rogue from my SDC and it's tripping up. I see the file is has a tag on it that says OS9, I imagine that is the snag. Anybody know what I'm doing wrong? DRIVE 0,"ROGUE128K" OK LOADM "ROGUE128K and I get an error code. When I check DIR to see if the .DSK is mounted I get garbled data. Quote Link to comment Share on other sites More sharing options...
tlindner Posted September 7, 2021 Share Posted September 7, 2021 This is an OS-9 game that is started using the DOS <enter> command. Then, within OS-9, type ROUGE <enter> to start the game. Quote Link to comment Share on other sites More sharing options...
VicViper Posted September 7, 2021 Author Share Posted September 7, 2021 1 hour ago, tlindner said: This is an OS-9 game that is started using the DOS <enter> command. Then, within OS-9, type ROUGE <enter> to start the game. So it would go more like this? DRIVE 0,"ROGUE128K" OK DOS<ENTER> ROGUE <ENTER> I'm still fairly new to the Tandy scene, sorry if this sounds dumb. Quote Link to comment Share on other sites More sharing options...
VicViper Posted September 9, 2021 Author Share Posted September 9, 2021 Aha! I'm closer. Mounted the file to drive 0, then launch DOS, then type EX ROGUE -X And hit enter. Get to the title screen, press space, then get hit with Rogue: unknown command line argument I'm sure this would be easier with a floppy disk and a drive... still, I'm proud I made it this far as a relative noob. Quote Link to comment Share on other sites More sharing options...
MrDave Posted September 10, 2021 Share Posted September 10, 2021 Well if rogue is os9 game you must first boot up os9 then run it from there.. Quote Link to comment Share on other sites More sharing options...
VicViper Posted September 10, 2021 Author Share Posted September 10, 2021 5 hours ago, MrDave said: Well if rogue is os9 game you must first boot up os9 then run it from there.. Yes, I did that. Got to title then the command line error. Quote Link to comment Share on other sites More sharing options...
