SteveB Posted September 14, 2021 Share Posted September 14, 2021 Hi, Extended BASIC uses # for sprite- and file-numbers, like CALL MOTION(#1,16,0). I have build a subroutine for a sprite with XB256 and it feels somehow wrong to use just the sprite-number without a #. SUB SPEED(S,X,Y) CALL VREAD(1920,112,A$) X = ASC(SEG$(A$,S*4-3,1)) IF X>127 THEN X=X-256 Y = ASC(SEG$(A$,S*4-2,1)) IF Y>127 THEN Y=Y-256 SUBEND With CALL SPEED(1,X,Y) I can read the speed of of sprite #1. It would look better and more consistent if I could use CALL SPEED(#1,X,Y) instead, but this gives me a syntax error, no matter how I try to define the SUB. [The CALL VREAD() will be replaced with CALL LINK("VREAD",1920,112,A$) by SXB in this example if you want to use the routine in standard XB/XB256] Any ideas? Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted September 14, 2021 Share Posted September 14, 2021 XB can pass numeric and string variables or constants to an assembly sub. Here is the problem: #1 is not a number "#1" is a string and could be passed, but then you need the quotes. I could never see a way around this. Quote Link to comment Share on other sites More sharing options...
RXB Posted September 14, 2021 Share Posted September 14, 2021 I have been working on the source code of XB GPL and Assembly longer then probably than anyone else as it is my sole project. Why they picked the # symbol to put in Sprite routine is a mystery for me too. Quote Link to comment Share on other sites More sharing options...
SteveB Posted September 14, 2021 Author Share Posted September 14, 2021 (edited) I consider these definitive answers, thank you both! I kind of like the #1, but the # gave me hell for the syntax-highlighter in TiCodEd. But I finally managed to apapt it for the next version I am currently working on. It was interpreted as I don't know what until the end of the line. will finally become as expected. Edited September 14, 2021 by SteveB 2 Quote Link to comment Share on other sites More sharing options...
