Goochman Posted September 20, 2021 Share Posted September 20, 2021 I got a replacement Production Concerto Cart and Im trying to open it to install my Pokey chip. It seems the cart is different that the Pre-Production one I got where I squeezed the sides pretty hard and it came apart. Squeezing doesnt seem to work unless its just really tight? is there a different mechanism to opening the production carts? Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted September 20, 2021 Share Posted September 20, 2021 Do you have a screw installed under the label? Quote Link to comment Share on other sites More sharing options...
Ritchie Posted September 20, 2021 Share Posted September 20, 2021 There is one screw under the label and there is also plastic pins each side at the cart slot end. Pry them apart gently. Quote Link to comment Share on other sites More sharing options...
Goochman Posted September 20, 2021 Author Share Posted September 20, 2021 No label on the cart so the screw is removed. Ill double check but the Production Cart seems to be slightly different than the preprod cart I had. squeezing and separating the tabs a bit in the front didnt pop open the prod cart like the preprod cart. Im wondering if there is something else to be aware of on the prod cart on opening or if its the same squeeze game. I dont want to break it On a seperate note Id like to punch the person who designed the Proline joystick.......still trying to put mine back together and the first buttons keep falling out ? Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted September 20, 2021 Share Posted September 20, 2021 9 minutes ago, Goochman said: No label on the cart so the screw is removed. Ill double check but the Production Cart seems to be slightly different than the preprod cart I had. squeezing and separating the tabs a bit in the front didnt pop open the prod cart like the preprod cart. Im wondering if there is something else to be aware of on the prod cart on opening or if its the same squeeze game. I dont want to break it They’re all just re-purposed 2600/7800 shells so the only difference is whatever variation exists between the specific pieces of plastic in that particular example. Quote Link to comment Share on other sites More sharing options...
Goochman Posted September 20, 2021 Author Share Posted September 20, 2021 Ok - let the squeezing begin Quote Link to comment Share on other sites More sharing options...
Inky Posted September 20, 2021 Share Posted September 20, 2021 1 hour ago, Goochman said: Ok - let the squeezing begin That's what she said. 2 Quote Link to comment Share on other sites More sharing options...
