PLATFORM.IO ESP-IDF 3.3.2 changes. Please help build and test!
tschak909
For anyone who is building the firmware: Can you:
(1) make sure you've upgraded to latest ESP-IDF
(2) make sure you've fixed dirent.h as here: https://gist.github.com/tschak909/1ad20255c17ac321bbd6fbfde9dac2c3
(3) delete your copy of the sdkdefaults.fujinet-v1
(4) pull the latest fujinet-platformio
(5) clean
(6) build and make sure that the fujinet completely initializes?
I had to make a change to sdkdefaults to tweak static memory allocation parameters, with the latest ESP-IDF framework, and would like a few more pairs of eyes to see if things are still ok after the latest change.
https://github.com/FujiNetWIFI/fujinet-platformio/commit/dfc7374ee6881fa5d27f828addf849c3ec9c2516#diff-828575c709a84e0dfe49845ee9030bcc01f12e9220029d91761990595de011a1
Thanks for that! I just did fresh install, followed wiki but was getting following error:
Archiving .pio/build/fujinet-v1/lib209/libhardware.a
Indexing .pio/build/fujinet-v1/lib209/libhardware.a
Archiving .pio/build/fujinet-v1/lib45e/libsio.a
Indexing .pio/build/fujinet-v1/lib45e/libsio.a
Archiving .pio/build/fujinet-v1/libaca/libhttp.a
Indexing .pio/build/fujinet-v1/libaca/libhttp.a
Linking .pio/build/fujinet-v1/firmware.elf
/home/user/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/fujinet-v1/lib916/libFileSystem.a(fnFsSPIF.o):(.literal._ZN16FileSystemSPIFFS8dir_openEPKcS1_t+0x0): undefined reference to `opendir(char const*)'
/home/user/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/fujinet-v1/lib916/libFileSystem.a(fnFsSPIF.o):(.literal._ZN16FileSystemSPIFFS8dir_readEv+0x0): undefined reference to `readdir(DIR*)'
/home/user/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/fujinet-v1/lib916/libFileSystem.a(fnFsSPIF.o):(.literal._ZN16FileSystemSPIFFS9dir_closeEv+0x0): undefined reference to `closedir(DIR*)'
/home/user/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/fujinet-v1/lib916/libFileSystem.a(fnFsSPIF.o): in function `FileSystemSPIFFS::dir_open(char const*, char const*, unsigned short)':
/home/user/Projects/fujinet-platformio/lib/FileSystem/fnFsSPIF.cpp:16: undefined reference to `opendir(char const*)'
/home/user/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/fujinet-v1/lib916/libFileSystem.a(fnFsSPIF.o): in function `FileSystemSPIFFS::dir_read()':
/home/user/Projects/fujinet-platformio/lib/FileSystem/fnFsSPIF.cpp:28: undefined reference to `readdir(DIR*)'
/home/user/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/fujinet-v1/lib916/libFileSystem.a(fnFsSPIF.o): in function `FileSystemSPIFFS::dir_close()':
/home/user/Projects/fujinet-platformio/lib/FileSystem/fnFsSPIF.cpp:57: undefined reference to `closedir(DIR*)'
collect2: error: ld returned 1 exit status
*** [.pio/build/fujinet-v1/firmware.elf] Error 1
============================================================================ [FAILED] Took 88.48 seconds ============================================================================
Environment    Status    Duration
fujinet-v1     FAILED    00:01:28.477
======================================================================= 1 failed, 0 succeeded in 00:01:28.477 =======================================================================
The terminal process "platformio 'run', '--environment', 'fujinet-v1'" terminated with exit code: 1.
(pasting here so it will be easier for others to find if looking for same error)
after modifying dirent.h all is working as expected. Thanks!
Thanks, yes. the 4.3.x IDF (that's packaged with platformio-espidf 3.x) has been a never ending stream of fixes like this as the underlying behavior changes.
-Thom
  • 9 months later...
