KeatonGamer1248 Posted September 21, 2021 Share Posted September 21, 2021 My AFB9 Gold Menu Screen shows the Flashback X screen, and I want to change it back to where it was, and be able to read the SD Card How do I do this? Please help! ? Quote Link to comment Share on other sites More sharing options...
Draxxon Posted September 21, 2021 Share Posted September 21, 2021 Sounds like you flashed the AFBX firmware onto the AFB9G. IDK, try to flash the correct firmware with an otg cable and flashdrive, or maybe try using a PC to push the correct firmware onto the unit. Quote Link to comment Share on other sites More sharing options...
KeatonGamer1248 Posted September 21, 2021 Author Share Posted September 21, 2021 (edited) I did flash the firmware to AFBX... ? Edited September 21, 2021 by KeatonGamer1248 I need to rewrite Quote Link to comment Share on other sites More sharing options...
Draxxon Posted September 21, 2021 Share Posted September 21, 2021 (edited) what happens if you put the correct firmware on the sd card and turn the system on? If it doesn't work try an OTG cable and flashdrive. Here is the correct custom firmware for your system. But how do you flash it now? https://atariage.com/forums/applications/core/interface/file/attachment.php?id=837182 Edited September 21, 2021 by Draxxon Quote Link to comment Share on other sites More sharing options...
KeatonGamer1248 Posted September 21, 2021 Author Share Posted September 21, 2021 Quote what happens if you put the correct firmware on the sd and turn the system on? If it doesn't work try an OTG cable and flashdrive Here is the correct custom firmware for your system. But how do you flash it now? https://atariage.com/forums/applications/core/interface/file/attachment.php?id=837182 Ooooh! I hope this works!!! Quote Link to comment Share on other sites More sharing options...
KeatonGamer1248 Posted September 21, 2021 Author Share Posted September 21, 2021 But yet...I'm kinda scared to flash it again. Because, if it doesn't work...then I won't know what to do, because I don't even know what is a OTG cable, and I don't even know if my console has that...? Quote Link to comment Share on other sites More sharing options...
KeatonGamer1248 Posted September 21, 2021 Author Share Posted September 21, 2021 (edited) The rom, and boxart cannot be loaded. I'm dead inside... What should I do know? Edited September 21, 2021 by KeatonGamer1248 font, emojis etc Quote Link to comment Share on other sites More sharing options...
KeatonGamer1248 Posted September 21, 2021 Author Share Posted September 21, 2021 (edited) 5 minutes ago, KeatonGamer1248 said: The rom, and boxart cannot be loaded. I'm dead inside... What should I do know? Ohmigosh! I finally fixed it! Thank you so much!!! Well...that is just what I think what happened. Edited September 21, 2021 by KeatonGamer1248 REASON: REWRITE Quote Link to comment Share on other sites More sharing options...
Draxxon Posted September 22, 2021 Share Posted September 22, 2021 did you flash the custom firmware from post #4? Quote Link to comment Share on other sites More sharing options...
KeatonGamer1248 Posted September 22, 2021 Author Share Posted September 22, 2021 (edited) Yes...? Edited September 22, 2021 by KeatonGamer1248 1 Quote Link to comment Share on other sites More sharing options...
Draxxon Posted September 22, 2021 Share Posted September 22, 2021 (edited) Awesome, because then you didn't just fix your AFB9G, you also hacked it. Put these files on the root of a fresh SD Card. 4GB (up to 32GB SD Card will work). Atari Flashback - Project Nexus V.0.9.0 https://drive.google.com/file/d/113xZFhe1RXtbj_rSOzq_4EuE45uTEsfp/view?usp=sharing Edited September 22, 2021 by Draxxon Quote Link to comment Share on other sites More sharing options...
KeatonGamer1248 Posted September 23, 2021 Author Share Posted September 23, 2021 Does it have to stay on the SD Card? Because I have a 4GB SD Card. Quote Link to comment Share on other sites More sharing options...
Draxxon Posted September 23, 2021 Share Posted September 23, 2021 (edited) Yes, but, its less than 4GB. it is like 2.6 GB zipped. I forget what it is unzipped but it may fit on your card. If not you could remove jaguar because they don't work or even the karaoke songs and make it fit. Edited September 23, 2021 by Draxxon Quote Link to comment Share on other sites More sharing options...
KeatonGamer1248 Posted September 23, 2021 Author Share Posted September 23, 2021 Do you know if this will work? Quote Link to comment Share on other sites More sharing options...
Draxxon Posted September 23, 2021 Share Posted September 23, 2021 I'm thinking, yes. it will work. Quote Link to comment Share on other sites More sharing options...
KeatonGamer1248 Posted September 23, 2021 Author Share Posted September 23, 2021 I mean like, the Emulators... Quote Link to comment Share on other sites More sharing options...
Draxxon Posted September 23, 2021 Share Posted September 23, 2021 (edited) Well, yeah the emulators work. Except for Jaguar, but I threw it in there because its Atari. Edited September 23, 2021 by Draxxon Quote Link to comment Share on other sites More sharing options...
KeatonGamer1248 Posted September 23, 2021 Author Share Posted September 23, 2021 It didn't work. Now what? Quote Link to comment Share on other sites More sharing options...
Draxxon Posted September 23, 2021 Share Posted September 23, 2021 (edited) How did you flash the AFBX update over your AFB9G. Did you use the SD Card or the Android Tools and a PC? What is the version number show in your about screen? It should say version V.2.1.1 and you flashed the custom firmware from the post above and it restored your system without an SD Card inserted? Again, how did you flash it? With the SD Card or Android Tools and PC? It prompted you to update and press left, and you got the spinning glowing circle update graphic? Like, does it say Atari Flashback 9 gold across the top of the background now? You have the purple grid and planet background back? All your built in games are showing and work? When you put an SD Card in your system and the box art doesnt show, what is on your SD Card? delete everything off of your SD Card and see what happens if you put just a folder named "game" on your SD Card and inside it place an Atari 2600 rom with .a26 extension? Edited September 23, 2021 by Draxxon Quote Link to comment Share on other sites More sharing options...
KeatonGamer1248 Posted September 23, 2021 Author Share Posted September 23, 2021 I actually fixed it! I did some editing to the SD Card and got everything back to normal. Well...it seemed normal, but everything just didn't feel right, the quality of the box art was just so low-quality. Like it was created with MS-Paint. I didn't really mind though. However, when I woke up this morning, and turned on the AFB9 Gold, I just stared at the screen for like 3 minutes, happily listening to the music and for a split second I heard just a slight glitch and then I heard this loud Hissing and it was like: HHHSSSSZSSSSZSSSS! And I was like startled like I thought that there was going to be some sorta ghost going to pop outta the screen! Or...some other weird stuff. I just turned off the AFB9 Gold after that. And then I turned it back on, and nothing bad happened, until I quit a game, and that same thing happened again! HHHSSSSZSSSSZSSSS! I was startled again, but then I was like: Don't worry! I will open up a game! I wonder if it is because that it is also reading the SD Card's audio directory too. Like I found some sound files and it had the music that gone to the console and it had that good music! The file was titled BGM.ogg and in the SD:\emulator\res\audio directory. So, like I said, everything seemed off on the console when I fixed it. Quote Link to comment Share on other sites More sharing options...
Draxxon Posted September 24, 2021 Share Posted September 24, 2021 (edited) Glad to hear you got it sorted. Edited September 24, 2021 by Draxxon Quote Link to comment Share on other sites More sharing options...
