Moving a game from a PET cassette to a modern computer
Hello,
I was looking for the 1979 version of Legionnaire by Chris Crawford, and I found a version... Chris Crawford himself has one.
The problem is that neither him nor me know how to transfer from Commodore PET to a support that lasts (aka : upload on Internet, ultimaly).
Do any of you know how to do this, or know someone who do this ? Let's beat data degradation!
The easiest way by far would be to just do a transfer on a Commodore machine to something like an SD2IEC.
If you don't have a real machine with a Datassette of some kind, though, maybe something like https://wav-prg.sourceforge.io/ could be useful, or one of the alternatives listed on that site?
That would be SD2PET if the original hardware still exists. Assuming we have a minor plethora of vintage hardware to choose from, an IEEE-488 disk drive like the 3040, 4040, 2031 is read compatible with 1541 meaning you could load the program off tape on the PET, save it to a floppy disk and then either load it on e.g. a C64 or even better, use a ZoomFloppy or X-series cable to transfer the program to a PC. But I realize I'm making a ton of assumptions now.
Theoretically one might use cbmlink and solder up an interface like prlink but it is a bit fiddly and hit and miss. I agree that WAV-PRG probably is your best bet, whether you can configure it to PET at exactly 1.0 MHz.
I've found that WAVPRG doesn't work and I don't recall it supporting PET tapes, but I suppose it's worth a try. You could also just put the tape in a regular tape recorder and record a simple WAV of the entire tape and upload it here. One of us could record that WAV file back onto a tape and load it into a PET, then use an SD card device to save the program.
Or if you have a PET, you could do that yourself. Bitfixer's PETdisk MAX is a cheaper alternative to the SD2PET, coming in at $45, and although I don't have an SD2PET, my PETdisk MAX has been excellent so far.
I've done this with a C64, a datasette drive, an SD2IEC drive, and the COPY190 program.  At that point you have the .prg file saved to the SD card and can do whatever.
** DARN!  I mean to enter the above as part of a reply quoting brpocock@star-hope.org's reply above.  Basically it's what he suggests.  Just wanted to chime in that I've had good success with that method.
Edited by Rick Reynolds
The PET program is probably 100% BASIC.
The cheapest way to copy it without buying cables and custom hardware,
is to make an audio recording of the tape (WAV file).
this can be done with a cable from Hi-Fi to PC.
i use stereo mix in sound card options.
*windows 7-10 has this setting disabled by default, and you need to enable it from control panel.
https://www.howtogeek.com/217348/how-to-record-the-sound-coming-from-your-pc-even-without-stereo-mix/
Depending on the sound quality, audiotap (Win32) will convert that into a TAP file.
This can then be loaded into VICE emulator where you can save the BASIC as a PRG file.
if you can upload the audio i will have a go at converting it.
i have already done this for a few Avalon Hill PET games.
