senior_falcon Posted October 26, 2021 Share Posted October 26, 2021 4 hours ago, F.G. Kaal said: Writting >FFFF to address >8802 to change a register (both >8000 for writing to register and >4000 for writing VDP RAM are set) tries to change a register that doesn't exist. Emulator gives a warning ones and continues. Writing >FFFF to address >8C02 (VDPWA) to setup an address to write data (both the >8000 bit for writing to register and >4000 bit for writing VDP RAM are set) changes the VDP address to >3FFF. Emulator gives a warning ones and continues. If data is read instead of written then the Emulator gives a warning but continues. This is just messy programming. Writing an address with >4000 bit reset to >8C02 (VDPWA) to read a value but a value is written instead then Emulator gives a warning but continues. This is just messy programming. Writing an address with >4000 set to >8C02 (VDPWA) to write a value but a value is read instead then Emulator gives a warning but continues. This is just messy programming. However, the real VDP does a prefetch when data is about to be read and that prefetch is not done in this case and can cause a wrong value to be read. I am confused. Are you saying that XB256 does the above? Quote Link to comment Share on other sites More sharing options...
fabrice montupet Posted October 26, 2021 Author Share Posted October 26, 2021 I still tried today same problem playing CALL SOUND(100,6000,0) Here is a video showing the problem and the DEBUG.TEXT file: http://www.ti99.com/misc/IMG_2090.MOV http://www.ti99.com/misc/DEBUG.TXT Quote Link to comment Share on other sites More sharing options...
SteveB Posted October 26, 2021 Share Posted October 26, 2021 Well, I had the same issue with my XB256 game-program, hanging on the first CALL SOUND, but the latest release fixed it and everything works now for me. Quote Link to comment Share on other sites More sharing options...
fabrice montupet Posted October 26, 2021 Author Share Posted October 26, 2021 (edited) Oh! After numerous tests, I noticed that the problem seems to not be the frequency that causes the garbage noise & sounds but the duration. After 25 minutes testing different duration values, all CALL SOUND (note or noise) including a duration below the value 34 were played perfectly with no erratic sound after. But if I use the value 34 and higher, the CALL SOUND cause problems. EDIT: Important precision: If I do a NEW and execute a simple XB256 program just containing a CALL SOUND with a duration > 33, it works. If I insert a CALL SOUND with a duration > 33 in my XB256 program (It only uses CALL LINK "DELAY" and "DISPLY" and uses SCREEN1 XB256 features) , the problem appears. ...My program is haunted! ? Edited October 26, 2021 by fabrice montupet Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted October 26, 2021 Share Posted October 26, 2021 Before I invest a lot of time tracking down a problem that may not even be a problem, I need to know whether this behavior happens when using Classic99 or Win994a or a real TI99. Quote Link to comment Share on other sites More sharing options...
fabrice montupet Posted October 26, 2021 Author Share Posted October 26, 2021 This problem doesn't interfere the programming of my XB256 program, I just have to pay attention to not exceed the value 33 in the duration of a tone/noise. When it will be corrected, I just will have to put the right duration ? Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted October 26, 2021 Share Posted October 26, 2021 Sounds like: ...Time for a Pentium 9900 processor 2 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted October 27, 2021 Share Posted October 27, 2021 2 hours ago, fabrice montupet said: This problem doesn't interfere the programming of my XB256 program, I just have to pay attention to not exceed the value 33 in the duration of a tone/noise. When it will be corrected, I just will have to put the right duration ? Without more information, this will never be corrected. Again, does this problem happen with Classic99 or a real TI99??? I entered this: 10 CALL SOUND(1000,220,0) 20 CALL SOUND(1000,440,0) and it runs properly under XB256 using both Classic99 and a real TI99 I added another line: 15 CALL SOUND(1000,330,0) and again it runs properly under XB256 with both Classic99 and a real TI99 I am unable to test TI994W. Does this cause the problem for you using TI994W? 1 Quote Link to comment Share on other sites More sharing options...
F.G. Kaal Posted October 27, 2021 Share Posted October 27, 2021 (edited) 19 hours ago, senior_falcon said: I am confused. Are you saying that XB256 does the above? Don't get confused ... This is just a description of what the Ti994w emulator does when an erroneous value is written to the VDP in order to set a VDP read/write address or trying to change a VDP register. An error message is printed in the debug window and the Ti994w emulator is making the best of it. The programmer/user must do something with this The original problem was that the game ALIENKEY-X was writing a value of >FFFF to the VDP. The question is: Is this just an error in the game ALIENKEY-X (the problem lays then between the backrest and the computer screen) or is it caused by one of the XB256 functions that game is using. And this was the piece of code that was executed when it happened, see addresses >FF44 to >FF4E. Again; I don't know if this is a programmers error, or an error the programmer should think about (writing to address -1) or that this is caused by a function the programmers is using. The only thing I could fix is that the Ti994w emulator is doing it's best to continue to run the faulty program and not stop functioning. Spoiler >F20A: >070F SETO R15 >F20C: >0420 BLWP @>E518 >F210: >C160 MOV @>83AA ,R05 >F214: >1303 JEQ >03 [ to PC:>F21C ] >F216: >C800 MOV R00,@>FAAE >F21A: >1002 JMP >02 [ to PC:>F220 ] >F21C: >C800 MOV R00,@>FADA >F220: >0460 B @>E836 >F224: >04C0 CLR R00 >F226: >0201 >8000 LI R01,>8000 >F22A: >0202 >0300 LI R02,>0300 >F22E: >06A0 BL @>E4EA >F232: >1002 JMP >02 [ to PC:>F238 ] >F234: >D801 MOVB R01,@>8C00 VDPWD >F238: >0602 DEC R02 >F23A: >16FC JNE >FC [ to PC:>F234 ] >F23C: >0460 B @>E836 >F240: >06A0 BL @>E894 >F244: >C014 MOV *R04,R00 <--- R4 = >D928 == >0001 >F246: >C095 MOV *R05,R02 <----R5 = >D92A == >0000 >F248: >0600 DEC R00 R0 := >0000 >F24A: >0602 DEC R02 R2 := >FFFF >F24C: >0A50 SLA R00,05 R0 := >0000 >F24E: >A002 A R02,R00 R0 := >FFFF >F250: >06C0 SWPB R00 >F252: >D800 MOVB R00,@>8C02 VDPWA >F256: >06C0 SWPB R00 >F258: >D800 MOVB R00,@>8C02 VDPWA >F25C: >1000 JMP >00 [ to PC:>F25E ] V9938: R63 := >FF (255) ERROR: VDP register number out of range >F25E: >D060 MOVB @>8800 VDPRD,R01 >F262: >0221 >A000 AI R01,>A000 Edited October 27, 2021 by F.G. Kaal 1 Quote Link to comment Share on other sites More sharing options...
F.G. Kaal Posted October 27, 2021 Share Posted October 27, 2021 (edited) 19 hours ago, fabrice montupet said: I still tried today same problem playing CALL SOUND(100,6000,0) Here is a video showing the problem and the DEBUG.TEXT file: http://www.ti99.com/misc/IMG_2090.MOV http://www.ti99.com/misc/DEBUG.TXT Hihi ... very interesting. What I meant is to examine the addresses that is used for sound. It is described in the editor assembler manual. Word address >83CC is a pointer to the sound list in VDP (or CPU) ram Byte address >83FD is a flag (bit >01) to tell the system that the buffer is in VDP ram Byte address >83CE is a trigger (bit >01) that starts the sound When a call sound is executed these addresses are set. I can imagine that if something is fooling arround with these addresses that some random/garbidge noise is played. You can edit this window by holding the CTRL key and klick on a '-' or a 'name' (left column). A small dialog is opened in which you can enter the thing you want to keep a close eye to. The debug.txt file: Is that a capture when the emulator is doing nothing/not running any program? The emulator is not writing to the sound addresses by itself ... there must be some TI99 code behind it to do that. Or paste this at the correct place in the Ti994w.ini file Spoiler [WatchToolWindow] ; ; Automatically created ; left=10 top=10 width=435 height=323 open=1 var00=>83C6 83c6 0122 000a var01=KBMODE 8374 0122 0002 var02=ASCII 8375 0122 0014 var03=- 0000 0124 000f var04=- 0000 0141 0010 var05=STATUS 837c 0122 0010 var06=- 0000 0124 0008 var07=>8379 8379 0122 0008 var08=>834A 834a 0144 0008 var09=STACK 838a 0164 0006 var10=- 0000 0124 0008 var11=SoundB 83cc 0124 0006 var12=VdpFlg 83fd 0122 0014 var13=SndTrg 83ce 0122 0007 var14=CDATA 0379 0262 000a var15=- 0000 0164 0007 var16=- 0000 0164 0004 var17=- 0000 0124 0028 var18=- 0000 0124 0000 var19=- 0000 0124 0028 var20=- 0000 0164 0004 var21=- 0000 0124 0005 var22=- 0000 0162 0014 var23=- 0000 0164 0003 var24=- 0000 0124 000a var25=- 0000 0464 0010 var26=- 0000 0241 000a var27=- 0000 0104 0000 var28=- 0000 0104 0000 var29=- 0000 0104 0000 var30=- 0000 0104 0000 var31=- 0000 0104 0000 var32=- 0000 0000 0000 Edited October 27, 2021 by F.G. Kaal 1 Quote Link to comment Share on other sites More sharing options...
fabrice montupet Posted October 27, 2021 Author Share Posted October 27, 2021 (edited) 17 hours ago, senior_falcon said: Without more information, this will never be corrected. Again, does this problem happen with Classic99 or a real TI99??? I entered this: 10 CALL SOUND(1000,220,0) 20 CALL SOUND(1000,440,0) and it runs properly under XB256 using both Classic99 and a real TI99 I added another line: 15 CALL SOUND(1000,330,0) and again it runs properly under XB256 with both Classic99 and a real TI99 I am unable to test TI994W. Does this cause the problem for you using TI994W? If I had seen the problem on the real 99/4A or Classic99, I would not have post my message in this thread that I have created to report problems with the ti994w emulator. Please, read well my messages. You'll see that I have no problem with CALL SOUND inserted in a simple loop but in my programs that contain XB256 features like CALL LINK DELAY AND DISPLY using the ti994w emulator. I make no conclusion, It is just a behavior noticed. But maybe the CALL SOUND erratic behavior is present just using TI Extended Basic? I don't know. The problem is that all my program use XB256 features so I can't try to reproduce the problem with just Extended Basic running. Edited October 27, 2021 by fabrice montupet Quote Link to comment Share on other sites More sharing options...
fabrice montupet Posted October 27, 2021 Author Share Posted October 27, 2021 (edited) An other problem noticed (TMS9918 mode): 10 CALL SCREEN(2) 20 GOTO 20 'Use all free CPU time' disabled, I obtain a black screen. Normal ? 'Use all free CPU time' enabled, I obtain a cyan screen... Why? Edited October 27, 2021 by fabrice montupet Quote Link to comment Share on other sites More sharing options...
fabrice montupet Posted October 27, 2021 Author Share Posted October 27, 2021 5 hours ago, F.G. Kaal said: The debug.txt file: Is that a capture when the emulator is doing nothing/not running any program? The emulator is not writing to the sound addresses by itself ... there must be some TI99 code behind it to do that. The debug.txt file is the result of what you see (ear) in the video, when I added the value 34 in the duration of a call sound I inserted in my program. My program contains no other audio code than the CALL SOUND(100,6000,0) Quote Link to comment Share on other sites More sharing options...
+Retrospect Posted October 28, 2021 Share Posted October 28, 2021 15 hours ago, F.G. Kaal said: Is this just an error in the game ALIENKEY-X Hi. I'm the author of that software. As far as I know the game shouldn't produce anything strange. Does the game hang or crash? And if so at what point in the game does this happen? Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted October 28, 2021 Share Posted October 28, 2021 Fred found an error in the "star wars" scroll code. I was using INC to advance a return address where I should have been using INCT. This never caused trouble with Classic99 and I believe it works on a real TI99 as well. I think the reason is that when an invalid opcode is encountered it is just skipped. Apparently TI994W reports an error instead. (Not saying that's bad, it's just different) I suppose it is possible that something like this is causing the problem. I will look into it some more. 6 Quote Link to comment Share on other sites More sharing options...
F.G. Kaal Posted October 28, 2021 Share Posted October 28, 2021 21 hours ago, fabrice montupet said: The debug.txt file is the result of what you see (ear) in the video, when I added the value 34 in the duration of a call sound I inserted in my program. My program contains no other audio code than the CALL SOUND(100,6000,0) Aha ... now I understand, there was a sound here on this side. The volume of my laptop was set to low. As I said a few message back; there must be TI99 code behind it, the emulator is not doing something by it self. The movie does not tel me yet what is going on because it doesn't show the interesting sound addresses. See my message #85 of yesterday. And if those strange sounds are playing and you halt the emulator, does the sound continues? And if the emulator is halted and the souns stopped, what happens when you single step? What code do you see? On what CPU addresses is that code running? Quote Link to comment Share on other sites More sharing options...
F.G. Kaal Posted October 28, 2021 Share Posted October 28, 2021 12 hours ago, Retrospect said: Hi. I'm the author of that software. As far as I know the game shouldn't produce anything strange. Does the game hang or crash? And if so at what point in the game does this happen? The game doesn't crash Stargunner ?. There is a value of >FFFF written to the VDP and that value is illegal because it is both a VDP write address (>3FFF) and a VDP register value >FF for VDP register 63. Both the 9918 and 9938 does not have a register 63. The $65535 question is if that value is caused by the user program (game) or is it caused by some library function the program is using. 3 Quote Link to comment Share on other sites More sharing options...
F.G. Kaal Posted October 28, 2021 Share Posted October 28, 2021 (edited) 1 hour ago, senior_falcon said: Fred found an error in the "star wars" scroll code. I was using INC to advance a return address where I should have been using INCT. This never caused trouble with Classic99 and I believe it works on a real TI99 as well. I think the reason is that when an invalid opcode is encountered it is just skipped. Apparently TI994W reports an error instead. (Not saying that's bad, it's just different) I suppose it is possible that something like this is causing the problem. I will look into it some more. That is good news senior_falcon. It is also not a problem anymore in Ti994w ... the emulator was just very strict. In the 20 years (or so) that this emulator exists it is the first time I saw something like this strange VDP writings happen, the value >FFFF sugests that it should have been >0000 (i guess). And it was indeed during scolling in the ALIENKEY game. Somewhere in this stage of the games it happens: And this is the log: Spoiler V99xx: read data VDPRA >4340 (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >435C (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >437F (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >40C1 (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >40C4 (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >42F0 (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: VDPWA = >FFFF ERROR: Both bits for writing register and data are set V9938: R63 := >FF (255) ERROR: VDP register number out of range V99xx: read data VDPRA >FFFF (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >437F (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >4348 (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >437F (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >436C (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >4790 (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >4300 (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >437F (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >4340 (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >478E (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >437F (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >437F (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >437F (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >42F0 (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >437F (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >437F (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >437F (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >4344 (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >40D4 (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >42F0 (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >4782 (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >4302 (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >42F0 (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >478E (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: read data VDPRA >40C3 (ERROR reading data but bit 0x8000 and/or 0x4000 is set) V99xx: VDPWA = >FFFF ERROR: Both bits for writing register and data are set V9938: R63 := >FF (255) ERROR: VDP register number out of range V99xx: read data VDPRA >FFFF (ERROR reading data but bit 0x8000 and/or 0x4000 is set) It is not only that a value of >FFFF is written but also that a VDP read address is setup with bit >4000 set. This bit must only be set when setting up a VDP write address. According to the VDP TMS9918 manual there can be a penalty for doing it incorrect on the real iron. If a VDP read address is setup properly the VDP does a prefetch of the data. If it is done incorrect the prefetch doesn't happen and when the data is read then it is possible the the VDP can't fetch the data in time. The (disassembled) code that is in lomem when using the editor/assembler module is i.e. like this: Spoiler * VSBW VSBW$ BL @VDPW Setup VDP write address MOVB @2(R13),@VDPWD Write byte RTWP * VMBW VMBW$ BL @VDPW Setup VDP write address VMBW$1 MOVB *R1+,@VDPWD Write byte DEC R2 More? JNE VMBW$1 Yes! RTWP * VSBR VSBR$ BL @VDPR Setup VDP read address MOVB @VDPRD,@2(R13) Read byte RTWP * VMBR VMBR$ BL @VDPR Setup VDP read address VMBR$1 MOVB @VDPRD,*R1+ Read byte DEC R2 More? JNE VMBR$1 Yes! RTWP * VWTR VWTR$ MOV *R13,R1 Get register number and data MOVB @1(R13),@VDPWA Write data ORI R1,>8000 Set MSBit for VDP register number MOVB R1,@VDPWA Write register number RTWP * This standard function is doing a bit to much for VSBW and VSBR but it makes the code a few istructions shorter. * VDP R/W helper VDPW LI R1,>4000 Set bit for VDP write address JMP VDP$1 VDPR CLR R1 No bits to set for VDP read adrress VDP$1 MOV *R13,R2 Get VDP address MOVB @UTILWS+LR02,@VDPWA Write LOByte SOC R1,R2 Set bits (if any) MOVB R2,@VDPWA Write HOByte MOV @2(R13),R1 Get R1 (byte or buffer address) MOV @4(R13),R2 Get byte count RT Edited October 28, 2021 by F.G. Kaal 1 Quote Link to comment Share on other sites More sharing options...
F.G. Kaal Posted October 28, 2021 Share Posted October 28, 2021 22 hours ago, fabrice montupet said: An other problem noticed (TMS9918 mode): 10 CALL SCREEN(2) 20 GOTO 20 'Use all free CPU time' disabled, I obtain a black screen. Normal ? 'Use all free CPU time' enabled, I obtain a cyan screen... Why? Sorry ... I only see black screens. The TMS9918 and V9938 are using the same code. Only if V9938 is enabled the code is using 45 VDP registers and 128Kb VDP RAM and 64Kb extended VDP ram and (almost) all the V9938 goodies build in to that processor. What module are you using? Quote Link to comment Share on other sites More sharing options...
fabrice montupet Posted October 28, 2021 Author Share Posted October 28, 2021 18 minutes ago, F.G. Kaal said: Sorry ... I only see black screens. The TMS9918 and V9938 are using the same code. Only if V9938 is enabled the code is using 45 VDP registers and 128Kb VDP RAM and 64Kb extended VDP ram and (almost) all the V9938 goodies build in to that processor. What module are you using? It works for you? This is beyond me. I have precised that I use TMS9918 mode just in case where you would ask to me. I use the original ROM /GROM TI-99/4A files (those you give with the emulator) and TI Extended Basic. I have made the same test today and I notice again a cyan screen. Do you have made the test several times? Quote Link to comment Share on other sites More sharing options...
+Retrospect Posted October 28, 2021 Share Posted October 28, 2021 Fabrice, if you are using XB256 to do these things, it might be worthwhile checking to see if you have the very latest update. Thats the only advice I can offer here. Quote Link to comment Share on other sites More sharing options...
fabrice montupet Posted October 28, 2021 Author Share Posted October 28, 2021 Thank you for your advice ? I use the Juwel folder with ti994w. Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted October 29, 2021 Share Posted October 29, 2021 Can someone provide me a copy of ALIENKEY-X. Quote Link to comment Share on other sites More sharing options...
+Retrospect Posted October 29, 2021 Share Posted October 29, 2021 2 hours ago, senior_falcon said: Can someone provide me a copy of ALIENKEY-X. ALIENKEY-X im not saying its aliens.txt Just in case you need it there's the XB source included. Quote Link to comment Share on other sites More sharing options...
Tursi Posted October 29, 2021 Share Posted October 29, 2021 (edited) 12 hours ago, senior_falcon said: Fred found an error in the "star wars" scroll code. I was using INC to advance a return address where I should have been using INCT. This never caused trouble with Classic99 and I believe it works on a real TI99 as well. I think the reason is that when an invalid opcode is encountered it is just skipped. Apparently TI994W reports an error instead. (Not saying that's bad, it's just different) Two things about that... Invalid opcodes use six cycles and do not affect registers or memory. But an odd return address is simply cropped to 15 bits. The 9900 can only express 15 bits of address, so the least significant bit never makes it out to the hardware, including RAM. BigFoot also crashes if you don't handle this correctly. Edited October 29, 2021 by Tursi 3 Quote Link to comment Share on other sites More sharing options...
