cc65 linker error compiling memory lib.
13 hours ago, Harry Potter said:
I have another problem: how do I define the __RESERVED_MEMORY__ macro on the ld65 command-line?  I mean, how do I know what to assign to it?
I know you solved your problem, but this is an examlpe of one I use
cl65 -t atari -Oi -T -Wl "-D__RESERVED_MEMORY__=0x3000" --static-locals -l temp.lst -o temp.xex temp.c
52 minutes ago, Harry Potter said:
How do I know what to assign to __RESERVED_MEMORY__?
It seems to depend on what you're doing as I believe cc65 uses the upper regions of memory, so if
you want to change graphics modes, the call to _graphics can potentially overwrite some code/data
and obviously crash your program.
For example, I have a program that uses a standard _graphics(0) call, but I also need space for a _graphics(3)
so I reserved 1K for the extra screen mode as after creating, I switch back and forth without calling the graphics modes
again
