Accessing the drive?
Just a small point @Harry Potter , I notice in your code there are still things like
char string[100]={"ABCDEF"};
then later you pass the string in a function like
result = myfunc(&string,a,b);
there is no need to use the "&", when you define a variable as char string[100] string is a pointer.
In your code although it will probably still work, you may be wasting cycles while the code gets the
address of 'string'.
I only say this as you said you want optimizations and this is one such way :)
Now, there is something wrong with the loadauxfile() function: it loads only one byte before exiting.  The aux memory contains more than one byte.  I attached the file containing the function.  Also, the extra Low me mory still crashes the system.  I attached the config and crt0.s files.
readauxfile.c atarixl_memx.cfg crt0.s
8 minutes ago, Harry Potter said:
the file that is loaded into aux memory is empty.
No file is loaded into aux memory - by putting strings in that C file the resulting executable simply has a section that loads data there. So its like saying the a file is loaded into MAIN memory.
I got it to work: I used #pragma data-name instead of #pragma rodata-name, and now that works.  But now, the XBUF memory area doesn't work.  I really want to use this buffer for code and data.  Maybe I'm doing it wrong.  I pasted the header code here.
.segment    "XBUFH"
.word        __XBUF__START__
.word        __XBUF__START__+__XBUF__SIZE__
