Automatic Hex conversion of text for Hardball
I have taken more than 8 hours to write and perfect a program that will take any word(s) that you type in and convert that series of words into a string of HEX codes that are exact codes for printing text on the player stats screen on Hardball.
Because Hardball uses a non standard code for upper case and lower case letter and for numbers, I took the time to make a program that will help you with Sherlock, or any HEX editor for that Atari 8 Bit , here is the ATR with whe proglam in Basic, and DOS, DUP, etc.
Automatically calculate HEX strings for Hardball Editing.atr
Had a quick look at your code, I think you may have one of the checks wrong,
line 1080 checks for "i"
so does line 2080, is that meant to be "I" and the code "29" ?
Also you could put a "RETURN" after each character check as it will only return on the line that matches
Let me have a look, it may be an error
Russ
Here's a different way to lookup the hex characters, no quicker, but a lot less typing :)
1 ? CHR$(125)
10 DIM A$(100),B$(200),C$(20),D$(1),OUT$(2)
20 A$="abcdefghijklmnopqrstuvwxyzA BCDEFGHIJKLMNOPQRSTUVWXYZ1234567890"
30 B$="0102030405060708090A0B0C0D0E0F101112131415161718191A21  "
40 B$(LEN(B$)+1)="22232425262728292A2B2C2D2E2F303132333435363738393A4142434445464748494A"
60 POSITION 0,6:? "                      ":POSITION 5,5:? "ENTER STRING ":INPUT C$
70 IF C$="" THEN 10000
80 FOR I=1 TO LEN(C$):D$=C$(I,I)
90 GOSUB 1000
100 NEXT I
110 GOTO 60
1000 FOR J=1 TO LEN(A$)
1010 IF A$(J,J)=D$ THEN 1100
1020 NEXT J
1030 RETURN
1100 POP :OUT$=B$(J*2-1,J*2)
1110 ? OUT$;" ";
1120 RETURN
10000 END
My version has printer support and saves to disk, plus its already typed in, I will post the new version..... however I do like your version too....have you used a hex editror before? I use Disk Magic from Blak Magic Software , hope to edit Hardball to put in the 2021 teams really soon, starting with The Yankees and the Red Sox
Russ
Hope you don't mind, couldn't resist trying to speed it up a bit :)
Uses a machine code USR call to speed up the lookup process
1 ? CHR$(125)
15 GOSUB 20000
90 X=USR(1536,ADR(A$),ADR(D$),LEN(A$)):GOSUB 1000
100 NEXT I
110 GOTO 60
1000 X=X+1:OUT$=B$(X*2-1,X*2)
1010 ? OUT$;" ";
1020 RETURN
10000 END
20000 I=0:RESTORE
20010 READ A:IF A=-1 THEN RETURN
20020 POKE 1536+I,A:I=I+1:GOTO 20010
20030 DATA 104,104,133,204,104,133,203,104,133,206
20040 DATA 104,133,205,104,104,141,46,6,160,0
20050 DATA 177,205,209,203,240,13,200,204,46,6
20060 DATA 208,246,169,0,133,212,133,213,96,169
20070 DATA 0,133,213,132,212,96,0,-1
I should mention that there is a mistake in my original program, I have the number 0 listed as 4A, when in fact it is 40, and I have added the comma , which is 4D....other than that no changes , I find that I am using the program quite often for helping my write out names in the hex editor. I am still hard at work producing the very first 2021 team for Hardball, and there is a lot of data that I missed in the 1985 program, I still copied sectors 106 , and 112 to 128, but I missed sector 105, that is where you can put the name of the 2 teams in highlighted text, instead of 'Cracked by whomever from that era', I am also working on a midi port for the Atari 8 bit, it needs a midi keyboard to play back any music? Apparently there is a way to get my music into the Fujinet through Bluetooth, (yes the Fujinet supports it).
Russ
PS: This is what I use the program for:
In order to make updates for this program , I need what I have written in the above....
