Daedalus2097 Posted October 8, 2021 Share Posted October 8, 2021 Just finished this build for another member of the Scottish Amiga Users Group. It has a new white ReAmiga 1200 motherboard, a new A1200.net translucent case, a mini Gotek and custom bracket, with on-screen display and keyboard control, and a Solas board to provide the RGB lighting (as well as some other functions). Might not be to everyone's tastes, but it's quite the eye-catching machine. I'll be sorry to be passing this one back to its owner! 5 1 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 8, 2021 Share Posted October 8, 2021 I would not own something like this as I feel it is tacky as hell and impractical. That said, it is indeed eye-catching and a pretty piece of eye candy, especially with 3.2 under the hood. Nice work. Now, I guess the ReAmiga board supports a dual Kickstart, right? Quote Link to comment Share on other sites More sharing options...
+save2600 Posted October 8, 2021 Share Posted October 8, 2021 Ghettolicious! All it needs now is some shiny chrome and a subwoofer. ? 1 Quote Link to comment Share on other sites More sharing options...
Daedalus2097 Posted October 11, 2021 Author Share Posted October 11, 2021 Ha yes, chrome FTW Yeah, the looks won't appeal to everyone, but the general practicality isn't affected - the Gotek can be controlled from the keyboard and has an on-screen overlay so there's no need to use the small screen and controls, and the RGB lighting is software controlled from Workbench, so can easily be turned off or toned down with a couple of clicks. The Re1200 motherboard does indeed have ROM switching built in - I added a small switch at the back of the case to select the ROM, and the SD card includes 3.1 and 3.2 OS installations. 2 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 11, 2021 Share Posted October 11, 2021 6 hours ago, Daedalus2097 said: RGB lighting is software controlled from Workbench Pretty slick, actually. Integrate that into a music player or WHDLoad games for ambiance. Oh, does the controller software have an ARexx port? Quote Link to comment Share on other sites More sharing options...
Daedalus2097 Posted October 11, 2021 Author Share Posted October 11, 2021 The RGB controller reads the audio output at a hardware level, so any sound from games or music players can be used to trigger animations without any software required. It doesn't have ARexx support just yet, but I'm working on it Currently it can react to audio, disk access or Shell commands aside from the main configuration program. Quote Link to comment Share on other sites More sharing options...
shoestring Posted October 13, 2021 Share Posted October 13, 2021 Interesting build. There's a potentiometer near the Gotek, that must be for the RGB lighting adjustment. Not to my taste either but I could see that being used at demo parties. Quote Link to comment Share on other sites More sharing options...
Daedalus2097 Posted October 13, 2021 Author Share Posted October 13, 2021 (edited) 8 hours ago, shoestring said: There's a potentiometer near the Gotek, that must be for the RGB lighting adjustment. It's actually a rotary encoder for the Gotek, so you can easily scroll through the entries, selecting by pushing on the shaft. Works well, but with the keyboard shortcuts isn't really necessary. Adjusting the lighting is done through the software, which looks like this: Edited October 13, 2021 by Daedalus2097 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 13, 2021 Share Posted October 13, 2021 @Daedalus2097 +1 for MUI. Is that address in the Clock Port range? EDIT: Never mind, I see the ClockPort header labeled "HOST". Slick. Quote Link to comment Share on other sites More sharing options...
Daedalus2097 Posted October 18, 2021 Author Share Posted October 18, 2021 Yep, the clockport address space is mirrored across 4 ranges starting at $D80001, $D84001, $D88001 and $D8C001. A directly connected device normally sits at $D80001, but most drivers will check all 4 addresses, so they can be used with clockport splitters. The Solas board internally responds at $D8C001, which allows the lower three (including the original address) to be used for other clockport devices at the same time. Quote Link to comment Share on other sites More sharing options...
