+Bruce-Robert Pocock Posted October 9, 2021 Share Posted October 9, 2021 Yes, I spelled that right. This is something I've toyed around with alongside Grizzards, which is progressing itself. Real life work has had me a little bogged down so I don't really have much to show for it, but in honor of yesterday's release from Nintendo I wanted to whet folks' appetites. There are two things that I find technically interesting about Meteoroid compared to Grizzards. One is that I'm using the SC RAM (128 bytes extra) for a buffer for the screen bitmap, allowing things like destroying blocks and the like. As you might guess, the screen is a 40×12 block layout, although the map stores columns at 1⁄4 that resolution horizontally. The other is that I'm toying with supporting "cloud saves" using a PlusCart (in addition to allowing SaveKey/AtariVox saves) as an option. You probably won't see much more of this until Grizzards is fully in Beta, but this clip shows off the player obtaining two different power-ups, encountering an enemy, opening a door, and then the scroll-into-next-room code kinda crashing as it reads garbage memory. And yes, that weird jumping effect actually happens right before the door opening routine. It's super buggy and not really playable in its current form, but maybe it'll be out in time for Meteoroid.mpeg Prime 4 at least. 5 Quote Link to comment Share on other sites More sharing options...
+Yurkie Posted October 27, 2021 Share Posted October 27, 2021 On 10/9/2021 at 3:40 PM, brpocock@star-hope.org said: Meteoroid.mpeg 54.32 MB · 39 downloads Looks pretty sweet! Thanks for sharing. Looking forward to seeing more. Quote Link to comment Share on other sites More sharing options...
+Bruce-Robert Pocock Posted November 15, 2021 Author Share Posted November 15, 2021 On 10/27/2021 at 5:14 AM, Yurkie said: Looks pretty sweet! Thanks for sharing. Looking forward to seeing more. Thanks! Just finally got a break from the mad projects at work so I can finish up Grizzards though, so it'll be a minute before I get back to this. Quote Link to comment Share on other sites More sharing options...
