  • 0
Any way to "ignore" whole subforums, not just threads?
youxia
Question
1 answer to this question
  • 1
It seems that you can set up your own stream, select Topics and then click which subforums you want to follow. It is a bit of work. You can edit your stream by changing settings afterwards. It might be an alternative if you can't filter out entire forum sections.
Edit: Ok, you need to select all levels of subforums - i.e. only Atari 2600 will not give you topics in the programming subforum unless you specifically add it to your stream.
Edited by carlsson
Answer this question...
