Pucrunch
AlanD
Ok I need some help. I found a really good compression routine for the C64. The compressor is on the PC and the decompressor is in ASM for C64. It looks very feasible to use this but I have been trying to set it up and it'll only decompress about 4 bytes until it goes stupid and starts spewing garbage I'm not sure where I am going wrong here.
Can anyone that is better at ASM than I am take a quick look at this program and see what they think? I talked to the original programmer so I know it does need to run out of RAM since it self-modifies. I would be glad to chat on the developers board about it and see what we can work out on it.
The address for the program is Pucrunch. Also the designer said I was trying to do something similar to what he did with his Vimm demo in the Vicpic part. Address for info on this is Vimm.
This is a major stumbling block for me and the further progress of Adventure 2. I have spent a week fighting with this. I would post the code I was using but it would be nasty spaghetti code because the original program is DASM and I use TASM and I put a lot of it in as .byte includes so would be useless for error detecting. At this point it would be better to get a fresh start and some help. Thanks again,
AlanD
The assembler code looks very straight forward and there are only a few places where selfmodifying code is used. In most cases, changing the code into indirect access would solve the problem without to much performance loss.
Example:
code:
INPOS = *+1
lda $aaaa
change into
code:
INPOS .word
ldy #0
lda (INPOS),y
And perhaps you have to save and restore Y.
[ 03-11-2002: Message edited by: Thomas Jentzsch ]
The code seemed to compile without a problem and the run from RAM was fine. Where I hit problems was when I tried to decompress a screen. There were 4 bytes that uncompressed fine then the last two should have been repeated say 10 times. At that point it just spit out garbage. I think there is an error somewhere in the LZW decompression routine but I can't find it unfortunately. Not sure where it went wrong.
Also it seems the first two bytes of the header of the compressed file are never read off anywhere. Not sure why they are there either. I would really love to get this working since out of two screens I compressed I ended up averaging about 20% of original file size which is better than I hoped for.
AlanD
Ok I finally managed to find a few errors so it tries a little more but still only gets 4 bytes into the decompression and screws up. I can post more if needed. Just tell me what you need. I found a few errors such as every #$00 in the original file compiled as a #$20 which is simply an issue with me and DASM as I think that is where the error occured. The other error was in my copy routine when I move it to RAM at $1500. I was rolling my loop wrong and was missing $15FF. I fixed that. I did a byte for byte compare and now $1500 is storing exactly what is stored in the ROM at $b000 ($7000 in this disassemly as it doesn't accout for the beginning of the ROM being at $4000). Any help you guys can offer would be greatly appreciated,
Alan
code:
ORG $1500
; Call with X = HI of packed data, Y = LO of packed data
; Returns exec address in X = HI and Y = LO
; Carry will be set for error, cleared for OK
decompress
sty INPOS ; Setup read pointer
stx INPOS+1
jsr getbyt ; 'p'
jsr getbyt ; 'u'
jsr getbyt ; skip endAddr
jsr getbyt
jsr getbyt
sta esc+1 ; starting escape
jsr getbyt ; read startAddr
sta OUTPOS
jsr getbyt
sta OUTPOS+1
jsr getbyt ; read # of escape bits
sta escB0+1
sta escB1+1
lda #8
sec
sbc escB1+1
sta noesc+1 ; 8-escBits
jsr getbyt
sta mg+1 ; maxGamma + 1
lda #9
sec
sbc mg+1 ; 8 - maxGamma == (8 + 1) - (maxGamma + 1)
sta longrle+1
jsr getbyt
sta mg1+1 ; (1<
asl
clc
sbc #0
sta mg21+1 ; (2<
jsr getbyt
sta elzpb+1
jsr getbyt ; exec address
sta lo+1 ; lo
jsr getbyt
sta hi+1 ; hi
jsr getbyt ; rleUsed
ldx #0
tay
t1 beq t2 ; Y == 0 ?
jsr getbyt
sta rletabl,x
inx
dey
bne t1
t2 lda #$80 ; setup bit store - $80 means empty
sta bitstr+1
jmp main
getbyt jsr getnew
bitstr lda #0
ror
rts
newesc ldy esc+1 ; remember the old code (top bits for escaped byte)
escB0 ldx #2 ; ** PARAMETER 0..8
jsr getchkf ; get & save the new escape code
sta esc+1
tya ; pre-set the bits
; Fall through and get the rest of the bits.
noesc ldx #6 ; ** PARAMETER 8..0
jsr getchkf
jsr putch ; output the escaped/normal byte
; Fall through and check the escape bits again
main ldy #0 ; Reset to a defined state
tya ; A = 0
escB1 ldx #2 ; ** PARAMETER 0..8
jsr getchkf ; X = 0
esc cmp #0
bne noesc
; Fall through to packed code
jsr getval ; X = 0
sta LZPOS+1 ; xstore - save the length for a later time
lsr ; cmp #1 ; LEN == 2 ? (A is never 0)
bne lz77 ; LEN != 2 -> LZ77
;tya ; A = 0
jsr get1bit ; X = 0
lsr ; bit -> C, A = 0
bcc lz77_2 ; A=0 -> LZPOS+1
;***FALL THRU***
; e..e01
jsr get1bit ; X = 0
bcc newesc ; e..e010
;***FALL THRU***
; e..e011
srle iny ; Y is 1 bigger than MSB loops
jsr getval ; Y is 1, get len, X = 0
sta LZPOS+1 ; xstore - Save length LSB
mg1 cmp #64 ; ** PARAMETER 63-64 -> C clear, 64-64 -> C set..
bcc chrcode ; short RLE, get bytecode
longrle ldx #2 ; ** PARAMETER 111111xxxxxx
jsr getbits ; get 3/2/1 more bits to get a full byte, X = 0
jsr getval ; length MSB, X = 0
tay ; Y is 1 bigger than MSB loops
chrcode jsr getval ; Byte Code, X = 0
tax ; this is executed most of the time anyway
lda rletabl-1,x ; Saves one jump if done here (loses one txa)
cpx #32 ; 31-32 -> C clear, 32-32 -> C set..
bcc t3 ; 1..31, we got the right byte from the table
; Ranks 32..64 (11111°xxxxx), get byte..
txa ; get back the value (5 valid bits)
ldx #3
jsr getbits ; get 3 more bits to get a full byte, X = 0
t3 ldx LZPOS+1 ; xstore - get length LSB
inx ; adjust for cpx#$ff;bne -> bne
dorle jsr putch
dex
bne dorle ; xstore 0..255 -> 1..256
dey
bne dorle ; Y was 1 bigger than wanted originally
mainbeq beq main ; reverse condition -> jump always
lz77 jsr getval ; X = 0
mg21 cmp #127 ; ** PARAMETER Clears carry (is maximum value)
bne noeof
; EOF
hi ldx #0
lo ldy #0
rts
noeof sbc #0 ; C is clear -> subtract 1 (1..126 -> 0..125)
elzpb ldx #0 ; ** PARAMETER (more bits to get)
jsr getchkf ; clears Carry, X = 0
lz77_2 sta LZPOS+2 ; offset MSB
jsr getbyte ; clears Carry, X = 0
; Note: Already eor:ed in the compressor..
;eor #255 ; offset LSB 2's complement -1 (i.e. -X = ~X+1)
adc OUTPOS ; -offset -1 + curpos (C is clear)
ldx LZPOS+1 ; xstore = LZLEN (read before it's overwritten)
sta LZPOS+1
lda OUTPOS+1
sbc LZPOS+2 ; takes C into account
sta LZPOS+2 ; copy X+1 number of chars from LZPOS to OUTPOS
;ldy #0 ; Y was 0 originally, we don't change it
lzloop
LZPOS lda $aaaa,y
jsr putch ; Note: must be copied forwards!
iny ; Y does not wrap because X=0..255 and Y initially 0
dex
bne lzloop ; X loops, (256,1..255)
beq mainbeq ; jump through another beq (-1 byte, +3 cycles)
getnew pha ; 1 Byte/3 cycles
INPOS = *+1
lda $aaaa ; ** PARAMETER
inc INPOS
bne t4
inc INPOS+1
t4 sec
rol ; Shift out the next bit and
; shift in C=1 (last bit marker)
sta bitstr+1 ; bitstr initial value = $80 == empty
pla ; 1 Byte/4 cycles
rts
; 25+12 = 37
; getval : Gets a 'static huffman coded' value
; ** Scratches X, returns the value in A **
getval inx ; X <- 1
txa ; set the top bit (value is 1..255)
gv0 asl bitstr+1
bne t5
jsr getnew
t5 bcc getchk ; got 0-bit
inx
mg cpx #7 ; ** PARAMETER unary code maximum length + 1
bne gv0
beq getchk ; inverse condition -> jump always
; getval: 18 bytes
; 15 + 17*n + 6+15*n+12 + 36*n/8 = 33 + 32*n + 36*n/8 cycles
; getbits: Gets X bits from the stream
getbyte ldx #7
get1bit inx ;2
getbits asl bitstr+1
bne t6
jsr getnew
t6 rol ;2
getchk dex ;2 more bits to get ?
getchkf bne getbits ;2/3
clc ;2 return carry cleared
rts ;6+6
OUTPOS = *+1 ; ZP
putch sta $aaaa ; ** parameter
inc OUTPOS ; ZP
bne t7
inc OUTPOS+1 ; ZP
t7 rts
rletabl .byte 0,0,0,0,0,0,0
.byte 0,0,0,0,0,0,0,0
here is the disassembly of what ended up in my 5200 bin.
code:
00007000:	8C2B16	STY $162B
00007003: 8E2C16 STX $162C
00007006: 207E15 JSR $157E
00007009: 207E15 JSR $157E
0000700C: 207E15 JSR $157E
0000700F: 207E15 JSR $157E
00007012: 207E15 JSR $157E
00007015: 8DA215 STA $15A2
00007018: 207E15 JSR $157E
0000701B: 8D6116 STA $1661
0000701E: 207E15 JSR $157E
00007021: 8D6216 STA $1662
00007024: 207E15 JSR $157E
00007027: 8D8915 STA $1589
0000702A: 8D9D15 STA $159D
0000702D: A908 LDA #$08
0000702F: 38 SEC
00007030: ED9D15 SBC $159D
00007033: 8D9215 STA $1592
00007036: 207E15 JSR $157E
00007039: 8D4A16 STA $164A
0000703C: A909 LDA #$09
0000703E: 38 SEC
0000703F: ED4A16 SBC $164A
00007042: 8DC615 STA $15C6
00007045: 207E15 JSR $157E
00007048: 8DC215 STA $15C2
0000704B: 0A ASL A
0000704C: 18 CLC
0000704D: E900 SBC #$00
0000704F: 8DF515 STA $15F5
00007052: 207E15 JSR $157E
00007055: 8D2016 STA $1620
00007058: 207E15 JSR $157E
0000705B: 8DFB15 STA $15FB
0000705E: 207E15 JSR $157E
00007061: 8DF915 STA $15F9
00007064: 207E15 JSR $157E
00007067: A200 LDX #$00
00007069: A8 TAY
0000706A: F00A BEQ $0A
0000706C: 207E15 JSR $157E
0000706F: 9D6C16 STA $166C,X
00007072: E8 INX
00007073: 88 DEY
00007074: D0F4 BNE $F4
00007076: A980 LDA #$80
00007078: 8D8215 STA $1582
0000707B: 4C9915 JMP $1599
0000707E: 202916 JSR $1629
00007081: A900 LDA #$00
00007083: 6A ROR A
00007084: 60 RTS
00007085: ACA215 LDY $15A2
00007088: A202 LDX #$02
0000708A: 205C16 JSR $165C
0000708D: 8DA215 STA $15A2
00007090: 98 TYA
00007091: A206 LDX #$06
00007093: 205C16 JSR $165C
00007096: 206016 JSR $1660
00007099: A000 LDY #$00
0000709B: 98 TYA
0000709C: A202 LDX #$02
0000709E: 205C16 JSR $165C
000070A1: C900 CMP #$00
000070A3: D0EC BNE $EC
000070A5: 203C16 JSR $163C
000070A8: 8D1E16 STA $161E
000070AB: 4A LSR A
000070AC: D043 BNE $43
000070AE: 205116 JSR $1651
000070B1: 4A LSR A
000070B2: 9050 BCC $50
000070B4: 205116 JSR $1651
000070B7: 4A LSR A
000070B8: 90CB BCC $CB
000070BA: C8 INY
000070BB: 203C16 JSR $163C
000070BE: 8D1E16 STA $161E
000070C1: C940 CMP #$40
000070C3: 900C BCC $0C
000070C5: A202 LDX #$02
000070C7: 205216 JSR $1652
000070CA: 8D1E16 STA $161E
000070CD: 203C16 JSR $163C
000070D0: A8 TAY
000070D1: 203C16 JSR $163C
000070D4: AA TAX
000070D5: BD6B16 LDA $166B,X
000070D8: E020 CPX #$20
000070DA: 9006 BCC $06
000070DC: 8A TXA
000070DD: A203 LDX #$03
000070DF: 205216 JSR $1652
000070E2: AE1E16 LDX $161E
000070E5: E8 INX
000070E6: 206016 JSR $1660
000070E9: CA DEX
000070EA: D0FA BNE $FA
000070EC: 88 DEY
000070ED: D0F7 BNE $F7
000070EF: F0A8 BEQ $A8
000070F1: 203C16 JSR $163C
000070F4: C97F CMP #$7F
000070F6: D005 BNE $05
000070F8: A200 LDX #$00
000070FA: A000 LDY #$00
000070FC: 60 RTS
000070FD: E900 SBC #$00
000070FF: A200 LDX #$00
00007101: 205C16 JSR $165C
00007104: 8D1F16 STA $161F
00007107: 204F16 JSR $164F
0000710A: 6D6116 ADC $1661
0000710D: AE1E16 LDX $161E
00007110: 8D1E16 STA $161E
00007113: AD6216 LDA $1662
00007116: ED1F16 SBC $161F
00007119: 8D1F16 STA $161F
0000711C: E8 INX
0000711D: B9AAAA LDA $AAAA,Y
00007120: 206016 JSR $1660
00007123: C8 INY
00007124: CA DEX
00007125: D0F6 BNE $F6
00007127: F0C6 BEQ $C6
00007129: 48 PHA
0000712A: ADAAAA LDA $AAAA
0000712D: EE2B16 INC $162B
00007130: D003 BNE $03
00007132: EE2C16 INC $162C
00007135: 38 SEC
00007136: 2A ROL A
00007137: 8D8215 STA $1582
0000713A: 68 PLA
0000713B: 60 RTS
0000713C: E8 INX
0000713D: 8A TXA
0000713E: 0E8215 ASL $1582
00007141: D003 BNE $03
00007143: 202916 JSR $1629
00007146: 9013 BCC $13
00007148: E8 INX
00007149: E007 CPX #$07
0000714B: D0F1 BNE $F1
0000714D: F00C BEQ $0C
0000714F: A207 LDX #$07
00007151: E8 INX
00007152: 0E8215 ASL $1582
00007155: D003 BNE $03
00007157: 202916 JSR $1629
0000715A: 2A ROL A
0000715B: CA DEX
0000715C: D0F4 BNE $F4
0000715E: 18 CLC
0000715F: 60 RTS
00007160: 8DAAAA STA $AAAA
00007163: EE6116 INC $1661
00007166: D003 BNE $03
00007168: EE6216 INC $1662
0000716B: 60 RTS
0000716C: 00 BRK
0000716D: 00 BRK
0000716E: 00 BRK
0000716F: 00 BRK
00007170: 00 BRK
00's continue on for another 36 bytes or so
Grrrr Can anyone confirm that some of my jump addresses or self-modifying addresses are off? I'm going thru it line by line now
code:
00007123: C8 INY
00007124: CA DEX
That area when I disassemble memory in the 5200 after a partial run when it crashes is showing up as:
code:
B9 02 10 LDA $1002,Y ;looks ok as my screen is $1000
00 BRK ;huh?
60 RTS
16 C8 ASL $C8,X
CA DEX
well you can see that is quite a bit different. Seems something is modifying $1620 which is where that break appeared. Now just to figure out where and why. I think there were some mild problem when I did the assembly which are coming to haunt me Not sure where I went wrong tho.
AlanD
Ok that $1620 being modified was the problem. All fixed now. It seems somehow that when my code was put into the source a bunch of the $00 changed to $20. Can you guess that it was supposed to be $1600 being modified and not $1620? Seems I missed one of the screwups. All fixed except it isn't loading in the colors and that is just a modification I need to do from when I began the changeover to compression. Thanks for everyone's help!
Alan
  • 1 month later...
  • 19 years later...
Did you ever get this to work (18 years ago!)? I tried the code you posted here and didn't get very far. It compiles but crashes. I'm including a binary file that I compressed with pucrunch (-d -c0) and trying to pass in the address in X/Y but it hangs. If you have working source you could share I'd much appreciate it --- just starting to learn my way around a8/6502
