25 minutes ago, Kaj de Vos said:
Those are advanced features. I use them only to accomplish specific goals for Meta. I will certainly not offer all those options for Meta. Usually, they can be much simplified when you take a step back and consider what it is that you want to accomplish.
I agree, it's nothing that needs to be done early in the language development. I listed the cases just a reminded what everything may be needed to cover in the future - may be useful when designing the low-level part of the language addressing the 8bit Atari needs. Often these needs cannot be simplified because of how the old hardware or OSes are designed.
@Kaj de Vos - do you have already arrays/series implemented in Meta? If not, how do you plan to approach this topic? Are they going to be dynamic/expandable like in REBOL or fixed size? From REBOL documentation:
REBOL uses the concept of expandable SERIES for holding and manipulating data, rather than the concept of fixed size arrays. For example, in REBOL you would normally write:
    block: copy []
    repeat n 5 [append block n]
rather than:
    block: array 5
    repeat n 5 [poke block n n]
In other words, REBOL does not require you to specify the size of data arrays (blocks, bytes, or strings) in advance. They are dynamic.
I have tried to compile following - are they already implemented?
    flags: array size - Script error: "array" has no value
    flags: copy [] - Script error: "copy" does not work on parameter type: expressions list block!
13 minutes ago, ilmenit said:
Script error: "WORD" has no value
means that WORD is undefined. So, not implemented.
14 minutes ago, ilmenit said:
Script error: "METHOD" does not work on parameter type
means that METHOD is defined, but on other parameter types than you gave it.
Both, but expandable is a dynamic feature, so that will come later:
https://language.metaproject.frl/#state
The current support is quite close to REBOL, but static, and only byte arrays and simple strings so far:
array= make static binary! 10
Thanks, how to make an memset of the array? Neither change nor head, forall seem to be implemented yet (no value) - is there some implemented way of setting an array value? Trying something like this:
    sizepl: 8192
    flags:  make static binary! sizepl
    for i sizepl
        change at flags i 1
    flags: head flags
EDIT: ok, poke seems to work, will return with more testing ;-)
Edited by ilmenit
2 minutes ago, Kaj de Vos said:
Meta has let-word!s for constants in addition to set-word!s, so to define the array as static, you need:
sizepl=
flags=
change at is very inefficient at that, that would be poke.
head is at-head in Meta.
thanks, what about pick? Not implemented yet? I also tried at-pick and pick-at.
3 minutes ago, Kaj de Vos said:
What does the compiler tell you?
Script error: "pick" does not work on types combination
Here is the code I'm trying to compile:
iter: 1
sizepl: 8192 ; becase with "sizepl= 8192" this "for i sizepl" does not compile
size= 8190
while [ iter <= 10 ]
    count: 0
	i: 0
	flags= make static binary! sizepl
	for i sizepl
        poke flags i 1
    flags: at-head flags
    while [ i <= size ]
        p: pick flags i
        if p = 1
		    prime: (i*2) + 3
            k: i + prime
            while [ k <= size ]
                poke flags k 0
                k: k + prime
			count: count + 1
		i: i + 1
    iter: iter + 1
3 hours ago, Kaj de Vos said:
So pick is implemented, but you left out what type combination it doesn't support.
it doesn't work neither for flags= make static binary! sizepl nor flags: make static binary! sizepl
** Script error: "pick" does not work on types combination:
Parameter types:
1: static-binary! [flags i
    if p = 1
2: integer! [i
    if p = 1
At: [pick flags i
    if p = 1
        prime: (i*2) + 3...
In: [
    p: pick flags i
    if p = 1
        prime: (...
Near: [
    while [i <= size]
        p: pick flags i
also when I set:
sizepl= 8192
then
** Script error: "for" does not work on types combination:
Parameter types:
1: integer! reference [i sizepl
2: natural16! [sizepl
3: literal block! [
        poke f...
At: [
    for i sizepl
        poke flags i 1
In: [
    count: 0
    i: 0
    flags= make static binary! si...
Near: [
    while [iter <= 10]
        count: 0
        i...
4 minutes ago, Kaj de Vos said:
I deployed a new compiler to the server. Should be implemented now.
Thanks, I'm getting closer to the end of compilation issues. Now for the code:
iter: 1
sizepl= 8192
size= 8190
    count: 0
    i: 0
    for i sizepl
        poke flags i 1
    i: 0
    while [ i <= size ]
        p: pick flags i
        if p = 1
            prime: ( i * 2 ) + 3
            k: i + prime
            while [ k <= size ]
                poke flags k 0
                k: k + prime
            count: count + 1
        i: i + 1
    iter: iter + 1
I receive the following output and error:
code: [none while
    [/block! compile/block
        [logic! is-lesser-or-equal
            [integer! compile/value [global! k]]
            [natural16! compile/value [global! size]]
        [byte! poke
            [/static-binary! compile/reference [global! flags]]
            [byte! 0]
        [integer16! set
            [:integer! compile/reference [global! k]]
            [integer16! add
                [integer! compile/value [global! prime]]
** Script error: "while" does not work on types combination:
Parameter types:
1: expressions list block! [[k <= size]
2: expressions list block! [
        poke f...
At: [
    while [k <= size]
        poke flags k 0
In: [
    prime: (i * 2) + 3
    k: i + prime
    while [k <=...
Near: [
    if p = 1
        prime: (i * 2) + 3
        k...
Ok, removed the block from the while but now again I'm getting the error in for:
iter: 1
sizepl= 8192
size= 8190
while iter <= 10
    count: 0
    i: 0
    for i sizepl
        poke flags i 1
    i: 0
    while i <= size
        p: pick flags i
        if p = 1
            k: prime + i
            while k <= size
                poke flags k 0
                k: k + prime
            count: count + 1
        i: i + 1
    iter: iter + 1
error:
** Script error: method "for" does not work on types combination:
Return value not used.
Parameter types:
3: statements sequence block! [
        poke f...
At: [
    for i sizepl
        poke flags i 1
In: [
    count: 0
    i: 0
Near: [
    while iter <= 10
        count: 0
        i: ...
19 minutes ago, Kaj de Vos said:
One step closer: on the back-end instead of the front-end. Updated again.
thanks, now there is another error in the same code:
** Script error: no known implicit method "is-equal" with 2 parameters.
At: [= 1
        prime: (i * 2) + 3
        k: prime + ...
In: [p = 1
        prime: (i * 2) + 3
        k: prime ...
Near: [
    if p = 1
        prime: (i * 2) + 3
        k...
1 minute ago, Kaj de Vos said:
Ah, changed that to EQUALS. You can use that as workaround (prefix). Laptop is empty now, more fixes tomorrow.
If I understand properly what do you mean by (prefix) I got the following error:
At: [EQUALS p 1
        prime: (i * 2) + 3
        k: p...
In: [
    if EQUALS p 1
        prime: (i * 2) + 3
Near: [
    p: pick flags i
    if EQUALS p 1
        pri...
