ALKO Posted November 2, 2021 Share Posted November 2, 2021 what was the reason for this? Did the TIA-chip break down? Quote Link to comment Share on other sites More sharing options...
+x=usr(1536) Posted November 3, 2021 Share Posted November 3, 2021 Check the colour pot first, especially if you've had the machine open recently. I've more than once knocked one out of whack while doing something else. Quote Link to comment Share on other sites More sharing options...
INTVCruise Posted November 3, 2021 Share Posted November 3, 2021 8 hours ago, ALKO said: what was the reason for this? Did the TIA-chip break down? Did you try moving the black and white switch back and forth alot of times to try and clean it? If it's dirty if might display in b and w until it gets cleaned. Quote Link to comment Share on other sites More sharing options...
+Stephen Moss Posted November 3, 2021 Share Posted November 3, 2021 You could try retuning the TV, if something has created a slight change in the the RF frequency it may just be enough to put it a little out of tune. Quote Link to comment Share on other sites More sharing options...
ALKO Posted November 3, 2021 Author Share Posted November 3, 2021 9 hours ago, Stephen Moss said: change in the the RF frequency this is AV mod Quote Link to comment Share on other sites More sharing options...
ALKO Posted November 3, 2021 Author Share Posted November 3, 2021 (edited) 15 hours ago, INTVCruise said: Did you try moving the black and white switch back and forth alot of times to try and clean it? If it's dirty if might display in b and w until it gets cleaned. Contact is normal Edited November 3, 2021 by ALKO Quote Link to comment Share on other sites More sharing options...
Dopy25 Posted November 3, 2021 Share Posted November 3, 2021 47 minutes ago, ALKO said: this is AV mod Depending on the AV mod, the color line may have broke free on the mod board. Quote Link to comment Share on other sites More sharing options...
ALKO Posted November 3, 2021 Author Share Posted November 3, 2021 45 minutes ago, Dopy25 said: Depending on the AV mod, the color line may have broke free on the mod board. I did it according to this scheme https://www.console-corner.de/videomod.html Quote Link to comment Share on other sites More sharing options...
ALKO Posted November 3, 2021 Author Share Posted November 3, 2021 RF-signal so bad. But he BW too BW-switcher just inverts some objects. Quote Link to comment Share on other sites More sharing options...
