Tursi Posted December 19, 2022 Share Posted December 19, 2022 Well, what does the debug log say? Quote Link to comment Share on other sites More sharing options...
.mad. Posted December 20, 2022 Share Posted December 20, 2022 i am more player than coder. ;) Quote Link to comment Share on other sites More sharing options...
Asmusr Posted December 20, 2022 Share Posted December 20, 2022 18 hours ago, Tursi said: "N|7000|10000|filename" should get you there It should be 1000 instead of 10000. Quote Link to comment Share on other sites More sharing options...
.mad. Posted December 20, 2022 Share Posted December 20, 2022 3 hours ago, Asmusr said: It should be 1000 instead of 10000. thanks, i did notice that error. it needs something else setting in the ini file or emulator when the GameBase option is used. no idea what though. Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 21, 2022 Share Posted December 21, 2022 Your screen capture doesn't include the ROM loading. Show me that. (Capture it after reset, before starting the game). We can see that DSK1.SNAKEBX is loaded successfully, and for some reason the CPU jumped to FFE0, which is not likely valid. I don't know what it /should/ look like, of course. Quote Link to comment Share on other sites More sharing options...
.mad. Posted December 21, 2022 Share Posted December 21, 2022 Thanks for your help! i can not resize the debug window to read all the info. not as if i could understand it anyway. i think it's best if i upload all the files i am using, for you to check on your side. copy the disk, minimem roms and classic.ini file to the same folder as classic99.exe run the emulator. it will autotype the load commands. see the crash. select minimem from the apps menu (resets emulator) select 1) BASIC type CALL FILES(0) OLD DSK1.SNAKEBX RUN see it work. classic99-snake.zip Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 21, 2022 Share Posted December 21, 2022 The problem is that you are loading 8k of ROM for the Minimemory, but there is actually only 4k. When you load ROM to a memory address, Classic99 flags that address as read-only, so loading 8k there flags the Minimemory's 4k of RAM as ROM, causing the crash. There's no need to include the NV file... NVRAM files in Classic99 don't define hardware, they just load and save data. (So, if the Snake game saves high scores or something, you can include it, but SNAKEBX reloads the memory from disk at startup, so it's probably unneeded.) You also have a blank ROM definition. I'm surprised it works, but I guess it's fine. Anyway, change the length of the MiniMemory ROM file to 4k and it works: [usercart0] rom0="C|6000|1000|MiniMemC.Bin" rom1="G|6000|2000|MiniMemG.Bin" rom2="K|0000|0000|xX1CALL FILES(0)\nOLD DSK1.SNAKEBX\nRUN\n" name=Gamebase 3 1 Quote Link to comment Share on other sites More sharing options...
.mad. Posted December 22, 2022 Share Posted December 22, 2022 Thanks! i thought the 2nd value had to be the total size of the rom file. the nvram value is still good to know, and can be included and re-saved when changed in any of the game zips that need it. i only use rom 4 for the sendkeys and leave 2 and 3 blank because the emulator alows it. it makes it easier for a global script setting. 👍 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 22, 2022 Share Posted December 22, 2022 11 hours ago, .mad. said: Thanks! i thought the 2nd value had to be the total size of the rom file. the nvram value is still good to know, and can be included and re-saved when changed in any of the game zips that need it. It does, but your ROM file is overdumped. The MiniMemory only has 4k of ROM. 2 Quote Link to comment Share on other sites More sharing options...
.mad. Posted December 23, 2022 Share Posted December 23, 2022 14 hours ago, Tursi said: It does, but your ROM file is overdumped. The MiniMemory only has 4k of ROM. I am using your overdumped rom... https://github.com/tursilion/classic99/tree/main/cartpack/roms i did notice a problem with the NVRAM file in the cartpack.dll. you have to select re-initialize to get anything to load with mm2dsk (Magic Places game). it just gives out of memory errors. i copied the data from this re-initialized file into the cartpack.dll and it works first time. re-initialized-NVRAM.bin 1 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 23, 2022 Share Posted December 23, 2022 8 hours ago, .mad. said: I am using your overdumped rom... https://github.com/tursilion/classic99/tree/main/cartpack/roms Maybe, but I load it properly. FWIW, don't call out that you are using my ROMs in other projects - I've specifically stated in the past that I don't appreciate that. Someone once published a for-real print book telling people to download my emulator and throw away everything but the ROM files (without bothering to tell me!), and I've never stopped being bitter about that. Classic99 is not a reference library. 8 hours ago, .mad. said: i did notice a problem with the NVRAM file in the cartpack.dll. you have to select re-initialize to get anything to load with mm2dsk (Magic Places game). it just gives out of memory errors. By default the NVRAM file in the distribution has the LINES and Line-By-Line assembler programs loaded. So yeah, you need to delete them to load something else. But again, unless there's something you need to provide pre-loaded, don't bother including an NVRAM file. The memory will be zeroed and unless your gamebase title saves something there for next time, there's no value to making it non-volatile. 3 Quote Link to comment Share on other sites More sharing options...
.mad. Posted December 24, 2022 Share Posted December 24, 2022 12 hours ago, Tursi said: Someone once published a for-real print book telling people to download my emulator and throw away everything but the ROM files It just goes to show, you can't believe everything you read. Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted December 24, 2022 Share Posted December 24, 2022 17 hours ago, Tursi said: Someone once published a for-real print book telling people to download my emulator and throw away everything but the ROM files 🚮 Sorry, just kidding! I've been pulling good stuff out of the garbage since I was about 7.💎 P.S. Once, while still a young man, I found a copy of Debbie-Does-Dallas(near Canal street). So, pretty good timing!!! Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 25, 2022 Share Posted December 25, 2022 Well, that was back when I paid for bandwidth, so I was a little ticked. I did buy the book and even scanned the page: Then I removed all ROMs from my download zip for the next several years. Next time ask first. 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted December 26, 2022 Share Posted December 26, 2022 3 hours ago, Tursi said: Well, that was back when I paid for bandwidth, so I was a little ticked Bandwidth notwithstanding, the book's suggestion is a total dick-head move. There are plenty of places to obtaib illicit ROMs for the TI, one of which should not include licensed work. Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 26, 2022 Share Posted December 26, 2022 1 hour ago, OLD CS1 said: Bandwidth notwithstanding, the book's suggestion is a total dick-head move. There are plenty of places to obtaib illicit ROMs for the TI, one of which should not include licensed work. That was an official O'Reilly book, too. I can't remember if I wrote them a sternly worded letter, I meant to. Quote Link to comment Share on other sites More sharing options...
.mad. Posted December 26, 2022 Share Posted December 26, 2022 "Retro Gaming Hacks" surly that's false advertising or something. 🤪 Quote Link to comment Share on other sites More sharing options...
