+acadiel Posted November 14, 2021 Share Posted November 14, 2021 I'm going to throw this up on Archive.org too, but thought that this stuff should be out there for everyone who's looked for it. This is a good little programmer, but you have to put a chip in with the configuration for the EPROM that you want to program. The documentation below has the pinout if yours is missing all the config chips. Prolink_DOS.zip prolink2.pdf RJ114C to DB-9F.pdf shooter-data.pdf shooter-init-test.pdf shooter-service.pdf userguide-shooter.pdf 3 Quote Link to comment Share on other sites More sharing options...
Rob Mitchell Posted May 17, 2022 Share Posted May 17, 2022 Thanks for all the info. I printed out everything. I was just given one of these so hopefully I can get it to work. 1 Quote Link to comment Share on other sites More sharing options...
+acadiel Posted May 22, 2022 Author Share Posted May 22, 2022 Thanks for all the info. I printed out everything. I was just given one of these so hopefully I can get it to work.Yep, you got it from me Quote Link to comment Share on other sites More sharing options...
