Frozone212 Posted November 15, 2021 Share Posted November 15, 2021 Clueless as to how to get the code to run Quote Link to comment Share on other sites More sharing options...
Gray Defender Posted November 15, 2021 Share Posted November 15, 2021 Merlin 64 or 128? I did a quick video covering Merlin 64 a while back.. 1 Quote Link to comment Share on other sites More sharing options...
Frozone212 Posted November 15, 2021 Author Share Posted November 15, 2021 64 Quote Link to comment Share on other sites More sharing options...
+sm3 Posted November 16, 2021 Share Posted November 16, 2021 20 hours ago, Frozone212 said: Clueless as to how to get the code to run load "merlin",8 Then type run Quote Link to comment Share on other sites More sharing options...
Frozone212 Posted November 16, 2021 Author Share Posted November 16, 2021 i meant the code that's saved in the assembler. After i leave edit mode. I save it as source, but how do i run it so that it shows up onscreen Quote Link to comment Share on other sites More sharing options...
+sm3 Posted November 16, 2021 Share Posted November 16, 2021 16 minutes ago, Frozone212 said: i meant the code that's saved in the assembler. After i leave edit mode. I save it as source, but how do i run it so that it shows up onscreen Oh, there's several ways to do it, but assuming you've assembled the source and saved the object code (something.o) file from Merlin you then: load "something.o",8,1 Then if you didn't have an ORG statement in your code (it defaults to $8000) you would type: sys 32768 Quote Link to comment Share on other sites More sharing options...
Frozone212 Posted November 16, 2021 Author Share Posted November 16, 2021 when i go to save the object code, the screen blurs, jumps and i'm still on the main menu Quote Link to comment Share on other sites More sharing options...
+sm3 Posted November 16, 2021 Share Posted November 16, 2021 42 minutes ago, Frozone212 said: when i go to save the object code, the screen blurs, jumps and i'm still on the main menu OK not sure exactly what you’re doing, but you have to save the object code after a successful assembly. So start over, load the source, assemble the source, if successful, save the object code. Quote Link to comment Share on other sites More sharing options...
Frozone212 Posted November 17, 2021 Author Share Posted November 17, 2021 (edited) figured it out, stupid me Edited November 17, 2021 by Frozone212 forgot to rtfm Quote Link to comment Share on other sites More sharing options...
carlsson Posted November 18, 2021 Share Posted November 18, 2021 I applaud you for your determination. I would probably not have ten seconds worth of patience and attention to learn to use a such tool. Then again I already have my cross assembling environments set up so I don't feel any need to use something like that . 1 Quote Link to comment Share on other sites More sharing options...
Frozone212 Posted November 18, 2021 Author Share Posted November 18, 2021 (edited) yup, I will get to grips with 6502 and nothing's going to stop me...except maybe sleep lol...and my kitten bubbles Edited November 18, 2021 by Frozone212 additional Quote Link to comment Share on other sites More sharing options...
