KevKelley Posted November 22, 2021 Share Posted November 22, 2021 I was curious. With on...goto statements, do they only work in instances where a variable is defined in steps, like x=x+1 or would it work with rand so when x equals a number it would go to that particular one? I haven't tried it out yet but when I get a chance I eabt s to see if it would work. Quote Link to comment https://forums.atariage.com/topic/327472-on-goto-and-rand/ Share on other sites More sharing options...
+Random Terrain Posted November 22, 2021 Share Posted November 22, 2021 on _Walk_Up goto __P0U0 __P0U1 __P0U2 __P0U3 The variable alias _Walk_Up used in the example above can safely have a value from 0 to 3 and that value can be in any order. The value of _Walk_Up could be 3, then 0, then 1, then 0 again. The value doesn't have to be from 0 to 3 in order, but you'll probably end up increasing the value by 1 when using on…goto for displaying sprite animation frames. 1 Quote Link to comment https://forums.atariage.com/topic/327472-on-goto-and-rand/#findComment-4952330 Share on other sites More sharing options...
KevKelley Posted November 22, 2021 Author Share Posted November 22, 2021 3 hours ago, Random Terrain said: on _Walk_Up goto __P0U0 __P0U1 __P0U2 __P0U3 The variable alias _Walk_Up used in the example above can safely have a value from 0 to 3 and that value can be in any order. The value of _Walk_Up could be 3, then 0, then 1, then 0 again. The value doesn't have to be from 0 to 3 in order, but you'll probably end up increasing the value by 1 when using on…goto for displaying sprite animation frames. Thanks. I was a little confused when reading. I had a "power up" code I was working on and was looking at various options. I had done something like "if x <> 1 then goto NOT_1" and then had a series of those but I didn't know if I chose a number at random how it would work. Quote Link to comment https://forums.atariage.com/topic/327472-on-goto-and-rand/#findComment-4952506 Share on other sites More sharing options...
+Gemintronic Posted November 28, 2021 Share Posted November 28, 2021 This isn't directly related to your question but take note of R.T.s Too Many Labels section. When I make Adventure-like games loading new screens uses long on .. goto statements. It's easy to think there's other problems when you've actually just reached the limit of labels on a single on .. goto statement. 1 Quote Link to comment https://forums.atariage.com/topic/327472-on-goto-and-rand/#findComment-4956034 Share on other sites More sharing options...
KevKelley Posted November 28, 2021 Author Share Posted November 28, 2021 2 hours ago, Gemintronic said: This isn't directly related to your question but take note of R.T.s Too Many Labels section. When I make Adventure-like games loading new screens uses long on .. goto statements. It's easy to think there's other problems when you've actually just reached the limit of labels on a single on .. goto statement. I had made similar mistakes or forgotten things, like how many ANDs or ORs you can have in a statement so while my brain thinks it was a genius making some crafty code reality slapped my face and told me to redo! In regards to my original question, when I tried the code in a couple different ways they all worked well. I can't remember now what I went with (I think it was my initial attempt) but it was nice to experiment with different methods or things. This will definitely be helpful in the future. 1 Quote Link to comment https://forums.atariage.com/topic/327472-on-goto-and-rand/#findComment-4956071 Share on other sites More sharing options...
