RangerG Posted November 23, 2021 Share Posted November 23, 2021 I want to buy a few items from thefuturewas8bit and I'd like to add the Kung Fu cartridge. I love the label and build quality from TFW8, but I know NTSC mode on the Kung Fu cart is still experimental. However, the NTSC version seems to be updated and there has to be some user reviews - anyone? Thanks for the help. Take care, RG Quote Link to comment Share on other sites More sharing options...
str0m Posted November 23, 2021 Share Posted November 23, 2021 Can't help your question sorry, just posting as excited that I have ordered one as I recently got my first C64, I'm PAL though. Quote Link to comment Share on other sites More sharing options...
WaldoX Posted November 24, 2021 Share Posted November 24, 2021 Hello, I have been using a Kung Fu Flash with NTSC firmware on my NTSC breadbin for about 6 months now. Haven't updated the firmware since I got it, lols, probably should! Anyway, I love it! I don't have anything to compare it to, but my experience with Kung Fu has been great! I keep it plugged in and running Action Reply most of the time, also works great as Epyx Fast Load. I LOVE finding easyflash copies of games that I can run from Kung Fu rather than multiple floppies on my pi1541. I highly recommend! 1 Quote Link to comment Share on other sites More sharing options...
RangerG Posted November 28, 2021 Author Share Posted November 28, 2021 Thanks, this is what I want to use it for, so I appreciate the recommendation. Quote Link to comment Share on other sites More sharing options...
str0m Posted November 29, 2021 Share Posted November 29, 2021 Just got mine and still can't answer your query but just updating to say it is amazing! Games load so quick, love the reset and menu buttons, spent ages on Buggy Boy yesterday. The only thing doing my head in is how half the games use one joystick port for player1 and others use the other, I need a 2nd joystick/pad! (C64 issue nothing to do with the cart) Quote Link to comment Share on other sites More sharing options...
Gray Defender Posted December 3, 2021 Share Posted December 3, 2021 I just received my Ntsc cart and upgraded to latest firmware 1.30 ... I've noticed a few issues. It's not compatible with my c64c... No biggie. I hooked up a breadbin c64 and I noticed game saves do not work the ones I tried.. The new bagman release by Luca Carmonati and Neptune lander elite ... Also a few disk game don't load all the way up before crashing... I understand games with 2 disks are a problem but I cannot get to that point with disk 1 of below the root or with the Ultima 4 remastered. The cart games seem fine... I was wondering if I am an isolated case or if these are sort of known issues with the experimental ntsc disk version. Quote Link to comment Share on other sites More sharing options...
carlsson Posted December 3, 2021 Share Posted December 3, 2021 With the exception of some custom chips upgraded: 8580 instead of 6581, newer VIC-II revision, better PLA and possibly a different Kernel ROM regarding default text colours, what can be the difference between a breadbin C64 and a C64C with the newer, short motherboard? It sounds quite strange if a newly developed cartridge won't work on all models, unless of course your C64C has some fault that prevents other advanced cartridges from running. Quote Link to comment Share on other sites More sharing options...
str0m Posted December 3, 2021 Share Posted December 3, 2021 Mine works fine with my C64c, it is a PAL one but can't see how that would stop it at least loading up. Faulty/dirty port on the C64c itself? Try cleaning the contacts. Quote Link to comment Share on other sites More sharing options...
Gray Defender Posted December 3, 2021 Share Posted December 3, 2021 Thank you guys for your comments and suggestions! I think cleaning the pads is always a good suggestion, can't hurt. I went to try that however the cart port on the C64 is female, duh, and I am not sure how to clean in between those contacts? Any ideas? I did however clean the contacts on the Kung Fu cartridge itself and it was actually quite dirty, much more than I expected. I assume probably from the old dirty C64 breadbins I tried. out. I don't discount the possibility that there could be some issue with my C64c, but it works with all my other cartridges, including the 1541 Ultimate 2+. Unfortunately, I don't have another C64c to test the Kung Fu cart with. I recorded a quick video to demonstrate some of the issues I was having with the NTSC Kung Fu Cartridge: Quote Link to comment Share on other sites More sharing options...
youxia Posted December 3, 2021 Share Posted December 3, 2021 The thing about KFF is that its disk image compatibility is rather low. I've heard elsewhere it might be just around 40%. Quote Link to comment Share on other sites More sharing options...
Gray Defender Posted December 3, 2021 Share Posted December 3, 2021 Yeah I've heard that as well and I already knew you cannot as of yet, switch disks. Also the NTSC version, I believe I read is experimental...(looking it up...) I don't expect perfection and I am happy with the cartridge, especially knowing they are continuously working on firmware improvements. Initially this cartridge was PAL only and was updated to support NTSC. This excerpt may explain many of the issues I was demonstrating... KimJorgensen/KungFuFlash: Cartridge for the Commodore 64 that packs a punch (github.com) Limitations Kung Fu Flash is a so called Software Defined Cartridge where a fast microcontroller emulates cartridge hardware in software. This makes it extremely flexible, allowing different cartridge types to be supported at a relative low cost. However, it can be challenging to get the C64 bus timing correct in software and in some places the timing is very close to the limit. Even though Kung Fu Flash has been tested on different models of the Commodore 64, there is a chance that it doesn't work correctly on your specific model. Use it at your own risk! Kung Fu Flash will work with the PAL version of the Commodore 64 or Commodore 128. Support for the NTSC version is still considered experimental. Disk drive emulation is using kernal vectors and will not work with fast loaders or software that uses direct hardware access which a lot of games does. Currently REL files are not supported and there is only limited write support. Quote Link to comment Share on other sites More sharing options...
str0m Posted December 3, 2021 Share Posted December 3, 2021 Try this for cleaning 1 Quote Link to comment Share on other sites More sharing options...
str0m Posted December 3, 2021 Share Posted December 3, 2021 I've found .crt files work fine, not really tried many others as the C64(c) is new to me (+4 when growing up sigh, then Amiga), big pack if you go on youtube and search for "oneload64 v2", link in description, the .crt files in the root of this archive Quote Link to comment Share on other sites More sharing options...
Gray Defender Posted December 3, 2021 Share Posted December 3, 2021 20 minutes ago, str0m said: Try this for cleaning Brilliant... Thanks! Quote Link to comment Share on other sites More sharing options...
