Help me for the debuging in Visual Studio Code
Hello everyone, I'm learning bAtari Basic and for that I use the extension Atari Dev Studio on Visual Studio Code. However for the debbuging, I have this message:
You don’t have an extension for debugging “batari Basic”. Should we find a “batari Basic” extension in the marketplace ?
Can you help me please, or give any clarification ?
Edited by Eudoire
Do you have Atari Dev Studio, then? If so, then that is all you should need. There's not a special debugger for batari basic code. You can do debugging with Stella, on the ASM level.
Also looping in @mksmith in case he has anything more to add.
4 hours ago, Karl G said:
Vous avez alors Atari Dev Studio ? Si c'est le cas, c'est tout ce dont vous avez besoin. Il n'y a pas de débogueur spécial pour le code de base de batari. Vous pouvez faire du débogage avec Stella, au niveau ASM.
En boucle aussi @mksmith au cas où il aurait quelque chose à ajouter.
thank you very much for this information, it is not always easy for a beginner to know this information, I am more motivated to share my future game!
Thanks @Karl G.
Sorry @Eudoire I had a few other things on and no chance to visit the forum.  If you have Atari Dev Studio installed then that is quite a strange error message as VS Code does not appear to fully recognize it's installed.
There might be a couple of things to check:
  • try re-installing the extension and try to compile again
  • verify any anti-virus is not blocking access to the compiler
  • open the VS Code Debugger (Help -> Toggle Developer Tools) - it will open a Chrome Web Developer tools. Then try to compile again and you will see the full debugging messages in that window.
