WicoKid Posted November 24, 2021 Share Posted November 24, 2021 Trying to get an Atari 7800 in working order. It fairly frequently boots to Atari 2600 games but is inconsistent. It as never booted a 7800 cartridge (black screen or other, same behavior as no cartridge inserted.) The board is in rough shape; have cleaned slot connector several times and thoroughly and still same results. Have replaced a couple of fractured resistors. Was going to socket and replace RAM first then move onto other chips. Trying to cheaper parts first and there is a broken zener diode (CR10) listed as 1N5231 on the schematics. I have zener diodes BZX55C. Both are rated at 5.1 V,0.5 watts. The 1N5231 data sheet indicates Forward Voltage at IF = 200 mA 1.1 volts whereas the BZX55C indicates forward voltage at IF=100mA 1.0 volts. I really do not know what this diode does in the circuit but if I could use the BZX55C it would save time (long weekend plus) and money (shipping). Is this part interchangeable? Can I put 2 in parallel to reach the 200 mA at which the original 1N5231 is rated? Does anyone know if this diode at C10 is likely to prevent booting in 7800 mode? Regardless, thank you for looking/reading. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted November 24, 2021 Share Posted November 24, 2021 CR10 has to do with the player 1 controller inputs to the RIOT. I wouldn't really see that as being a cause for it not starting up but would see it being a problem with controls. Same diode is next to it at CR9 and also CR7 and 8 off player 2 side if memory serves. Quote Link to comment Share on other sites More sharing options...
