Vatcaris Posted December 4, 2021 Share Posted December 4, 2021 When I received the console months ago they worked perfectly, but from one day to the next they only work via USB cable. I have the console and controllers updated. Anyone else with the same problem? Any solution? Quote Link to comment Share on other sites More sharing options...
+sramirez2008 Posted December 4, 2021 Share Posted December 4, 2021 Yep. My classic controller only works via USB cable. I’ve ordered a 2nd classic controller to see if that one will work. My modern controller has worked fine from day one. Both controllers are updated. Quote Link to comment Share on other sites More sharing options...
eightbit Posted December 5, 2021 Share Posted December 5, 2021 Did you try to forget and re-pair them in the device settings? Have you paired other controllers in the past? 1 Quote Link to comment Share on other sites More sharing options...
fmh Posted December 5, 2021 Share Posted December 5, 2021 I am having issues also but I am new to the VCS. I can get mine to pair but it takes almost 60 seconds of holding the Fuji button down before the VCS see them. Then they are paired and work fine. But after powering off the VCS most of the time pairing is lost and I have to do it all over. Not sure if it is the controller firmware of the VCS firmware causing the problem. But most of the time I use the controllers wired. Quote Link to comment Share on other sites More sharing options...
+SabertoothRetro Posted December 5, 2021 Share Posted December 5, 2021 I had this issue once and had to forget and repair the controllers in device settings. They have worked flawlessly since. 1 Quote Link to comment Share on other sites More sharing options...
Vatcaris Posted December 5, 2021 Author Share Posted December 5, 2021 13 hours ago, eightbit said: Did you try to forget and re-pair them in the device settings? Have you paired other controllers in the past? How can I forget the controllers? I don't see that option. Quote Link to comment Share on other sites More sharing options...
justclaws Posted December 5, 2021 Share Posted December 5, 2021 5 hours ago, fmh said: I am having issues also but I am new to the VCS. I can get mine to pair but it takes almost 60 seconds of holding the Fuji button down before the VCS see them. Then they are paired and work fine. But after powering off the VCS most of the time pairing is lost and I have to do it all over. Not sure if it is the controller firmware of the VCS firmware causing the problem. But most of the time I use the controllers wired. You are not meant to hold the button the whole time, to pair them. 1) The first time, hold the Atari button until they flash quickly. That's pairing mode. Release the button. 2) After they're paired the first time, just tapping the button to turn them on, will cause a slow flash, and they will reconnect. If you hold the button down, instead of tapping it, you'll put them back into first-time pairing mode again. Another note, if you pair them in Windows, the pairing will be lost with the AtariOS mode. You can use them wired with Windows or Linux, and then the Bluetooth pairing in AtariOS will not be affected. To forget the pairing of the controllers, you can go to Settings, and "My Devices", and forget (any) controllers. I hope this helps you and anybody else. 3 Quote Link to comment Share on other sites More sharing options...
+sramirez2008 Posted December 6, 2021 Share Posted December 6, 2021 On 12/5/2021 at 2:16 PM, justclaws said: You can use them wired with Windows or Linux, and then the Bluetooth pairing in AtariOS will not be affected. This seemed to be my issue. They are pairing pretty quickly now, upon start up. -Thanks. Quote Link to comment Share on other sites More sharing options...
Vaskomyr Posted September 22, 2023 Share Posted September 22, 2023 (edited) I know this is late in the conversation but I have not been able to connect either controller wirelessly since I got my bundle in june this year. Updated everything but still not working. Any suggestions? Tried them on pc and they work so the bluetooth of the controllers are fine. When I go to connect to the VCS they never appear on the pair new controller tab, but the VCS shows them as connected devices, but they don't respond at all. Did the reset on each control as well, nothing seems to correct this issue. Fine on usb connection but the cord just gets in the way of my setup. Plus I just want the functionality of be wireless. Any suggestions? Edited September 22, 2023 by Vaskomyr Issue fixed by system reflash Quote Link to comment Share on other sites More sharing options...
justclaws Posted September 23, 2023 Share Posted September 23, 2023 14 hours ago, Vaskomyr said: When I go to connect to the VCS they never appear on the pair new controller tab, but the VCS shows them as connected devices, but they don't respond at all. Did the reset on each control as well, nothing seems to correct this issue. You already checked the Bluetooth works on the controllers. That's good. You can also check it on the VCS, by making another Bluetooth item available, and seeing if you can pair that. e.g. Bluetooth speaker, or headphones. (Bluetooth up to 4.0, not >4.0 of course.) The joysticks can only be paired with a single device at once, so if they are paired to a PC in PC-mode, they have to go back into pairing mode to connect to the VCS, and vice versa. Quote Link to comment Share on other sites More sharing options...
