fieroluke Posted December 9, 2021 Share Posted December 9, 2021 I took the time today to measure the current draws of the Atari 2600 expansion module (without cartridge). Hopefully someone finds this useful: The 5V supply unsurprisingly draws most, about 270mA. I would have guessed more, but this is moderate. Next is the 12V supply, coming in second at 25mA. I guess it only supplies the video amp. Finally, the -5V supply: 0.0mA! Surprise, surprise, it’s apparently not used! This info may come in handy if anyone wants to turn the exp module into a standalone 2600 clone… 1 Quote Link to comment Share on other sites More sharing options...
Falonn Posted December 10, 2021 Share Posted December 10, 2021 Re: "if anyone wants to turn the exp module into a standalone 2600 clone", this is a nearly-finished place to start. Once I found out you could get S-video out of a 2600--but not from the expansion module pins--it took the wind out of my sails and I abandoned the project (and just grabbed a modded 2600 from eBay instead ? ). That said, that board design was far enough along that things were showing up on the screen, just... not quite correctly. ? 2 Quote Link to comment Share on other sites More sharing options...
fieroluke Posted December 10, 2021 Author Share Posted December 10, 2021 2 hours ago, Falonn said: Re: "if anyone wants to turn the exp module into a standalone 2600 clone", this is a nearly-finished place to start. Once I found out you could get S-video out of a 2600--but not from the expansion module pins--it took the wind out of my sails and I abandoned the project (and just grabbed a modded 2600 from eBay instead ? ). That said, that board design was far enough along that things were showing up on the screen, just... not quite correctly. ? Yes, but the interesting point was that -5V is not needed, and adding an 7805 you could run the whole thing from a single 12V supply. The 0.3A are interesting when it comes to heat sinking the 7805... Quote Link to comment Share on other sites More sharing options...
Ikrananka Posted December 10, 2021 Share Posted December 10, 2021 7 hours ago, Falonn said: Once I found out you could get S-video out of a 2600--but not from the expansion module pins--it took the wind out of my sails and I abandoned the project (and just grabbed a modded 2600 from eBay instead ? ). For years I had wanted to try to replicate phattyboombatty's standalone mod but never found the time. Then I picked up a 2600Jr. locally for a few dollars and installed a Tim Worthington RGB mod in it and have never looked back. Stunning image quality. I also planned on installing one of Tim's RGB mods in one of my spare expansion modules but again never found the time. A future project perhaps. Quote Link to comment Share on other sites More sharing options...
Falonn Posted December 11, 2021 Share Posted December 11, 2021 21 hours ago, fieroluke said: Yes, but the interesting point was that -5V is not needed... Are you completely sure? @ChildOfCv's schematics show the -5V rail connected (through a resistor and 2.5V Zener diode) to pin 8 of each controller port (which is the "ground" pin for left/right/up/down). During your testing did you have controllers connected? Does the -5V rail show any current when you move the stick around? (I'm hazy on Zeners, but the circuit looks like it's almost been designed to have the -5V rail be optional. But the controller interface on the Colecovision does something similarly quizzical, so I wouldn't write it off as "not needed".) 16 hours ago, Ikrananka said: Stunning image quality. I'd be curious to see a side-by-side comparison. At that resolution and color count, I would already describe the S-video mod as "flawless". hehe. Quote Link to comment Share on other sites More sharing options...
fieroluke Posted December 11, 2021 Author Share Posted December 11, 2021 1 hour ago, Falonn said: Are you completely sure? @ChildOfCv's schematics show the -5V rail connected (through a resistor and 2.5V Zener diode) to pin 8 of each controller port (which is the "ground" pin for left/right/up/down). During your testing did you have controllers connected? Does the -5V rail show any current when you move the stick around? (I'm hazy on Zeners, but the circuit looks like it's almost been designed to have the -5V rail be optional. But the controller interface on the Colecovision does something similarly quizzical, so I wouldn't write it off as "not needed".) Good point! i wasn’t aware of the schematics being available, I couldn’t find them when I looked for them. indeed, I didn’t hook up a joystick (I’m not even sure I have Atari joysticks anymore!). And yes, Coleco used the -5V as well to (I guess) have a „stronger“ ground using their controllers, which have diodes in them, offsetting their voltage drops? Maybe using the CV controllers on the expansion module was supported and offsetting the diodes required the -2.5V offset? Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted December 11, 2021 Share Posted December 11, 2021 Yeah I think the zeners are there to make sure the CV joysticks work in the Expansion Module. With the zener diodes in place, it pulls down to -2.5V, which ought to overcome any diode issues in the controller. Otherwise there's a 18Ohm resistor to ground from pin 8. Quote Link to comment Share on other sites More sharing options...
Ikrananka Posted December 11, 2021 Share Posted December 11, 2021 5 hours ago, Falonn said: I'd be curious to see a side-by-side comparison. At that resolution and color count, I would already describe the S-video mod as "flawless". hehe. I put my RGB modded 2600 through an OSSC and then into a 20" LCD monitor via HDMI. All I can say is that the image looks flawless, with ultra-sharp edges wherever a colour change occurs. No fuzziness or colour blending whatsoever. I'm not sure the same could be said for s-video. All of this is just personal preference anyway. 1 Quote Link to comment Share on other sites More sharing options...
Falonn Posted December 20, 2023 Share Posted December 20, 2023 On 12/11/2021 at 4:47 AM, ChildOfCv said: With the zener diodes in place, it pulls down to -2.5V, which ought to overcome any diode issues in the controller. Otherwise there's a 18Ohm resistor to ground from pin 8. Hmm, in the two years since this reply I seem to have forgotten I'd already asked here, so I just re-asked it over in the 2600 forum a couple hours ago before I noticed this one again. But the answers here (that the -5V supply pulls 0mA and that pin 8 on the controllers would be at -2.5V) both seem at odds with the schematic: (Here it is, live in the simulator.) The intersection between R1, ZD1, and ZD2 is definitely at -2.5V, but the pin 8 controller GNDs are just a hair below 0V at -63mV. And instead of 0mA, there should be a steady 43mA pouring mostly through ZD1 and R1. So, if it is for Coleco controller compatibility, it's a tiny <0.1V tweak that comes at the expense of ~200mW constantly being burned. For Atari joysticks, it seems like the -5V rail could safely be omitted. But I still feel like I'm missing something. Maybe I should get my Expansion Module 1 back on the bench and test the power draw, too. I wonder if fieroluke's was behaving out of the ordinary? Quote Link to comment Share on other sites More sharing options...
