New major #FujiNet build coming - Look for regressions.
A new build is coming with major changes internally.
The last build released was in July of this year, and since then, we all have been extremely busy refactoring the entire code-base to support multiple target platforms, in anticipation of releasing the Adam FujiNet, and later the Apple2 and Commodore 64 FujiNets, with an eye to releasing one for every single 8-bit system out there.
While we have done as much due diligence as possible, I am posting this ahead of time, because we need to be on the look out for any features that may regress as a result of this build, and report them in all the usual channels, so that they can be fixed.
Thank you all for your patience.
-Thom
  • Like 4
I just updated my Fujinet to the latest version, and I think I found an issue. This is running on a 130xe, so unlike running on an 800, it shouldn't (and didn't before) need external power to start up. Now, if it's unplugged and I turn on the 130xe, it boots straight to Basic. The white LED takes several seconds (20ish) to turn on, long after the computer has booted.
If I plug the USB cable in, and the light is on when I turn on the computer, the Fujinet boots to the config just fine.
The only way to work around it, without having it plugged in, is to enter the BYE command to get to the self-test, then hit reset.
So, guessing there's some longer delay to boot up the device with the latest firmware?
Thanks!
Ok, one update... I see this behavior on my original Fujinet (v1.0)? However, if I try on my V1.3 device, it boots just fine (my mistake, the white light doesn't come on before it boots, but the activity LED does flash (on the 1.3) as Config is loaded. On v1.0, there's no activity flashing.
1 hour ago, _The Doctor__ said:
You didn't see this coming?
Might as well just roll back to the previous firmware... it's going to be about it... gotta make it for all machines now... rinse repeat...
No offense but relax. I just wanted to post my experience so someone knows.  I’m well aware of rhe consequences of running “bleeding edge” software.
Thanks for the report. :)
The white indicator isn't necessary for booting into config. I am definitely interested to see the debug output from the flasher. I am wondering if the IDF 3.4.0 toolchain adds a slight boot delay?
-Thom
-Thom
I will get you the output. I had thought it may not tell much, as when plugged in it works correctly.
  • 2 weeks later...
Upgraded today - see full flasher output below.  Ended up now with no working wi-fi afterwards (worked before).  No Wi-Fi light, won't find any AP when re-scanned or manually entered.  All wi-fi operations appear to just return error 12289 in the debug serial output. I've tried reflashing a couple times now with same results.
Thanks,
-Bill
Using '/dev/ttyUSB0' as serial port.
Starting firmware upgrade...
Getting latest firmware from fujinet.online..
FujiNet Version: 0.5.cec57d6a
Version Date/Time: 2021-12-11 17:57:01
Build Date/Time: Mon Dec 13 01:57:05 UTC 2021
Connecting....
Detecting chip type... ESP32
Connecting....
Chip Info:
 - Chip Family: ESP32
 - Chip Model: ESP32-D0WD-V3 (revision 3)
 - Number of Cores: 2
 - Max CPU Frequency: 240MHz
 - Has Bluetooth: YES
 - Has Embedded Flash: NO
 - Has Factory-Calibrated ADC: YES
 - MAC Address: AC:67:B2:76:F3:B8
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
 - Flash Size: 16MB
 - Firware path: fujinet.online
 - Flash Mode: dio
 - Flash Frequency: 40MHz
Erasing flash (this may take a while)...
Chip erase completed successfully in 47.3s
Compressed 27520 bytes to 16756...
Writing at 0x00001000... (50 %)
Writing at 0x00005000... (100 %)
Wrote 27520 bytes (16756 compressed) at 0x00001000 in 0.4 seconds (effective 545.0 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 128...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (effective 3515.7 kbit/s)...
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 13149.5 kbit/s)...
Compressed 1910336 bytes to 1099295...
Writing at 0x00010000... (1 %)
Writing at 0x00014000... (2 %)
Writing at 0x00018000... (4 %)
Writing at 0x0001c000... (5 %)
Writing at 0x00020000... (7 %)
Writing at 0x00024000... (8 %)
Writing at 0x00028000... (10 %)
Writing at 0x0002c000... (11 %)
Writing at 0x00030000... (13 %)
Writing at 0x00034000... (14 %)
Writing at 0x00038000... (16 %)
Writing at 0x0003c000... (17 %)
Writing at 0x00040000... (19 %)
Writing at 0x00044000... (20 %)
Writing at 0x00048000... (22 %)
Writing at 0x0004c000... (23 %)
Writing at 0x00050000... (25 %)
Writing at 0x00054000... (26 %)
Writing at 0x00058000... (27 %)
Writing at 0x0005c000... (29 %)
Writing at 0x00060000... (30 %)
Writing at 0x00064000... (32 %)
Writing at 0x00068000... (33 %)
Writing at 0x0006c000... (35 %)
Writing at 0x00070000... (36 %)
Writing at 0x00074000... (38 %)
Writing at 0x00078000... (39 %)
Writing at 0x0007c000... (41 %)
Writing at 0x00080000... (42 %)
Writing at 0x00084000... (44 %)
Writing at 0x00088000... (45 %)
Writing at 0x0008c000... (47 %)
Writing at 0x00090000... (48 %)
Writing at 0x00094000... (50 %)
Writing at 0x00098000... (51 %)
Writing at 0x0009c000... (52 %)
Writing at 0x000a0000... (54 %)
Writing at 0x000a4000... (55 %)
Writing at 0x000a8000... (57 %)
Writing at 0x000ac000... (58 %)
Writing at 0x000b0000... (60 %)
Writing at 0x000b4000... (61 %)
Writing at 0x000b8000... (63 %)
Writing at 0x000bc000... (64 %)
Writing at 0x000c0000... (66 %)
Writing at 0x000c4000... (67 %)
Writing at 0x000c8000... (69 %)
Writing at 0x000cc000... (70 %)
Writing at 0x000d0000... (72 %)
Writing at 0x000d4000... (73 %)
Writing at 0x000d8000... (75 %)
Writing at 0x000dc000... (76 %)
Writing at 0x000e0000... (77 %)
Writing at 0x000e4000... (79 %)
Writing at 0x000e8000... (80 %)
Writing at 0x000ec000... (82 %)
Writing at 0x000f0000... (83 %)
Writing at 0x000f4000... (85 %)
Writing at 0x000f8000... (86 %)
Writing at 0x000fc000... (88 %)
Writing at 0x00100000... (89 %)
Writing at 0x00104000... (91 %)
Writing at 0x00108000... (92 %)
Writing at 0x0010c000... (94 %)
Writing at 0x00110000... (95 %)
Writing at 0x00114000... (97 %)
Writing at 0x00118000... (98 %)
Writing at 0x0011c000... (100 %)
Wrote 1910336 bytes (1099295 compressed) at 0x00010000 in 25.6 seconds (effective 596.1 kbit/s)...
Compressed 2097152 bytes to 648574...
Writing at 0x00c10000... (2 %)
Writing at 0x00c14000... (5 %)
Writing at 0x00c18000... (7 %)
Writing at 0x00c1c000... (10 %)
Writing at 0x00c20000... (12 %)
Writing at 0x00c24000... (15 %)
Writing at 0x00c28000... (17 %)
Writing at 0x00c2c000... (20 %)
Writing at 0x00c30000... (22 %)
Writing at 0x00c34000... (25 %)
Writing at 0x00c38000... (27 %)
Writing at 0x00c3c000... (30 %)
Writing at 0x00c40000... (32 %)
Writing at 0x00c44000... (35 %)
Writing at 0x00c48000... (37 %)
Writing at 0x00c4c000... (40 %)
Writing at 0x00c50000... (42 %)
Writing at 0x00c54000... (45 %)
Writing at 0x00c58000... (47 %)
Writing at 0x00c5c000... (50 %)
Writing at 0x00c60000... (52 %)
Writing at 0x00c64000... (55 %)
Writing at 0x00c68000... (57 %)
Writing at 0x00c6c000... (60 %)
Writing at 0x00c70000... (62 %)
Writing at 0x00c74000... (65 %)
Writing at 0x00c78000... (67 %)
Writing at 0x00c7c000... (70 %)
Writing at 0x00c80000... (72 %)
Writing at 0x00c84000... (75 %)
Writing at 0x00c88000... (77 %)
Writing at 0x00c8c000... (80 %)
Writing at 0x00c90000... (82 %)
Writing at 0x00c94000... (85 %)
Writing at 0x00c98000... (87 %)
Writing at 0x00c9c000... (90 %)
Writing at 0x00ca0000... (92 %)
Writing at 0x00ca4000... (95 %)
Writing at 0x00ca8000... (97 %)
Writing at 0x00cac000... (100 %)
Wrote 2097152 bytes (648574 compressed) at 0x00c10000 in 16.1 seconds (effective 1041.1 kbit/s)...
Leaving...
Hard Resetting...
Done! Flashing is complete!
Showing logs:
[15:09:11]
[15:09:11]
[15:09:11]--~--~--~--
[15:09:11]FujiNet 0.5.cec57d6a 2021-12-11 17:57:01 Started @ 5
[15:09:11]Starting heap: 4375827
[15:09:11]Detected Hardware Version: 1.0
[15:09:11]SPIFFS mounted.
[15:09:11]SD mounted.
[15:09:11]fnConfig::load
[15:09:11]Load fnconfig.ini from SD
[15:09:11]fnConfig::load read 599 bytes from config file
[15:09:11]SPIFFS Config Storage: Enabled
[15:09:11]fnConfig::load read 316 bytes from SPIFFS config file
[15:09:11]Copying SD config file to SPIFFS
[15:09:11]copy_file "/fnconfig.ini" -> "/fnconfig.ini"
[15:09:11]copy_file copied 599 bytes
[15:09:11]disk UNMOUNT
[15:09:11]disk MOUNT
[15:09:11]ATR MOUNT
[15:09:11]mounted ATR: paragraphs=5760, sect_size=128, sect_count=720, disk_size=0
[15:09:11]Creating a default printer using FS_SDFAT storage and type 1
[15:09:11]SSH client initialized.
[15:09:11]ModemSniffer::ModemSniffer(FS_SDFAT)
[15:09:11]SIO SETUP
[15:09:11]Set HSIO baud from 0 to 67431 (index 6), alt=68209
[15:09:11]Available heap: 4283739
[15:09:11]Setup complete @ 410 (405ms)
[15:09:45]
[15:09:45]CF: 00 31 53 00 00
[15:09:45]CHECKSUM_ERROR
[15:09:45]
[15:09:45]CF: 31 53 00 00 84
[15:09:45]FujiNet CONFIG boot
[15:09:45]disk sio_process()
[15:09:45]ignoring status command
[15:09:45]
[15:09:45]
[15:09:45]
[15:09:45]
[15:09:45]
[15:09:45]ACK!
[15:09:45]disk STATUS
[15:09:45]response: 0x00, 0xff, 0xe0
[15:09:45]->SIO write 4 bytes
[15:09:45]COMPLETE!
[15:09:45]
[15:09:45]CF: 31 52 01 00 84
[15:09:45]ACK!
[15:09:45]ATR READ
[15:09:45]->SIO write 128 bytes
[15:09:45]COMPLETE!
[15:09:45]
[15:09:45]CF: 31 52 02 00 85
[15:09:45]ACK!
[15:09:45]ATR READ
[15:09:45]COMPLETE!
[15:09:45]
[15:09:45]CF: 31 52 03 00 86
[15:09:45]ACK!
[15:09:45]ATR READ
[15:09:45]COMPLETE!
[15:09:45]
[15:09:45]CF: 31 52 04 00 87
[15:09:45]ACK!
[15:09:45]ATR READ
[15:09:45]COMPLETE!
[15:09:45]
[15:09:45]CF: 31 52 05 00 88
[15:09:45]ACK!
[15:09:45]ATR READ
[15:09:45]COMPLETE!
[15:09:45]
[15:09:45]CF: 31 52 06 00 89
[15:09:45]ACK!
[15:09:45]ATR READ
[15:09:45]COMPLETE!
[15:09:45]
[15:09:45]CF: 31 52 07 00 8a
[15:09:45]ACK!
[15:09:45]ATR READ
[15:09:45]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 08 00 8b
[15:09:46]FujiNet CONFIG boot
[15:09:46]disk sio_process()
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]->SIO write 128 bytes
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 09 00 8c
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 3f 00 00 70
[15:09:46]ACK!
[15:09:46]sio HSIO INDEX
[15:09:46]->SIO write 1 bytes
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 00 ff 00 ff 00
[15:09:46]CHECKSUM_ERROR
[15:09:46]Toggling baudrate from 19200 to 67431
[15:09:46]set_baudrate change from 19200 to 67431
[15:09:46]
[15:09:46]CF: 31 52 0a 00 8d
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 0b 00 8e
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 0c 00 8f
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 0d 00 90
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 0e 00 91
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 0f 00 92
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 10 00 93
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 11 00 94
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 12 00 95
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 13 00 96
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 14 00 97
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 15 00 98
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 16 00 99
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 17 00 9a
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 18 00 9b
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 19 00 9c
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:46]
[15:09:46]CF: 31 52 1a 00 9d
[15:09:46]ACK!
[15:09:46]ATR READ
[15:09:46]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 1b 00 9e
[15:09:47]FujiNet CONFIG boot
[15:09:47]disk sio_process()
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]->SIO write 128 bytes
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 1c 00 9f
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 1d 00 a0
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 1e 00 a1
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 1f 00 a2
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 20 00 a3
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 21 00 a4
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 22 00 a5
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 23 00 a6
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 24 00 a7
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 25 00 a8
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 26 00 a9
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 27 00 aa
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 28 00 ab
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 29 00 ac
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 2a 00 ad
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 2b 00 ae
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 2c 00 af
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 2d 00 b0
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 2e 00 b1
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 2f 00 b2
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 30 00 b3
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 31 00 b4
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 32 00 b5
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:47]CF: 31 52 33 00 b6
[15:09:47]ACK!
[15:09:47]ATR READ
[15:09:47]COMPLETE!
[15:09:47]
[15:09:48]CF: 31 52 34 00 b7
[15:09:48]FujiNet CONFIG boot
[15:09:48]disk sio_process()
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]->SIO write 128 bytes
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 35 00 b8
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 36 00 b9
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 37 00 ba
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 38 00 bb
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 39 00 bc
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 3a 00 bd
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 3b 00 be
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 3c 00 bf
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 3d 00 c0
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 3e 00 c1
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 3f 00 c2
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 40 00 c3
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 41 00 c4
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 42 00 c5
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 43 00 c6
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 44 00 c7
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 45 00 c8
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 46 00 c9
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 47 00 ca
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 48 00 cb
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 49 00 cc
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 4a 00 cd
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 4b 00 ce
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 4c 00 cf
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:48]
[15:09:48]CF: 31 52 4d 00 d0
[15:09:48]ACK!
[15:09:48]ATR READ
[15:09:48]COMPLETE!
[15:09:49]
[15:09:49]CF: 31 52 4e 00 d1
[15:09:49]FujiNet CONFIG boot
[15:09:49]disk sio_process()
[15:09:49]ACK!
[15:09:49]ATR READ
[15:09:49]->SIO write 128 bytes
[15:09:49]COMPLETE!
[15:09:49]
[15:09:49]CF: 31 52 4f 00 d2
[15:09:49]ACK!
[15:09:49]ATR READ
[15:09:49]COMPLETE!
[15:09:49]
[15:09:49]CF: 31 52 50 00 d3
[15:09:49]ACK!
[15:09:49]ATR READ
[15:09:49]COMPLETE!
[15:09:49]
[15:09:49]CF: 31 52 51 00 d4
[15:09:49]ACK!
[15:09:49]ATR READ
[15:09:49]COMPLETE!
[15:09:49]
[15:09:49]CF: 00 38 00 00 f8
[15:09:49]CHECKSUM_ERROR
[15:09:49]
[15:09:49]Toggling baudrate from 67431 to 19200
[15:09:49]set_baudrate change from 67432 to 19200
[15:09:49]
[15:09:49]CF: 70 fe 00 00 6f
[15:09:49]sioFuji::sio_process() called
[15:09:49]ACK!
[15:09:49]Fuji cmd: GET SSID
[15:09:49]->SIO write 96 bytes
[15:09:49]COMPLETE!
[15:09:49]
[15:09:49]CF: 70 e8 00 00 59
[15:09:49]ACK!
[15:09:49]Fuji cmd: GET ADAPTER CONFIG
[15:09:49]->SIO write 139 bytes
[15:09:49]COMPLETE!
[15:09:49]
[15:09:49]CF: 70 fd 00 00 6e
[15:09:49]ACK!
[15:09:49]Fuji cmd: SCAN NETWORKS
[15:09:49]esp_wifi_scan_start returned error 12289
[15:09:49]->SIO write 4 bytes
[15:09:49]COMPLETE!
[15:09:55]
[15:09:55]CF: 70 e8 00 00 59
[15:09:55]sioFuji::sio_process() called
[15:09:55]ACK!
[15:09:55]Fuji cmd: GET ADAPTER CONFIG
[15:09:55]->SIO write 139 bytes
[15:09:55]COMPLETE!
[15:09:55]
[15:09:55]CF: 70 fd 00 00 6e
[15:09:55]ACK!
[15:09:55]Fuji cmd: SCAN NETWORKS
[15:09:55]esp_wifi_scan_start returned error 12289
[15:09:55]->SIO write 4 bytes
[15:09:55]COMPLETE!
[15:09:57]
[15:09:57]CF: 70 e8 00 00 59
[15:09:57]sioFuji::sio_process() called
[15:09:57]ACK!
[15:09:57]Fuji cmd: GET ADAPTER CONFIG
[15:09:57]->SIO write 139 bytes
[15:09:57]COMPLETE!
[15:09:57]
[15:09:57]CF: 70 fd 00 00 6e
[15:09:57]ACK!
[15:09:57]Fuji cmd: SCAN NETWORKS
[15:09:57]esp_wifi_scan_start returned error 12289
[15:09:57]->SIO write 4 bytes
[15:09:57]COMPLETE!
[15:17:24]
[15:17:24]CF: 70 f4 00 00 65
[15:17:24]sioFuji::sio_process() called
[15:17:24]ACK!
[15:17:24]Fuji cmd: READ HOST SLOTS
[15:17:24]->SIO write 256 bytes
[15:17:24]COMPLETE!
[15:17:24]
[15:17:24]CF: 70 f2 00 00 63
[15:17:24]ACK!
[15:17:24]Fuji cmd: READ DEVICE SLOTS
[15:17:24]->SIO write 304 bytes
[15:17:24]COMPLETE!
[15:17:30]
[15:17:30]CF: 70 e8 00 00 59
[15:17:30]sioFuji::sio_process() called
[15:17:30]ACK!
[15:17:30]Fuji cmd: GET ADAPTER CONFIG
[15:17:30]->SIO write 139 bytes
[15:17:30]COMPLETE!
[15:17:37]
[15:17:37]CF: 70 fe 00 00 6f
[15:17:37]sioFuji::sio_process() called
[15:17:37]ACK!
[15:17:37]Fuji cmd: GET SSID
[15:17:37]->SIO write 96 bytes
[15:17:37]COMPLETE!
[15:17:37]
[15:17:37]CF: 70 e8 00 00 59
[15:17:37]ACK!
[15:17:37]Fuji cmd: GET ADAPTER CONFIG
[15:17:37]->SIO write 139 bytes
[15:17:37]COMPLETE!
[15:17:37]
[15:17:37]CF: 70 fd 00 00 6e
[15:17:37]ACK!
[15:17:37]Fuji cmd: SCAN NETWORKS
[15:17:37]esp_wifi_scan_start returned error 12289
[15:17:37]->SIO write 4 bytes
[15:17:37]COMPLETE!
Sorry - this got chopped out of the previous paste - serial debug error when doing a manual entry for the wi-fi.
-Bill
[15:17:37]COMPLETE!
[15:34:27]
[15:34:27]CF: 70 fb 01 00 6d
[15:34:27]sioFuji::sio_process() called
[15:34:27]ACK!
[15:34:27]Fuji cmd: SET SSID
[15:34:27]<-SIO read 96 bytes
[15:34:27]ACK!
[15:34:27]Connecting to net: private password: private
[15:34:27]WiFi connect attempt to SSID "private"
[15:34:27]ESP_ERROR_CHECK failed: esp_err_t 0x3001 (ESP_ERR_WIFI_NOT_INIT) at 0x4008f39c
[15:34:27]file: "lib/hardware/fnWiFi.cpp" line 155
[15:34:27]func: int WiFiManager::connect(const char*, const char*)
[15:34:27]expression: esp_wifi_set_config(WIFI_IF_STA, &wifi_config)
[15:34:27]
[15:34:27]abort() was called at PC 0x4008f39f on core 1
[15:34:27]
[15:34:27]Backtrace:0x4009108e:0x3ffd47f0 0x400918c1:0x3ffd4810 0x400983c1:0x3ffd4830 0x4008f39f:0x3ffd48b0 0x400f0414:0x3ffd48d0 0x400d9709:0x3ffd4980 0x400db599:0x3ffd4a10 0x400eea99:0x3ffd4a30 0x400eeba2:0x3ffd4a70 0x400d3e12:0x3ffd4a90 0x40095159:0x3ffd4ab0
[15:34:27]
[15:34:27]
[15:34:27]ELF file SHA256: 4ca0e402ce6de7e3
[15:34:27]
[15:34:27]Rebooting...
On 12/18/2021 at 6:30 PM, tschak909 said:
Actually it will give me a critical piece of information, the start up time. :)
-Thom
Here's the debug output. This is turning the computer on cold. Again, hooked up with the USB cable, it boots just fine. Pulling the cable out and it does not seem to power on fast enough for the 130xe.
Using '/dev/cu.usbserial-10' as serial port.
Showing logs:
[17:07:42]sioFuji::sio_process() called
[17:07:42]ACK!
[17:07:42]Fuji cmd: GET WIFI STATUS
[17:07:42]->SIO write 1 bytes
[17:07:42]COMPLETE!
[17:07:44]
[17:07:44]CF: 31 53 00 00 84
[17:07:44]FujiNet CONFIG boot
[17:07:44]disk sio_process()
[17:07:44]ACK!
[17:07:44]disk STATUS
[17:07:44]response: 0x00, 0xff, 0xe0
[17:07:44]->SIO write 4 bytes
[17:07:44]COMPLETE!
[17:07:44]
[17:07:44]CF: 31 52 01 00 84
[17:07:44]ACK!
[17:07:44]ATR READ
[17:07:44]->SIO write 128 bytes
[17:07:44]COMPLETE!
[17:07:44]
[17:07:44]CF: 31 52 02 00 85
[17:07:44]ACK!
[17:07:44]ATR READ
[17:07:44]COMPLETE!
[17:07:44]
[17:07:44]CF: 31 52 03 00 86
[17:07:44]ACK!
[17:07:44]ATR READ
[17:07:44]COMPLETE!
[17:07:44]
[17:07:44]CF: 31 52 04 00 87
[17:07:44]ACK!
[17:07:44]ATR READ
[17:07:44]COMPLETE!
[17:07:44]
[17:07:44]CF: 31 52 05 00 88
[17:07:44]ACK!
[17:07:44]ATR READ
[17:07:44]COMPLETE!
[17:07:44]
[17:07:44]CF: 31 52 06 00 89
[17:07:44]ACK!
[17:07:44]ATR READ
[17:07:44]COMPLETE!
[17:07:44]
[17:07:44]CF: 31 52 07 00 8a
[17:07:44]ACK!
[17:07:44]ATR READ
[17:07:44]COMPLETE!
[17:07:44]
[17:07:44]CF: 31 52 08 00 8b
[17:07:44]ACK!
[17:07:44]ATR READ
[17:07:44]COMPLETE!
[17:07:44]
[17:07:44]CF: 31 52 09 00 8c
[17:07:44]ACK!
[17:07:44]ATR READ
[17:07:44]COMPLETE!
[17:07:44]
[17:07:44]CF: 31 3f 00 00 70
[17:07:44]ACK!
[17:07:44]sio HSIO INDEX
[17:07:44]->SIO write 1 bytes
[17:07:44]COMPLETE!
[17:07:44]
[17:07:44]CF: 00 ff 00 ff 00
[17:07:44]CHECKSUM_ERROR
[17:07:45]
[17:07:45]CF: 00 ff 00 ff 00
[17:07:45]CHECKSUM_ERROR
[17:07:45]Toggling baudrate from 19200 to 67431
[17:07:45]set_baudrate change from 19200 to 67431
[17:07:45]
[17:07:45]CF: 31 52 0a 00 8d
[17:07:45]FujiNet CONFIG boot
[17:07:45]disk sio_process()
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]->SIO write 128 bytes
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 0b 00 8e
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 0c 00 8f
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 0d 00 90
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 0e 00 91
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 0f 00 92
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 10 00 93
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 11 00 94
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 12 00 95
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 13 00 96
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 14 00 97
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 15 00 98
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 16 00 99
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 17 00 9a
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 18 00 9b
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 19 00 9c
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 1a 00 9d
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 1b 00 9e
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 1c 00 9f
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 1d 00 a0
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 1e 00 a1
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 1f 00 a2
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 20 00 a3
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:45]
[17:07:45]CF: 31 52 21 00 a4
[17:07:45]ACK!
[17:07:45]ATR READ
[17:07:45]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 22 00 a5
[17:07:46]FujiNet CONFIG boot
[17:07:46]disk sio_process()
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]->SIO write 128 bytes
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 23 00 a6
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 24 00 a7
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 25 00 a8
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 26 00 a9
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 27 00 aa
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 28 00 ab
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 29 00 ac
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 2a 00 ad
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 2b 00 ae
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 2c 00 af
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 2d 00 b0
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 2e 00 b1
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 2f 00 b2
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 30 00 b3
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 31 00 b4
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 32 00 b5
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 33 00 b6
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 34 00 b7
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 35 00 b8
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 36 00 b9
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 37 00 ba
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 38 00 bb
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 39 00 bc
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:46]
[17:07:46]CF: 31 52 3a 00 bd
[17:07:46]ACK!
[17:07:46]ATR READ
[17:07:46]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 3b 00 be
[17:07:47]FujiNet CONFIG boot
[17:07:47]disk sio_process()
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]->SIO write 128 bytes
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 3c 00 bf
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 3d 00 c0
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 3e 00 c1
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 3f 00 c2
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 40 00 c3
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 41 00 c4
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 42 00 c5
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 43 00 c6
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 44 00 c7
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 45 00 c8
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 46 00 c9
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 47 00 ca
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 48 00 cb
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 49 00 cc
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 4a 00 cd
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 4b 00 ce
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 4c 00 cf
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 4d 00 d0
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 4e 00 d1
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 4f 00 d2
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 50 00 d3
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 31 52 51 00 d4
[17:07:47]ACK!
[17:07:47]ATR READ
[17:07:47]COMPLETE!
[17:07:47]
[17:07:47]CF: 00 38 00 00 f8
[17:07:47]CHECKSUM_ERROR
[17:07:47]
[17:07:47]Toggling baudrate from 67431 to 19200
[17:07:47]set_baudrate change from 67432 to 19200
[17:07:48]
[17:07:48]CF: 70 fe 00 00 6f
[17:07:48]sioFuji::sio_process() called
[17:07:48]ACK!
[17:07:48]Fuji cmd: GET SSID
[17:07:48]->SIO write 96 bytes
[17:07:48]COMPLETE!
[17:07:48]
[17:07:48]CF: 70 fa 00 00 6b
[17:07:48]ACK!
[17:07:48]Fuji cmd: GET WIFI STATUS
[17:07:48]->SIO write 1 bytes
[17:07:48]COMPLETE!
[17:07:48]
[17:07:48]CF: 70 f4 00 00 65
[17:07:48]ACK!
[17:07:48]Fuji cmd: READ HOST SLOTS
[17:07:48]->SIO write 256 bytes
[17:07:48]COMPLETE!
[17:07:48]
[17:07:48]CF: 70 f2 00 00 63
[17:07:48]ACK!
[17:07:48]Fuji cmd: READ DEVICE SLOTS
[17:07:48]->SIO write 304 bytes
[17:07:48]COMPLETE!
-Bill
[15:17:37]COMPLETE!
[15:34:27]
[15:34:27]ACK!
[15:34:27]ACK!
[15:34:27]
[15:34:27]
[15:34:27]
[15:34:27]
[15:34:27]
This is very unusual, that error code translates to hex 0x3001, which is ESP_ERR_WIFI_NOT_INIT, which means esp_wifi_init() wasn't called. Will investigate.
-Thom
@8bitbill @mozzwald will do another build tonight. If you want to try before that, you can follow the instructions here to set up a dev environment:
https://github.com/FujiNetWIFI/fujinet-platformio/wiki/Board-bring-up-for-FujiNet-Platform.IO-code
I have added additional debug info into fnWifi.cpp:
// Set up requried resources and start WiFi driver
int WiFiManager::start()
    // Initilize an event group
    if (_wifi_event_group == nullptr)
        _wifi_event_group = xEventGroupCreate();
    // Make sure our network interface is initialized
    ESP_ERROR_CHECK(esp_netif_init());
    // Assume we've already done these steps if _wifi_if has a value
    if (_wifi_if == nullptr)
        // Create the default event loop, which is where the WiFi driver sends events
        ESP_ERROR_CHECK(esp_event_loop_create_default());
        // Create a default WIFI station interface
        _wifi_if = esp_netif_create_default_wifi_sta();
        // Configure basic WiFi settings
        wifi_init_config_t wifi_init_cfg = WIFI_INIT_CONFIG_DEFAULT();
        ESP_ERROR_CHECK(esp_wifi_init(&wifi_init_cfg));
        Debug_printf("WiFiManager::start() complete\n");
-Thom
Here's the full output of the run from Platformio building and running the latest git clone per your directions.  Includes a wi-fi scan attempt and a manual entry of the ssid/pw attempt.
-Bill
> Executing task: platformio device monitor <
--- Available filters and text transformations: colorize, debug, default, direct, esp32_exception_decoder, hexlify, log2file, nocontrol, printable, send_on_enter, time
--- More details at https://bit.ly/pio-monitor-filters
--- Miniterm on /dev/ttyUSB0  921600,8,N,1 ---
--- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
18:59:53.095 >
18:59:53.095 > CF: 00 31 53 00 00
18:59:53.095 > CHECKSUM_ERROR
18:59:53.123 >
18:59:53.123 > CF: 31 53 00 00 84
18:59:53.123 > FujiNet CONFIG boot
18:59:53.123 > disk sio_process()
18:59:53.123 > ignoring status command
18:59:53.156 >
18:59:53.156 > CF: 31 53 00 00 84
18:59:53.156 > FujiNet CONFIG boot
18:59:53.156 > disk sio_process()
18:59:53.156 > ignoring status command
18:59:53.190 >
18:59:53.190 > CF: 31 53 00 00 84
18:59:53.190 > FujiNet CONFIG boot
18:59:53.190 > disk sio_process()
18:59:53.190 > ignoring status command
18:59:53.223 >
18:59:53.223 > CF: 31 53 00 00 84
18:59:53.223 > FujiNet CONFIG boot
18:59:53.223 > disk sio_process()
18:59:53.223 > ignoring status command
18:59:53.257 >
18:59:53.257 > CF: 31 53 00 00 84
18:59:53.257 > FujiNet CONFIG boot
18:59:53.257 > disk sio_process()
18:59:53.257 > ignoring status command
18:59:53.290 >
18:59:53.290 > CF: 31 53 00 00 84
18:59:53.290 > FujiNet CONFIG boot
18:59:53.290 > disk sio_process()
18:59:53.290 > ACK!
18:59:53.290 > disk STATUS
18:59:53.291 > response: 0x00, 0xff, 0xe0
18:59:53.291 > ->SIO write 4 bytes
18:59:53.291 > COMPLETE!
18:59:53.304 >
18:59:53.304 > CF: 31 52 01 00 84
18:59:53.304 > FujiNet CONFIG boot
18:59:53.304 > disk sio_process()
18:59:53.304 > ACK!
18:59:53.306 > ATR READ
18:59:53.306 > ->SIO write 128 bytes
18:59:53.306 > COMPLETE!
18:59:53.385 >
18:59:53.385 > CF: 31 52 02 00 85
18:59:53.385 > FujiNet CONFIG boot
18:59:53.385 > disk sio_process()
18:59:53.385 > ACK!
18:59:53.386 > ATR READ
18:59:53.387 > ->SIO write 128 bytes
18:59:53.387 > COMPLETE!
18:59:53.466 >
18:59:53.466 > CF: 31 52 03 00 86
18:59:53.466 > FujiNet CONFIG boot
18:59:53.466 > disk sio_process()
18:59:53.466 > ACK!
18:59:53.468 > ATR READ
18:59:53.468 > ->SIO write 128 bytes
18:59:53.468 > COMPLETE!
18:59:53.547 >
18:59:53.547 > CF: 31 52 04 00 87
18:59:53.547 > FujiNet CONFIG boot
18:59:53.547 > disk sio_process()
18:59:53.547 > ACK!
18:59:53.549 > ATR READ
18:59:53.549 > ->SIO write 128 bytes
18:59:53.549 > COMPLETE!
18:59:53.635 >
18:59:53.635 > CF: 31 52 05 00 88
18:59:53.635 > FujiNet CONFIG boot
18:59:53.635 > disk sio_process()
18:59:53.635 > ACK!
18:59:53.637 > ATR READ
18:59:53.637 > ->SIO write 128 bytes
18:59:53.637 > COMPLETE!
18:59:53.727 >
18:59:53.727 > CF: 31 52 06 00 89
18:59:53.727 > FujiNet CONFIG boot
18:59:53.727 > disk sio_process()
18:59:53.727 > ACK!
18:59:53.727 > ATR READ
18:59:53.728 > ->SIO write 128 bytes
18:59:53.728 > COMPLETE!
18:59:53.818 >
18:59:53.818 > CF: 31 52 07 00 8a
18:59:53.818 > FujiNet CONFIG boot
18:59:53.818 > disk sio_process()
18:59:53.818 > ACK!
18:59:53.820 > ATR READ
18:59:53.820 > ->SIO write 128 bytes
18:59:53.820 > COMPLETE!
18:59:53.909 >
18:59:53.909 > CF: 31 52 08 00 8b
18:59:53.909 > FujiNet CONFIG boot
18:59:53.909 > disk sio_process()
18:59:53.909 > ACK!
18:59:53.909 > ATR READ
18:59:53.910 > ->SIO write 128 bytes
18:59:53.910 > COMPLETE!
18:59:54.003 >
18:59:54.003 > CF: 31 52 09 00 8c
18:59:54.003 > FujiNet CONFIG boot
18:59:54.003 > disk sio_process()
18:59:54.003 > ACK!
18:59:54.005 > ATR READ
18:59:54.005 > ->SIO write 128 bytes
18:59:54.005 > COMPLETE!
18:59:54.088 >
18:59:54.088 > CF: 31 3f 00 00 70
18:59:54.088 > FujiNet CONFIG boot
18:59:54.088 > disk sio_process()
18:59:54.088 > ACK!
18:59:54.090 > sio HSIO INDEX
18:59:54.090 > ->SIO write 1 bytes
18:59:54.090 > COMPLETE!
18:59:54.172 >
18:59:54.172 > CF: 00 ff 00 ff 00
18:59:54.172 > CHECKSUM_ERROR
18:59:54.172 > Toggling baudrate from 19200 to 67431
18:59:54.174 > set_baudrate change from 19200 to 67431
18:59:54.202 >
18:59:54.202 > CF: 31 52 0a 00 8d
18:59:54.202 > FujiNet CONFIG boot
18:59:54.202 > disk sio_process()
18:59:54.202 > ACK!
18:59:54.204 > ATR READ
18:59:54.204 > ->SIO write 128 bytes
18:59:54.204 > COMPLETE!
18:59:54.240 >
18:59:54.240 > CF: 31 52 0b 00 8e
18:59:54.240 > FujiNet CONFIG boot
18:59:54.240 > disk sio_process()
18:59:54.240 > ACK!
18:59:54.242 > ATR READ
18:59:54.242 > ->SIO write 128 bytes
18:59:54.242 > COMPLETE!
18:59:54.284 >
18:59:54.284 > CF: 31 52 0c 00 8f
18:59:54.284 > FujiNet CONFIG boot
18:59:54.284 > disk sio_process()
18:59:54.284 > ACK!
18:59:54.286 > ATR READ
18:59:54.286 > ->SIO write 128 bytes
18:59:54.286 > COMPLETE!
18:59:54.326 >
18:59:54.326 > CF: 31 52 0d 00 90
18:59:54.326 > FujiNet CONFIG boot
18:59:54.326 > disk sio_process()
18:59:54.326 > ACK!
18:59:54.328 > ATR READ
18:59:54.328 > ->SIO write 128 bytes
18:59:54.328 > COMPLETE!
18:59:54.357 >
18:59:54.357 > CF: 31 52 0e 00 91
18:59:54.357 > FujiNet CONFIG boot
18:59:54.357 > disk sio_process()
18:59:54.357 > ACK!
18:59:54.357 > ATR READ
18:59:54.358 > ->SIO write 128 bytes
18:59:54.358 > COMPLETE!
18:59:54.391 >
18:59:54.391 > CF: 31 52 0f 00 92
18:59:54.391 > FujiNet CONFIG boot
18:59:54.391 > disk sio_process()
18:59:54.391 > ACK!
18:59:54.393 > ATR READ
18:59:54.393 > ->SIO write 128 bytes
18:59:54.393 > COMPLETE!
18:59:54.426 >
18:59:54.426 > CF: 31 52 10 00 93
18:59:54.426 > FujiNet CONFIG boot
18:59:54.426 > disk sio_process()
18:59:54.426 > ACK!
18:59:54.427 > ATR READ
18:59:54.427 > ->SIO write 128 bytes
18:59:54.427 > COMPLETE!
18:59:54.462 >
18:59:54.462 > CF: 31 52 11 00 94
18:59:54.462 > FujiNet CONFIG boot
18:59:54.462 > disk sio_process()
18:59:54.462 > ACK!
18:59:54.464 > ATR READ
18:59:54.464 > ->SIO write 128 bytes
18:59:54.464 > COMPLETE!
18:59:54.504 >
18:59:54.504 > CF: 31 52 12 00 95
18:59:54.504 > FujiNet CONFIG boot
18:59:54.504 > disk sio_process()
18:59:54.504 > ACK!
18:59:54.505 > ATR READ
18:59:54.505 > ->SIO write 128 bytes
18:59:54.505 > COMPLETE!
18:59:54.545 >
18:59:54.545 > CF: 31 52 13 00 96
18:59:54.545 > FujiNet CONFIG boot
18:59:54.545 > disk sio_process()
18:59:54.545 > ACK!
18:59:54.547 > ATR READ
18:59:54.547 > ->SIO write 128 bytes
18:59:54.547 > COMPLETE!
18:59:54.588 >
18:59:54.588 > CF: 31 52 14 00 97
18:59:54.588 > FujiNet CONFIG boot
18:59:54.588 > disk sio_process()
18:59:54.588 > ACK!
18:59:54.590 > ATR READ
18:59:54.590 > ->SIO write 128 bytes
18:59:54.590 > COMPLETE!
18:59:54.625 >
18:59:54.625 > CF: 31 52 15 00 98
18:59:54.625 > FujiNet CONFIG boot
18:59:54.625 > disk sio_process()
18:59:54.625 > ACK!
18:59:54.627 > ATR READ
18:59:54.627 > ->SIO write 128 bytes
18:59:54.627 > COMPLETE!
18:59:54.667 >
18:59:54.667 > CF: 31 52 16 00 99
18:59:54.667 > FujiNet CONFIG boot
18:59:54.667 > disk sio_process()
18:59:54.667 > ACK!
18:59:54.669 > ATR READ
18:59:54.669 > ->SIO write 128 bytes
18:59:54.669 > COMPLETE!
18:59:54.705 >
18:59:54.705 > CF: 31 52 17 00 9a
18:59:54.705 > FujiNet CONFIG boot
18:59:54.705 > disk sio_process()
18:59:54.705 > ACK!
18:59:54.707 > ATR READ
18:59:54.707 > ->SIO write 128 bytes
18:59:54.707 > COMPLETE!
18:59:54.747 >
18:59:54.747 > CF: 31 52 18 00 9b
18:59:54.747 > FujiNet CONFIG boot
18:59:54.747 > disk sio_process()
18:59:54.747 > ACK!
18:59:54.749 > ATR READ
18:59:54.749 > ->SIO write 128 bytes
18:59:54.749 > COMPLETE!
18:59:54.786 >
18:59:54.786 > CF: 31 52 19 00 9c
18:59:54.786 > FujiNet CONFIG boot
18:59:54.786 > disk sio_process()
18:59:54.786 > ACK!
18:59:54.788 > ATR READ
18:59:54.788 > ->SIO write 128 bytes
18:59:54.788 > COMPLETE!
18:59:54.823 >
18:59:54.823 > CF: 31 52 1a 00 9d
18:59:54.823 > FujiNet CONFIG boot
18:59:54.823 > disk sio_process()
18:59:54.823 > ACK!
18:59:54.825 > ATR READ
18:59:54.825 > ->SIO write 128 bytes
18:59:54.825 > COMPLETE!
18:59:54.862 >
18:59:54.862 > CF: 31 52 1b 00 9e
18:59:54.862 > FujiNet CONFIG boot
18:59:54.862 > disk sio_process()
18:59:54.862 > ACK!
18:59:54.863 > ATR READ
18:59:54.863 > ->SIO write 128 bytes
18:59:54.863 > COMPLETE!
18:59:54.900 >
18:59:54.900 > CF: 31 52 1c 00 9f
18:59:54.900 > FujiNet CONFIG boot
18:59:54.900 > disk sio_process()
18:59:54.900 > ACK!
18:59:54.902 > ATR READ
18:59:54.902 > ->SIO write 128 bytes
18:59:54.902 > COMPLETE!
18:59:54.940 >
18:59:54.940 > CF: 31 52 1d 00 a0
18:59:54.940 > FujiNet CONFIG boot
18:59:54.940 > disk sio_process()
18:59:54.940 > ACK!
18:59:54.941 > ATR READ
18:59:54.941 > ->SIO write 128 bytes
18:59:54.941 > COMPLETE!
18:59:54.979 >
18:59:54.979 > CF: 31 52 1e 00 a1
18:59:54.979 > FujiNet CONFIG boot
18:59:54.979 > disk sio_process()
18:59:54.979 > ACK!
18:59:54.981 > ATR READ
18:59:54.981 > ->SIO write 128 bytes
18:59:54.981 > COMPLETE!
18:59:55.021 >
18:59:55.021 > CF: 31 52 1f 00 a2
18:59:55.021 > FujiNet CONFIG boot
18:59:55.021 > disk sio_process()
18:59:55.021 > ACK!
18:59:55.021 > ATR READ
18:59:55.021 > ->SIO write 128 bytes
18:59:55.021 > COMPLETE!
18:59:55.058 >
18:59:55.058 > CF: 31 52 20 00 a3
18:59:55.058 > FujiNet CONFIG boot
18:59:55.058 > disk sio_process()
18:59:55.058 > ACK!
18:59:55.060 > ATR READ
18:59:55.060 > ->SIO write 128 bytes
18:59:55.060 > COMPLETE!
18:59:55.098 >
18:59:55.098 > CF: 31 52 21 00 a4
18:59:55.098 > FujiNet CONFIG boot
18:59:55.098 > disk sio_process()
18:59:55.098 > ACK!
18:59:55.099 > ATR READ
18:59:55.099 > ->SIO write 128 bytes
18:59:55.099 > COMPLETE!
18:59:55.137 >
18:59:55.137 > CF: 31 52 22 00 a5
18:59:55.137 > FujiNet CONFIG boot
18:59:55.137 > disk sio_process()
18:59:55.137 > ACK!
18:59:55.139 > ATR READ
18:59:55.139 > ->SIO write 128 bytes
18:59:55.139 > COMPLETE!
18:59:55.181 >
18:59:55.181 > CF: 31 52 23 00 a6
18:59:55.181 > FujiNet CONFIG boot
18:59:55.181 > disk sio_process()
18:59:55.181 > ACK!
18:59:55.183 > ATR READ
18:59:55.183 > ->SIO write 128 bytes
18:59:55.183 > COMPLETE!
18:59:55.222 >
18:59:55.222 > CF: 31 52 24 00 a7
18:59:55.222 > FujiNet CONFIG boot
18:59:55.222 > disk sio_process()
18:59:55.222 > ACK!
18:59:55.224 > ATR READ
18:59:55.224 > ->SIO write 128 bytes
18:59:55.224 > COMPLETE!
18:59:55.262 >
18:59:55.262 > CF: 31 52 25 00 a8
18:59:55.262 > FujiNet CONFIG boot
18:59:55.262 > disk sio_process()
18:59:55.262 > ACK!
18:59:55.264 > ATR READ
18:59:55.264 > ->SIO write 128 bytes
18:59:55.264 > COMPLETE!
18:59:55.304 >
18:59:55.304 > CF: 31 52 26 00 a9
18:59:55.304 > FujiNet CONFIG boot
18:59:55.304 > disk sio_process()
18:59:55.304 > ACK!
18:59:55.306 > ATR READ
18:59:55.306 > ->SIO write 128 bytes
18:59:55.306 > COMPLETE!
18:59:55.347 >
18:59:55.347 > CF: 31 52 27 00 aa
18:59:55.347 > FujiNet CONFIG boot
18:59:55.347 > disk sio_process()
18:59:55.347 > ACK!
18:59:55.349 > ATR READ
18:59:55.349 > ->SIO write 128 bytes
18:59:55.349 > COMPLETE!
18:59:55.389 >
18:59:55.389 > CF: 31 52 28 00 ab
18:59:55.389 > FujiNet CONFIG boot
18:59:55.389 > disk sio_process()
18:59:55.389 > ACK!
18:59:55.391 > ATR READ
18:59:55.391 > ->SIO write 128 bytes
18:59:55.391 > COMPLETE!
18:59:55.425 >
18:59:55.425 > CF: 31 52 29 00 ac
18:59:55.425 > FujiNet CONFIG boot
18:59:55.425 > disk sio_process()
18:59:55.425 > ACK!
18:59:55.427 > ATR READ
18:59:55.427 > ->SIO write 128 bytes
18:59:55.427 > COMPLETE!
18:59:55.468 >
18:59:55.468 > CF: 31 52 2a 00 ad
18:59:55.468 > FujiNet CONFIG boot
18:59:55.468 > disk sio_process()
18:59:55.468 > ACK!
18:59:55.470 > ATR READ
18:59:55.470 > ->SIO write 128 bytes
18:59:55.470 > COMPLETE!
18:59:55.508 >
18:59:55.508 > CF: 31 52 2b 00 ae
18:59:55.508 > FujiNet CONFIG boot
18:59:55.508 > disk sio_process()
18:59:55.508 > ACK!
18:59:55.510 > ATR READ
18:59:55.510 > ->SIO write 128 bytes
18:59:55.510 > COMPLETE!
18:59:55.547 >
18:59:55.547 > CF: 31 52 2c 00 af
18:59:55.547 > FujiNet CONFIG boot
18:59:55.547 > disk sio_process()
18:59:55.547 > ACK!
18:59:55.549 > ATR READ
18:59:55.549 > ->SIO write 128 bytes
18:59:55.549 > COMPLETE!
18:59:55.588 >
18:59:55.588 > CF: 31 52 2d 00 b0
18:59:55.588 > FujiNet CONFIG boot
18:59:55.588 > disk sio_process()
18:59:55.588 > ACK!
18:59:55.590 > ATR READ
18:59:55.590 > ->SIO write 128 bytes
18:59:55.590 > COMPLETE!
18:59:55.626 >
18:59:55.626 > CF: 31 52 2e 00 b1
18:59:55.626 > FujiNet CONFIG boot
18:59:55.626 > disk sio_process()
18:59:55.626 > ACK!
18:59:55.627 > ATR READ
18:59:55.627 > ->SIO write 128 bytes
18:59:55.627 > COMPLETE!
18:59:55.663 >
18:59:55.663 > CF: 31 52 2f 00 b2
18:59:55.663 > FujiNet CONFIG boot
18:59:55.663 > disk sio_process()
18:59:55.663 > ACK!
18:59:55.665 > ATR READ
18:59:55.665 > ->SIO write 128 bytes
18:59:55.665 > COMPLETE!
18:59:55.702 >
18:59:55.702 > CF: 31 52 30 00 b3
18:59:55.702 > FujiNet CONFIG boot
18:59:55.702 > disk sio_process()
18:59:55.702 > ACK!
18:59:55.704 > ATR READ
18:59:55.704 > ->SIO write 128 bytes
18:59:55.704 > COMPLETE!
18:59:55.744 >
18:59:55.744 > CF: 31 52 31 00 b4
18:59:55.744 > FujiNet CONFIG boot
18:59:55.744 > disk sio_process()
18:59:55.744 > ACK!
18:59:55.746 > ATR READ
18:59:55.746 > ->SIO write 128 bytes
18:59:55.746 > COMPLETE!
18:59:55.784 >
18:59:55.784 > CF: 31 52 32 00 b5
18:59:55.784 > FujiNet CONFIG boot
18:59:55.784 > disk sio_process()
18:59:55.784 > ACK!
18:59:55.786 > ATR READ
18:59:55.786 > ->SIO write 128 bytes
18:59:55.786 > COMPLETE!
18:59:55.823 >
18:59:55.823 > CF: 31 52 33 00 b6
18:59:55.823 > FujiNet CONFIG boot
18:59:55.823 > disk sio_process()
18:59:55.823 > ACK!
18:59:55.825 > ATR READ
18:59:55.825 > ->SIO write 128 bytes
18:59:55.825 > COMPLETE!
18:59:55.861 >
18:59:55.861 > CF: 31 52 34 00 b7
18:59:55.861 > FujiNet CONFIG boot
18:59:55.861 > disk sio_process()
18:59:55.861 > ACK!
18:59:55.863 > ATR READ
18:59:55.863 > ->SIO write 128 bytes
18:59:55.863 > COMPLETE!
18:59:55.897 >
18:59:55.897 > CF: 31 52 35 00 b8
18:59:55.897 > FujiNet CONFIG boot
18:59:55.897 > disk sio_process()
18:59:55.897 > ACK!
18:59:55.899 > ATR READ
18:59:55.899 > ->SIO write 128 bytes
18:59:55.899 > COMPLETE!
18:59:55.941 >
18:59:55.941 > CF: 31 52 36 00 b9
18:59:55.941 > FujiNet CONFIG boot
18:59:55.941 > disk sio_process()
18:59:55.941 > ACK!
18:59:55.943 > ATR READ
18:59:55.943 > ->SIO write 128 bytes
18:59:55.943 > COMPLETE!
18:59:55.982 >
18:59:55.982 > CF: 31 52 37 00 ba
18:59:55.982 > FujiNet CONFIG boot
18:59:55.982 > disk sio_process()
18:59:55.982 > ACK!
18:59:55.984 > ATR READ
18:59:55.984 > ->SIO write 128 bytes
18:59:55.984 > COMPLETE!
18:59:56.025 >
18:59:56.025 > CF: 31 52 38 00 bb
18:59:56.025 > FujiNet CONFIG boot
18:59:56.025 > disk sio_process()
18:59:56.025 > ACK!
18:59:56.026 > ATR READ
18:59:56.026 > ->SIO write 128 bytes
18:59:56.026 > COMPLETE!
18:59:56.069 >
18:59:56.069 > CF: 31 52 39 00 bc
18:59:56.069 > FujiNet CONFIG boot
18:59:56.069 > disk sio_process()
18:59:56.069 > ACK!
18:59:56.071 > ATR READ
18:59:56.071 > ->SIO write 128 bytes
18:59:56.071 > COMPLETE!
18:59:56.110 >
18:59:56.110 > CF: 31 52 3a 00 bd
18:59:56.110 > FujiNet CONFIG boot
18:59:56.110 > disk sio_process()
18:59:56.110 > ACK!
18:59:56.112 > ATR READ
18:59:56.112 > ->SIO write 128 bytes
18:59:56.112 > COMPLETE!
18:59:56.153 >
18:59:56.153 > CF: 31 52 3b 00 be
18:59:56.153 > FujiNet CONFIG boot
18:59:56.153 > disk sio_process()
18:59:56.153 > ACK!
18:59:56.155 > ATR READ
18:59:56.155 > ->SIO write 128 bytes
18:59:56.155 > COMPLETE!
18:59:56.199 >
18:59:56.199 > CF: 31 52 3c 00 bf
18:59:56.199 > FujiNet CONFIG boot
18:59:56.199 > disk sio_process()
18:59:56.199 > ACK!
18:59:56.201 > ATR READ
18:59:56.201 > ->SIO write 128 bytes
18:59:56.201 > COMPLETE!
18:59:56.241 >
18:59:56.241 > CF: 31 52 3d 00 c0
18:59:56.241 > FujiNet CONFIG boot
18:59:56.241 > disk sio_process()
18:59:56.241 > ACK!
18:59:56.243 > ATR READ
18:59:56.243 > ->SIO write 128 bytes
18:59:56.243 > COMPLETE!
18:59:56.286 >
18:59:56.286 > CF: 31 52 3e 00 c1
18:59:56.286 > FujiNet CONFIG boot
18:59:56.286 > disk sio_process()
18:59:56.286 > ACK!
18:59:56.288 > ATR READ
18:59:56.288 > ->SIO write 128 bytes
18:59:56.288 > COMPLETE!
18:59:56.321 >
18:59:56.321 > CF: 31 52 3f 00 c2
18:59:56.321 > FujiNet CONFIG boot
18:59:56.321 > disk sio_process()
18:59:56.321 > ACK!
18:59:56.323 > ATR READ
18:59:56.323 > ->SIO write 128 bytes
18:59:56.323 > COMPLETE!
18:59:56.355 >
18:59:56.355 > CF: 31 52 40 00 c3
18:59:56.355 > FujiNet CONFIG boot
18:59:56.355 > disk sio_process()
18:59:56.355 > ACK!
18:59:56.357 > ATR READ
18:59:56.357 > ->SIO write 128 bytes
18:59:56.357 > COMPLETE!
18:59:56.389 >
18:59:56.389 > CF: 31 52 41 00 c4
18:59:56.389 > FujiNet CONFIG boot
18:59:56.389 > disk sio_process()
18:59:56.389 > ACK!
18:59:56.391 > ATR READ
18:59:56.391 > ->SIO write 128 bytes
18:59:56.391 > COMPLETE!
18:59:56.426 >
18:59:56.426 > CF: 31 52 42 00 c5
18:59:56.426 > FujiNet CONFIG boot
18:59:56.426 > disk sio_process()
18:59:56.426 > ACK!
18:59:56.428 > ATR READ
18:59:56.428 > ->SIO write 128 bytes
18:59:56.428 > COMPLETE!
18:59:56.461 >
18:59:56.461 > CF: 31 52 43 00 c6
18:59:56.461 > FujiNet CONFIG boot
18:59:56.461 > disk sio_process()
18:59:56.461 > ACK!
18:59:56.463 > ATR READ
18:59:56.463 > ->SIO write 128 bytes
18:59:56.463 > COMPLETE!
18:59:56.498 >
18:59:56.498 > CF: 31 52 44 00 c7
18:59:56.498 > FujiNet CONFIG boot
18:59:56.498 > disk sio_process()
18:59:56.498 > ACK!
18:59:56.500 > ATR READ
18:59:56.500 > ->SIO write 128 bytes
18:59:56.500 > COMPLETE!
18:59:56.535 >
18:59:56.535 > CF: 31 52 45 00 c8
18:59:56.535 > FujiNet CONFIG boot
18:59:56.535 > disk sio_process()
18:59:56.535 > ACK!
18:59:56.536 > ATR READ
18:59:56.536 > ->SIO write 128 bytes
18:59:56.536 > COMPLETE!
18:59:56.572 >
18:59:56.572 > CF: 31 52 46 00 c9
18:59:56.572 > FujiNet CONFIG boot
18:59:56.572 > disk sio_process()
18:59:56.572 > ACK!
18:59:56.574 > ATR READ
18:59:56.574 > ->SIO write 128 bytes
18:59:56.574 > COMPLETE!
18:59:56.609 >
18:59:56.609 > CF: 31 52 47 00 ca
18:59:56.609 > FujiNet CONFIG boot
18:59:56.609 > disk sio_process()
18:59:56.609 > ACK!
18:59:56.610 > ATR READ
18:59:56.610 > ->SIO write 128 bytes
18:59:56.610 > COMPLETE!
18:59:56.644 >
18:59:56.644 > CF: 31 52 48 00 cb
18:59:56.644 > FujiNet CONFIG boot
18:59:56.644 > disk sio_process()
18:59:56.644 > ACK!
18:59:56.646 > ATR READ
18:59:56.646 > ->SIO write 128 bytes
18:59:56.646 > COMPLETE!
18:59:56.684 >
18:59:56.684 > CF: 31 52 49 00 cc
18:59:56.684 > FujiNet CONFIG boot
18:59:56.684 > disk sio_process()
18:59:56.684 > ACK!
18:59:56.686 > ATR READ
18:59:56.686 > ->SIO write 128 bytes
18:59:56.686 > COMPLETE!
18:59:56.717 >
18:59:56.717 > CF: 31 52 4a 00 cd
18:59:56.717 > FujiNet CONFIG boot
18:59:56.717 > disk sio_process()
18:59:56.717 > ACK!
18:59:56.719 > ATR READ
18:59:56.719 > ->SIO write 128 bytes
18:59:56.719 > COMPLETE!
18:59:56.752 >
18:59:56.752 > CF: 31 52 4b 00 ce
18:59:56.752 > FujiNet CONFIG boot
18:59:56.752 > disk sio_process()
18:59:56.752 > ACK!
18:59:56.754 > ATR READ
18:59:56.754 > ->SIO write 128 bytes
18:59:56.754 > COMPLETE!
18:59:56.786 >
18:59:56.786 > CF: 31 52 4c 00 cf
18:59:56.786 > FujiNet CONFIG boot
18:59:56.786 > disk sio_process()
18:59:56.786 > ACK!
18:59:56.788 > ATR READ
18:59:56.788 > ->SIO write 128 bytes
18:59:56.788 > COMPLETE!
18:59:56.825 >
18:59:56.825 > CF: 31 52 4d 00 d0
18:59:56.825 > FujiNet CONFIG boot
18:59:56.825 > disk sio_process()
18:59:56.825 > ACK!
18:59:56.826 > ATR READ
18:59:56.826 > ->SIO write 128 bytes
18:59:56.826 > COMPLETE!
18:59:56.864 >
18:59:56.864 > CF: 31 52 4e 00 d1
18:59:56.864 > FujiNet CONFIG boot
18:59:56.864 > disk sio_process()
18:59:56.864 > ACK!
18:59:56.866 > ATR READ
18:59:56.866 > ->SIO write 128 bytes
18:59:56.866 > COMPLETE!
18:59:56.903 >
18:59:56.903 > CF: 31 52 4f 00 d2
18:59:56.903 > FujiNet CONFIG boot
18:59:56.903 > disk sio_process()
18:59:56.903 > ACK!
18:59:56.905 > ATR READ
18:59:56.905 > ->SIO write 128 bytes
18:59:56.905 > COMPLETE!
18:59:56.942 >
18:59:56.942 > CF: 31 52 50 00 d3
18:59:56.942 > FujiNet CONFIG boot
18:59:56.942 > disk sio_process()
18:59:56.942 > ACK!
18:59:56.943 > ATR READ
18:59:56.943 > ->SIO write 128 bytes
18:59:56.943 > COMPLETE!
18:59:56.976 >
18:59:56.976 > CF: 31 52 51 00 d4
18:59:56.976 > FujiNet CONFIG boot
18:59:56.976 > disk sio_process()
18:59:56.976 > ACK!
18:59:56.978 > ATR READ
18:59:56.978 > ->SIO write 128 bytes
18:59:56.978 > COMPLETE!
18:59:57.065 >
18:59:57.065 > CF: 00 38 00 00 f8
18:59:57.065 > CHECKSUM_ERROR
18:59:57.091 >
18:59:57.091 > CF: 00 38 00 00 f8
18:59:57.091 > CHECKSUM_ERROR
18:59:57.091 > Toggling baudrate from 67431 to 19200
18:59:57.093 > set_baudrate change from 67432 to 19200
18:59:57.128 >
18:59:57.128 > CF: 70 fe 00 00 6f
18:59:57.128 > sioFuji::sio_process() called
18:59:57.128 > ACK!
18:59:57.128 > Fuji cmd: GET SSID
18:59:57.130 > ->SIO write 96 bytes
18:59:57.130 > COMPLETE!
18:59:57.226 >
18:59:57.226 > CF: 70 e8 00 00 59
18:59:57.226 > sioFuji::sio_process() called
18:59:57.226 > ACK!
18:59:57.226 > Fuji cmd: GET ADAPTER CONFIG
18:59:57.228 > ->SIO write 139 bytes
18:59:57.228 > COMPLETE!
18:59:57.325 >
18:59:57.325 > CF: 70 fd 00 00 6e
18:59:57.325 > sioFuji::sio_process() called
18:59:57.325 > ACK!
18:59:57.325 > Fuji cmd: SCAN NETWORKS
18:59:57.326 > esp_wifi_scan_start returned error 12289
18:59:57.326 > ->SIO write 4 bytes
18:59:57.328 > COMPLETE!
19:00:25.697 >
19:00:25.697 > CF: 70 fb 01 00 6d
19:00:25.697 > sioFuji::sio_process() called
19:00:25.697 > ACK!
19:00:25.697 > Fuji cmd: SET SSID
19:00:25.698 > <-SIO read 96 bytes
19:00:25.755 > ACK!
19:00:25.755 > Connecting to net: private password: private
19:00:25.756 > WiFi connect attempt to SSID "private"
19:00:25.756 > ESP_ERROR_CHECK failed: esp_err_t 0x3001 (ESP_ERR_WIFI_NOT_INIT) at 0x4008f3e0
19:00:25.757 > file: "lib/hardware/fnWiFi.cpp" line 156
19:00:25.758 > func: int WiFiManager::connect(const char*, const char*)
19:00:25.759 > expression: esp_wifi_set_config(WIFI_IF_STA, &wifi_config)
19:00:25.759 >
19:00:25.759 > abort() was called at PC 0x4008f3e3 on core 1
19:00:25.760 >
19:00:25.760 > Backtrace:0x400910d2:0x3ffd4530 0x40091905:0x3ffd4550 0x40098699:0x3ffd4570 0x4008f3e3:0x3ffd45f0 0x400f051c:0x3ffd4610 0x400d971d:0x3ffd46c0 0x400db5ad:0x3ffd4750 0x400eeb99:0x3ffd4770 0x400eeca2:0x3ffd47b0 0x400d3e26:0x3ffd47d0 0x40095431:0x3ffd47f0
19:00:26.223 >   #0  0x400910d2:0x3ffd4530 in panic_abort at /home/bill/.platformio/packages/framework-espidf/components/esp_system/panic.c:356
19:00:26.223 >   #1  0x40091905:0x3ffd4550 in esp_system_abort at /home/bill/.platformio/packages/framework-espidf/components/esp_system/system_api.c:112
19:00:26.223 >   #2  0x40098699:0x3ffd4570 in abort at /home/bill/.platformio/packages/framework-espidf/components/newlib/abort.c:46
19:00:26.223 >   #3  0x4008f3e3:0x3ffd45f0 in _esp_error_check_failed at /home/bill/.platformio/packages/framework-espidf/components/esp_common/src/esp_err.c:42
19:00:26.223 >   #4  0x400f051c:0x3ffd4610 in WiFiManager::connect(char const*, char const*) at lib/hardware/fnWiFi.cpp:156 (discriminator 1)
19:00:26.223 >   #5  0x400d971d:0x3ffd46c0 in sioFuji::sio_net_set_ssid() at lib/device/sio/fuji.cpp:258
19:00:26.223 >   #6  0x400db5ad:0x3ffd4750 in sioFuji::sio_process(unsigned int, unsigned char) at lib/device/sio/fuji.cpp:1562
19:00:26.223 >   #7  0x400eeb99:0x3ffd4770 in sioBus::_sio_process_cmd() at lib/bus/sio/sio.cpp:225
19:00:26.223 >   #8  0x400eeca2:0x3ffd47b0 in sioBus::service() at lib/bus/sio/sio.cpp:333
19:00:26.223 >   #9  0x400d3e26:0x3ffd47d0 in fn_service_loop(void*) at src/main.cpp:237 (discriminator 1)
19:00:26.223 >   #10 0x40095431:0x3ffd47f0 in vPortTaskWrapper at /home/bill/.platformio/packages/framework-espidf/components/freertos/port/xtensa/port.c:168
19:00:26.223 >
19:00:26.223 >
19:00:26.223 > ELF file SHA256: 376c9b42aff8deb4
19:00:26.223 >
19:00:26.223 > Rebooting...
19:00:26.223 > �������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������
19:00:26.409 >
19:00:26.409 > --~--~--~--
19:00:26.409 > FujiNet 0.5.1a042314 2021-12-27 23:17:47 Started @ 5
19:00:26.410 > Starting heap: 4375851
19:00:26.425 > Detected Hardware Version: 1.0
19:00:26.575 > SPIFFS mounted.
19:00:26.661 > SD mounted.
19:00:26.661 > fnConfig::load
19:00:26.661 > Load fnconfig.ini from SD
19:00:26.664 > fnConfig::load read 599 bytes from config file
19:00:26.723 > SPIFFS Config Storage: Enabled
19:00:26.723 > fnConfig::load read 599 bytes from SPIFFS config file
19:00:26.725 > disk UNMOUNT
19:00:26.742 > disk MOUNT
19:00:26.742 > ATR MOUNT
19:00:26.742 > mounted ATR: paragraphs=5760, sect_size=128, sect_count=720, disk_size=0
19:00:26.743 > Creating a default printer using FS_SDFAT storage and type 1
19:00:26.744 > SSH client initialized.
19:00:26.744 > ModemSniffer::ModemSniffer(FS_SDFAT)
19:00:26.745 > SIO SETUP
19:00:26.745 > Set HSIO baud from 0 to 67431 (index 6), alt=68209
19:00:26.746 > Available heap: 4284411
19:00:26.746 > Setup complete @ 343 (338ms)
19:00:41.787 >
19:00:41.787 > CF: 70 fb 01 00 6d
19:00:41.787 > sioFuji::sio_process() called
19:00:41.787 > ACK!
19:00:41.787 > Fuji cmd: SET SSID
19:00:41.788 > <-SIO read 96 bytes
19:00:41.845 > ACK!
19:00:41.845 > Connecting to net: private password: private
19:00:41.846 > WiFi connect attempt to SSID "private"
19:00:41.846 > ESP_ERROR_CHECK failed: esp_err_t 0x3001 (ESP_ERR_WIFI_NOT_INIT) at 0x4008f3e0
19:00:41.847 > file: "lib/hardware/fnWiFi.cpp" line 156
19:00:41.848 > func: int WiFiManager::connect(const char*, const char*)
19:00:41.848 > expression: esp_wifi_set_config(WIFI_IF_STA, &wifi_config)
19:00:41.849 >
19:00:41.849 > abort() was called at PC 0x4008f3e3 on core 1
19:00:41.850 >
19:00:41.850 > Backtrace:0x400910d2:0x3ffd4550 0x40091905:0x3ffd4570 0x40098699:0x3ffd4590 0x4008f3e3:0x3ffd4610 0x400f051c:0x3ffd4630 0x400d971d:0x3ffd46e0 0x400db5ad:0x3ffd4770 0x400eeb99:0x3ffd4790 0x400eeca2:0x3ffd47d0 0x400d3e26:0x3ffd47f0 0x40095431:0x3ffd4810
19:00:42.284 >   #0  0x400910d2:0x3ffd4550 in panic_abort at /home/bill/.platformio/packages/framework-espidf/components/esp_system/panic.c:356
19:00:42.284 >   #1  0x40091905:0x3ffd4570 in esp_system_abort at /home/bill/.platformio/packages/framework-espidf/components/esp_system/system_api.c:112
19:00:42.284 >   #2  0x40098699:0x3ffd4590 in abort at /home/bill/.platformio/packages/framework-espidf/components/newlib/abort.c:46
19:00:42.284 >   #3  0x4008f3e3:0x3ffd4610 in _esp_error_check_failed at /home/bill/.platformio/packages/framework-espidf/components/esp_common/src/esp_err.c:42
19:00:42.284 >   #4  0x400f051c:0x3ffd4630 in WiFiManager::connect(char const*, char const*) at lib/hardware/fnWiFi.cpp:156 (discriminator 1)
19:00:42.284 >   #5  0x400d971d:0x3ffd46e0 in sioFuji::sio_net_set_ssid() at lib/device/sio/fuji.cpp:258
19:00:42.284 >   #6  0x400db5ad:0x3ffd4770 in sioFuji::sio_process(unsigned int, unsigned char) at lib/device/sio/fuji.cpp:1562
19:00:42.284 >   #7  0x400eeb99:0x3ffd4790 in sioBus::_sio_process_cmd() at lib/bus/sio/sio.cpp:225
19:00:42.284 >   #8  0x400eeca2:0x3ffd47d0 in sioBus::service() at lib/bus/sio/sio.cpp:333
19:00:42.284 >   #9  0x400d3e26:0x3ffd47f0 in fn_service_loop(void*) at src/main.cpp:237 (discriminator 1)
19:00:42.284 >   #10 0x40095431:0x3ffd4810 in vPortTaskWrapper at /home/bill/.platformio/packages/framework-espidf/components/freertos/port/xtensa/port.c:168
19:00:42.284 >
19:00:42.284 >
19:00:42.284 > ELF file SHA256: 376c9b42aff8deb4
19:00:42.284 >
19:00:42.284 > Rebooting...
19:00:42.284 > �������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������
19:00:42.499 >
19:00:42.499 > --~--~--~--
19:00:42.499 > FujiNet 0.5.1a042314 2021-12-27 23:17:47 Started @ 5
19:00:42.500 > Starting heap: 4375851
19:00:42.514 > Detected Hardware Version: 1.0
19:00:42.665 > SPIFFS mounted.
19:00:42.750 > SD mounted.
19:00:42.750 > fnConfig::load
19:00:42.750 > Load fnconfig.ini from SD
19:00:42.753 > fnConfig::load read 599 bytes from config file
19:00:42.813 > SPIFFS Config Storage: Enabled
19:00:42.813 > fnConfig::load read 599 bytes from SPIFFS config file
19:00:42.814 > disk UNMOUNT
19:00:42.832 > disk MOUNT
19:00:42.832 > ATR MOUNT
19:00:42.832 > mounted ATR: paragraphs=5760, sect_size=128, sect_count=720, disk_size=0
19:00:42.833 > Creating a default printer using FS_SDFAT storage and type 1
19:00:42.834 > SSH client initialized.
19:00:42.834 > ModemSniffer::ModemSniffer(FS_SDFAT)
19:00:42.835 > SIO SETUP
19:00:42.835 > Set HSIO baud from 0 to 67431 (index 6), alt=68209
19:00:42.836 > Available heap: 4284399
19:00:42.836 > Setup complete @ 343 (338ms)
