thomas3120 Posted December 15, 2021 Share Posted December 15, 2021 Looking at the datasheets. Would it be possible to add the Sony RGB encoder: Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted December 16, 2021 Share Posted December 16, 2021 Not directly. The 9928 outputs Y, R-Y and B-Y. Not RGB. There's a converter out there called TMS-RGB that will do the proper conversion though, and then you get RGBC out that ought to work with this chip. 1 Quote Link to comment Share on other sites More sharing options...
thomas3120 Posted January 2, 2022 Author Share Posted January 2, 2022 On 12/16/2021 at 4:45 AM, ChildOfCv said: Not directly. The 9928 outputs Y, R-Y and B-Y. Not RGB. There's a converter out there called TMS-RGB that will do the proper conversion though, and then you get RGBC out that ought to work with this chip. Thanks for the reply, I did some searching and found this: MC13077 encoder It has R-Y and B-Y inputs Here's the datasheet MC13077P.pdf Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted January 2, 2022 Share Posted January 2, 2022 21 minutes ago, thomas3120 said: Thanks for the reply, I did some searching and found this: MC13077 encoder It has R-Y and B-Y inputs Here's the datasheet MC13077P.pdf 249.52 kB · 2 downloads That chip only has composite or S-video outputs. If you want composite out, you can already use one of the composite out mods for CV to use its LM1889. This basically requires you to build the Motorola equivalent circuit for the same signal output. Quote Link to comment Share on other sites More sharing options...
