SteveB Posted January 16, 2022 Author Share Posted January 16, 2022 Even with the non-square noise it works better than expected. 10 CALL SOUND(2000,110,30,110,30,830,30,-4,0) 20 CALL SOUND(2000,110,0,110,30,830,30,-4,0) 30 CALL SOUND(2000,110,0,220,0) The overlay 55/110 is not much more "instable" than the 110/220 Hz, just a little more "humming". I would rather use this in a game than in the MuseScore for now. 3 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted January 17, 2022 Share Posted January 17, 2022 Excellent. I was working with LMMS doing much the same. ? 1 Quote Link to comment Share on other sites More sharing options...
globeron Posted January 22, 2022 Share Posted January 22, 2022 Very nice program! I never came very far with Music Maker, but this makes music fun again on the TI 2 Quote Link to comment Share on other sites More sharing options...
XLERB Posted April 26, 2022 Share Posted April 26, 2022 I just installed it and it looks great, and works great with the sample music. Thank you! This makes things a lot simpler and more fun when it comes to TI music. My question: I haven't used MuseScore before, and I would like to use it on an older 32 bit Windows computer that I keep for Classic99 and other non-work stuff. But the newest version of MuseScore that I can run is version 2 - not 3. Will that cause any compatibility problems with your program? I figure if everything is saved in MusicXML format, it should work, correct? I know should try it before I ask, but... 1 Quote Link to comment Share on other sites More sharing options...
SteveB Posted April 26, 2022 Author Share Posted April 26, 2022 Hi Paul, I did not test the MuseScore 2.x version, but in general any uncompressed MusicXML should work. But I think the current 3.x version is also available in 32bit Windows: https://musescore.org/de/download/musescore-32bit.msi This should work in 32bit Windows 7 and is version 3.6.2. 2 Quote Link to comment Share on other sites More sharing options...
XLERB Posted April 26, 2022 Share Posted April 26, 2022 3 hours ago, SteveB said: Hi Paul, I did not test the MuseScore 2.x version, but in general any uncompressed MusicXML should work. But I think the current 3.x version is also available in 32bit Windows: https://musescore.org/de/download/musescore-32bit.msi This should work in 32bit Windows 7 and is version 3.6.2. Thanks! Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted April 26, 2022 Share Posted April 26, 2022 (edited) I done some trials but no luck for the moment ? the only one almost good is GALAGA's jingle Galaga.xml GALAGAJNGL The other ones I have tried give me too much errors of transposing notes and the melody change too much. like these ones: Knight Rider - Theme Tune.xml Rodland.xml Star Trek - Theme Tune.xml maybe I should take a better look to the manual to discover some secrets ? Edited April 26, 2022 by ti99iuc 2 Quote Link to comment Share on other sites More sharing options...
XLERB Posted April 27, 2022 Share Posted April 27, 2022 Uh-oh, my two life-eating interests have collided: Fiddle tunes and the TI99/4A. I can now import 650,000 tunes in musicxml format and convert them to sound programs for the TI. “Kesh Jig” was the first. Only 649,999 to go… 1 5 Quote Link to comment Share on other sites More sharing options...
SteveB Posted April 27, 2022 Author Share Posted April 27, 2022 23 hours ago, ti99iuc said: maybe I should take a better look to the manual to discover some secrets ? Always a good idea ... if you do not enjoy saving 10 minutes of reading by trying something for two hours... Very brief: No sounds below 110 Hz Maximum of 3 simultanious sounds / voices ... chords are lava! 3 Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted April 27, 2022 Share Posted April 27, 2022 (edited) Thanks I just watched your video example and followed the explained steps thinking it was fast and easy to do a conversion. I just thought that a not too complex midi was already sufficient for an easy conversion, instead not, or at least not always it is possible for a fast conversion, for the Galaga jingle, it was good. Read and understand the manual is a bit more complicated for me but I will do a try of course Edited April 27, 2022 by ti99iuc 4 Quote Link to comment Share on other sites More sharing options...
SteveB Posted May 1 Author Share Posted May 1 In January the MuseScore team released version 4 with a lot of changes and improvements. I revised the documentation for MuseScore 4 and added two features: Auto-Copy to Clipboard is now an option (as suggested by @Vorticon) Create XB256 Soundlists to be played in the background of program Harry @senior_falcon helped me very much in getting this to work. Please be aware, this option provides only very basic soundlist-functionality: Play the list once or in endless repetition. For more complex arrangements use the very versatile SLCOMPILER tool from Harry included in XB256, where you can have muliple, named sections and finite loops etc. and can pack multiple soundlists into one binary. I use the BIN$() pseudo-function of LibXBTKN to get the 8bit binary soundlist to the TI. During tokenization, the BIN$("hex-string") gets replaced with the binary representation of the supplied hex-string, i.e. PRINT BIN$("424344") gets saved as PRINT "ABC". Therefore you should use the "Export to FIAD" for saving the XB256 Soundlist (requires line-numbers to be enabled to have a valid XB program) or copy the created code over to TiCodEd, where BIN$ also works. The EXAMPLE256 is the FIAD soundlist of the provided example. Enjoy! TI-MuseScore4a_V11.zip 7 Quote Link to comment Share on other sites More sharing options...
SteveB Posted May 2 Author Share Posted May 2 On 5/1/2023 at 3:01 PM, SteveB said: PRINT BIN$("424344") gets saved as PRINT "ABC" Correction: PRINT BIN$("414243") gets saved as PRINT "ABC" ... you get the idea ... >00, >0B, >0D, >FF all have special meanings, but are not interpreted by the TI in a quoted string. The preceding length byte makes control characters superfluous. 1 Quote Link to comment Share on other sites More sharing options...
