RetroB1977 Posted January 17, 2022 Share Posted January 17, 2022 I'm trying to load the Comaland demo from my SD2IEC. I used the normal process I use to load multiple disk games, but it didn't work. Here are my steps: - Generate AUTOSWAP.LST by pushing both buttons. - Press Q - Press the next disk button - LOAD"*",8,1 - RUN (At this point the disk error light flashes and my C64 locks up) Anyone see my mistake? Quote Link to comment Share on other sites More sharing options...
bjonte Posted January 17, 2022 Share Posted January 17, 2022 The mistake is probably that you’re using SD2IEC. It doesn’t replicate the CPU in the drive that demos use to communicate with in order to load in the background without hickups. 1 Quote Link to comment Share on other sites More sharing options...
RetroB1977 Posted January 17, 2022 Author Share Posted January 17, 2022 1 minute ago, bjonte said: The mistake is probably that you’re using SD2IEC. It doesn’t replicate the CPU in the drive that demos use to communicate with in order to load in the background without hickups. Okay. I thought I heard the demo was compatible. Quote Link to comment Share on other sites More sharing options...
bjonte Posted January 17, 2022 Share Posted January 17, 2022 Okay. I thought I heard the demo was compatible. Well, it could be. It’s just unlikely. If you can load the first file and start it but the demo locks up when it starts then I’d say it’s not compatible. Quote Link to comment Share on other sites More sharing options...
RetroB1977 Posted January 17, 2022 Author Share Posted January 17, 2022 (edited) 2 minutes ago, bjonte said: Well, it could be. It’s just unlikely. If you can load the first file and start it but the demo locks up when it starts then I’d say it’s not compatible. Oh well, thanks for your help. Is there another disk drive solution you recommend? Edited January 17, 2022 by RetroB1977 Quote Link to comment Share on other sites More sharing options...
hofster Posted January 18, 2022 Share Posted January 18, 2022 Oh well, thanks for your help. [emoji4] Is there another disk drive solution you recommend?I mostly use Pi1541. It's more of a true 1541 emulator so most fastloaders and disk tools should work. There may of course still be bugs that prevent particular fast loaders from working. 1 Quote Link to comment Share on other sites More sharing options...
bjonte Posted January 19, 2022 Share Posted January 19, 2022 Oh well, thanks for your help. [emoji4] Is there another disk drive solution you recommend?The ultimate solution is still the 1541 ultimate series if you need a modern mass storage device. 1541 Ultimate. 1541 Ultimate II or 1541 Ultimte II+. That’s my recommendation until Pi1541 gets better. Quote Link to comment Share on other sites More sharing options...
