Tempest Posted January 18, 2022 Share Posted January 18, 2022 One of the main things that keeps me from going from real systems to emulation is the fact that I like to use the original systems controllers rather than a generic gamepad or keyboard. How many classic systems have a controller to USB type device that can be used with emulators? For example, is there a NES pad to USB device? SNES pad? Genesis pad? Is there one that does multiple systems (the thought of buying 15+ controller devices sounds expensive)? I have the Stelladpter so my 2600 needs at met anyway Quote Link to comment Share on other sites More sharing options...
mr_me Posted January 18, 2022 Share Posted January 18, 2022 Almost everything is covered, even things like Channel F and Astrocade have USB adaptors. You could ask which controllers don't have usb adaptors. Adaptors like the 2600-daptor or the Retronic USB cover most DE9 based controllers including the Sega Genesis. Quote Link to comment Share on other sites More sharing options...
Forrest Posted January 24, 2022 Share Posted January 24, 2022 There is an inexpensive NES, SNES and Genesis to USB adapter on Tindie Link Quote Link to comment Share on other sites More sharing options...
Trebor Posted January 24, 2022 Share Posted January 24, 2022 On 1/18/2022 at 9:52 AM, Tempest said: I have the Stelladpter so my 2600 needs at met anyway If you have or acquire the D9 version, then the following systems and respective controllers are covered: Atari 2600 Joystick/Driving (driving may be miss-detected, use joystick or paddles, then swap to driving) Atari 2600 Paddles, both paddles work (paddle #1 button) Atari 2600 Keypads - Keyboard Controller, Video Touch Pad aka Star Raiders, Kids Controller Atari 2800/Sears Video Arcade II (either side button, knob towards center) Atari 7800 Pro-line, CX78 gamepad Atari CX22 & CX80 Trak-balls, native mode (selected via switches) Atari CX85 Numeric Keypad Atari Flashback 1 Atari Flashback 9/X w/ 4 special function buttons (REWIND) Atari ST mouse (selected via switches) Amiga mouse (selected via switches) Amiga CD32 Bally Astrocade CBS Booster Grip for 2600 (grip switch, not thumb switch) Cheetah Annihilator (both base button and either stick button) ColecoVision, original & flashback, Super Action including spinner, Driving Controller Commodore Paddles, both paddles work (hold both paddle #1 and #2 buttons) Fairchild Channel F (push down) Famiclone - with adapter cables: NES/SNES/Famicom/Super Famicom gamepads, HVC-051/NTT network pads, SNES mouse (A+B to swap A/B X/Y) - see section below* FM Towns Marty (FMM-PAD301 - also hold shoulder) Gemini Dual Command (knob towards center) Intellivision, original & flashback - dongle available for using INTV-1 controllers without having to modify the cable Magnavox Odyssey 2 MSX & x68000 (both buttons 1 & 2) QuadTari - appears as 2 USB joysticks (fire on joystick 1 for A, joystick 2 for B) Sega Genesis: 3 & 6 button d-pad & arcade stick (gamepad "A", but can also use "START" for backwards compatibility) Sega Master System: d-pad, Sports Pad in both Control & Sports modes, Paddle Control HPD-200 (selected via switches) Sinclair ZX Spectrum (joystick down) TI-99/4A - both joysticks (button on joystick #1) 3DO - and one controller in extension jack (press "A" on 2nd controller to appear as 2 PC USB joysticks) XPD-1LR - right d-pad on Rx/Ry (hold right d-pad left) *For Famiclone, NES, SNES, Famicom, Super Famicom, an adapter cable is needed: 1 Quote Link to comment Share on other sites More sharing options...
Tempest Posted January 24, 2022 Author Share Posted January 24, 2022 That's the one I have. Looks like I just need to find something for Nintendo controllers and I should be all set. 1 Quote Link to comment Share on other sites More sharing options...
Trebor Posted January 24, 2022 Share Posted January 24, 2022 3 minutes ago, Tempest said: That's the one I have. Looks like I just need to find something for Nintendo controllers and I should be all set. http://www.2600-daptor.com/index.htm Quote Link to comment Share on other sites More sharing options...
ClassicGMR Posted January 24, 2022 Share Posted January 24, 2022 I really enjoy having the "real controller" feel while gaming so I chose this route. Here's what I use in my arcade cabinet: Atari 2600 - 2600-daptor II Intellivision / ColecoVision - vision-daptor x2 (1 for each system) Nintendo NES - Retrolink USB adapter Nintendo SNES - Super Nintendo Smartjoy adapter Playstation 1/2 - EAXUS PS to PC 2-port adapter XBox controller - Rock Candy wired XBox 360 controller Arcade - X-Arcade Tankstick with trackball All of the adapters are connected through a USB 3.0 powered hub and 3.0 port. None of it USES 3.0 - nor even benefits from it I believe - but if you have the ports why not connect to them? Keep in mind most of this stuff I have had for a very long time so there are more current items out there. Everything still works though! Quote Link to comment Share on other sites More sharing options...
Tempest Posted January 24, 2022 Author Share Posted January 24, 2022 5 minutes ago, ClassicGMR said: I really enjoy having the "real controller" feel while gaming so I chose this route. Here's what I use in my arcade cabinet: Atari 2600 - 2600-daptor II Intellivision / ColecoVision - vision-daptor x2 (1 for each system) Nintendo NES - Retrolink USB adapter Nintendo SNES - Super Nintendo Smartjoy adapter Playstation 1/2 - EAXUS PS to PC 2-port adapter XBox controller - Rock Candy wired XBox 360 controller Arcade - X-Arcade Tankstick with trackball All of the adapters are connected through a USB 3.0 powered hub and 3.0 port. None of it USES 3.0 - nor even benefits from it I believe - but if you have the ports why not connect to them? Keep in mind most of this stuff I have had for a very long time so there are more current items out there. Everything still works though! That helps. Thank you. 1 Quote Link to comment Share on other sites More sharing options...
Leonard Smith Posted January 25, 2022 Share Posted January 25, 2022 As a testimonial, I've been using a standard 2600-daptor for about a year now and I highly recommend it for 2600 and 7800 games. I detect no lag and it's 100% plug and play on a Windows 10 system. Highly recommended if you're on the fence. 1 Quote Link to comment Share on other sites More sharing options...
0078265317 Posted January 26, 2022 Share Posted January 26, 2022 I have one of these. Nes classic to usb And then a Wii classic controller on top of that. Works for nes and sees. Quote Link to comment Share on other sites More sharing options...
