donnerkuh Posted January 18, 2022 Share Posted January 18, 2022 I want to creat a small song, changing a note after a few seconds. In my example the change is much to early. I can loop as long as i want, it does not change. Is there a way to change the note after 1 or 2 seconds. Or is my code not ok? If someone can help me? soundtest.bas.bin Quote Link to comment https://forums.atariage.com/topic/329933-set-note-length/ Share on other sites More sharing options...
+Al_Nafuur Posted January 18, 2022 Share Posted January 18, 2022 17 minutes ago, donnerkuh said: I want to creat a small song, changing a note after a few seconds. In my example the change is much to early. I can loop as long as i want, it does not change. Is there a way to change the note after 1 or 2 seconds. Or is my code not ok? If someone can help me? soundtest.bas.bin 4 kB · 1 download You should post your code too, this would help a lot 1 Quote Link to comment https://forums.atariage.com/topic/329933-set-note-length/#findComment-4987168 Share on other sites More sharing options...
+Random Terrain Posted January 18, 2022 Share Posted January 18, 2022 Have you played around with this example program: https://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#ex_sound_with_bg_music 1 Quote Link to comment https://forums.atariage.com/topic/329933-set-note-length/#findComment-4987171 Share on other sites More sharing options...
donnerkuh Posted January 18, 2022 Author Share Posted January 18, 2022 (edited) of course Al_Nafuur. Here it is: soundtest.bas Edited January 18, 2022 by donnerkuh Quote Link to comment https://forums.atariage.com/topic/329933-set-note-length/#findComment-4987244 Share on other sites More sharing options...
