Gatherer of Data Posted January 24, 2022 Share Posted January 24, 2022 It was my understanding that colors should be consistent when you switch PAL and NTSC output on a console when connected through RGB, so it's really mostly a 50/60 Hz respectively resolution switch. Hence the "Tint" control has no effect. I do get different colors however, but the behavior is inconsistent between displays. I've tested this recently mostly with a PAL Playstation 2. When switching from PAL to NTSC output, the reds get notably more intense on two CRTs of mine. This does not happen on a Sony LCD I tested with. Cable used is the same for all of these (RGB Scart of course). Tint control has as expected no effect. So what is going on, is it wrong that there is no color encoding going on, or is something faulty? Quote Link to comment Share on other sites More sharing options...
