Bobo Cujo Posted February 1 Share Posted February 1 (edited) Regarding Hawkquest Joy2B: There's two preceding "original" versions: 1) The original 4-disk version 2) The Atarimax 1MB(8mbit) cart version by @playsoft per this thread: @mytek @Peruchi@Mr Robot Did you try version #2 above, or just #1? Assuming that the non-Joy2B Atarimax cart version works and the Joy2B one doesn't, there's a few things that may come to mind: 1) @playsoft mentioned in the post below that there was a bug that sometimes caused the game to not boot on real hardware; I patched in the proposed fix into the Joy2B release (I don't think it's in the original Atarimax cart release). It may be possible that something about it is causing issues with 576NUC (or I implemented it incorrectly)? 2) One of the big differences between the original disk version and the Atarimax version is the usage of the >48K memory map (E000-FFFF, AKA the OS ROM space). The extra code for Joy2B support (which was a more involved hack than the other Joy2B hacks I made) involves even more extra code in the OS ROM space. I can't imagine that it would cause problems since that part of ram should be fully banked in (and the OS ROM banked out), but just in case, could that be causing issues with 576NUC memory management? From my original notes (pardon the lack of comments; the key thing is where I located things in memory...): ;-------------------------------------------------- ; New Button 2 handler (in OS RAM space) ;-------------------------------------------------- ; E965: Button 2 debouncing value E966: AD 70 02 lda PADDL0 E969: C9 E4 cmp #$e4 E96B: D0 0D BNE $E97A E96D: AD 65 E9 lda $E965 E970: D0 0D BNE $E97F E972: A9 01 lda #$01 E974: 8D 65 E9 sta $E965 E977: 4C 9E 85 JMP $859E E97A: A9 00 lda #$00 E97C: 8D 65 E9 sta $E965 E97F: 60 RTS ;-------------------------------------------------- ; New, relocated Custom Immediate VBLANK handler (the call to setting SETVBV needs to be set to the new address too) ;-------------------------------------------------- F2E0: AD 00 D3 LDA PORTA ; $FE380 in the rom, $E965 in system memory F2E3: 29 0F AND #$0F ; ($FED40 in rom/$F2DF in system) is where free space begins) F2E5: 8D 78 02 STA STICK0 F2E8: AD 10 D0 LDA TRIG0 F2EB: 8D 84 02 STA STRIG0 F2EE: AD 00 D2 lda POT0 F2F1: 8D 0B D2 STA POTGO F2F4: 8D 70 02 STA PADDL0 F2F7: A9 01 LDA #$01 F2F9: 8D 16 E8 STA $E816 F2FC: AD 18 02 LDA CDTMV1 F2FF: F0 08 BEQ $E985 F301: CE 18 02 DEC CDTMV1 F304: D0 03 BNE $E985 F306: 20 C2 E9 JSR $E9C2 ;[expand] F309: AD 1A 02 LDA CDTMV2 F30C: F0 08 BEQ $E992 F30E: CE 1A 02 DEC CDTMV2 F311: D0 03 BNE $E992 F313: 20 C5 E9 JSR $E9C5 ;[expand] F316: AD 1C 02 LDA CDTMV3 F319: F0 0A BEQ $E9A1 F31B: CE 1C 02 DEC CDTMV3 F31E: D0 05 BNE $E9A1 F320: A9 00 LDA #$00 F322: 8D 2A 02 STA CDTMF3 F325: AD 1E 02 LDA CDTMV4 F328: F0 0A BEQ $E9B0 F32A: CE 1E 02 DEC CDTMV4 F32D: D0 05 BNE $E9B0 F32F: A9 00 LDA #$00 F331: 8D 2C 02 STA CDTMF4 F334: AD 20 02 LDA CDTMV5 F337: F0 0A BEQ $E9BF F339: CE 20 02 DEC CDTMV5 F33C: D0 05 BNE $E9BF F33E: A9 00 LDA #$00 F340: 8D 2E 02 STA CDTMF5 F343: 6C 24 02 JMP (VVBLKD) ;-------------------------------------------------- ;As pointed out by Paul Lay, replace the following mutexes to fix a bug from the original cart release: AD 0E D4 LDA NMIEN 48 PHA ;with: A9 40 LDA #$40 48 PHA EA NOP ;-------------------------------------------------- And finally, for those wondering: I tested Hawkquest Joy2B on an actual NTSC 800XL and in Altirra; I didn't test this on other systems (I don't even have NTSC 128K Ataris anymore ? ) Edited February 1 by Bobo Cujo Quote Link to comment Share on other sites More sharing options...
+playsoft Posted February 1 Share Posted February 1 Could the issue be trying to binary load an AtariMaxFlash 1MB cart image? The HQ file posted earlier has the wrong filename extension, it should be a .car file. Altirra is able to load it (as a 1MB AtariMaxFlash cart) because it recognises that the first 16 bytes are a CART header. I don't know what support 576NUC+ has for carts. 2 Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted February 1 Share Posted February 1 5 hours ago, Bobo Cujo said: Regarding Hawkquest Joy2B: There's two preceding "original" versions: 1) The original 4-disk version 2) The Atarimax 1MB(8mbit) cart version by @playsoft per this thread: @mytek @Peruchi@Mr Robot Did you try version #2 above, or just #1? I tried both on emulation with varying memory configs and they both worked, I haven't tried the cart version on a real NUC, so far all my testing has been using a fujinet. I'll try the cart version when I get home from work tonight, @Peruchi probably can't test a cart version as there are only a couple of people who have cart ports on their NUCs. 1 Quote Link to comment Share on other sites More sharing options...
Peruchi Posted February 1 Author Share Posted February 1 As @Mr Robot stated, I don't have the cart expander board for the NUC, so I can't properly test the 1MB image of the game "Hawkquest". It seems that @playsoft got the right answer to the problem, maybe the file should have a .car extension, not .xex, and an update on the github page would be applicable: I tested on my NUC the original 4-disk version, as mentioned by @Bobo Cujo. I wish I could understand all the machine language code he provided, but, alas, I'm just an enthusiast of the A8, not more than that ? Quote Link to comment Share on other sites More sharing options...
+mytek Posted February 1 Share Posted February 1 I'm far from an expert on 576NUC+ extended memory since the design and the jed file used in the EMMU are not my doing. However the base 64K memory should be the same from a functionality point of view as a stock XL/XE computer. As for carts, the stock 576NUC+ is a SIO-centric computer and does not provide a cart port without a custom daughter board designed by @Mr Robot which as he mentioned there not many of those presently in the wild. So all 576NUC+ tests of these Joy2B+ games needs to be done with either ATRs or XEX versions. 1 Quote Link to comment Share on other sites More sharing options...
StickJock Posted February 1 Share Posted February 1 11 hours ago, Bobo Cujo said: ;-------------------------------------------------- ; New Button 2 handler (in OS RAM space) ;-------------------------------------------------- ; E965: Button 2 debouncing value E966: AD 70 02 lda PADDL0 E969: C9 E4 cmp #$e4 E96B: D0 0D BNE $E97A E96D: AD 65 E9 lda $E965 E970: D0 0D BNE $E97F E972: A9 01 lda #$01 E974: 8D 65 E9 sta $E965 E977: 4C 9E 85 JMP $859E E97A: A9 00 lda #$00 E97C: 8D 65 E9 sta $E965 E97F: 60 RTS Unless whatever is at $859E is depending on the value of A or the flags, you can save a couple of bytes here by replacing the LDA $01 STA $e965 instruction pair at $E972 with a single INC $E965 since the previous two instructions (LDA $E965 BNE $E97F) mean that both A and $E965 must be 0 at this point. The LDA + STA take 6 cycles, the same as the INC, so there is no CPU time savings, but hey, two bytes is two bytes! Again, this optimization depends upon whatever is at the destination of the JMP $859E. If it does not rely on A or the flags, then this is a safe code change. 1 Quote Link to comment Share on other sites More sharing options...
Bobo Cujo Posted February 2 Share Posted February 2 The Joy2B version of Hawkquest was never made in 1MB .xex form; it was only made available in .car (Atarimax cartridge) form. If that was made into an .xex, it would definitely explain why the game didn't boot ? To my knowledge, I don't think non-Joy2B Hawkquest ever made it to an .xex version either... (for those wondering: I didn't make a Joy2B version of the original 4-disk version, since it lacks NTSC compatibility) 3 Quote Link to comment Share on other sites More sharing options...
+mytek Posted February 2 Share Posted February 2 11 hours ago, Bobo Cujo said: The Joy2B version of Hawkquest was never made in 1MB .xex form; it was only made available in .car (Atarimax cartridge) form. If that was made into an .xex, it would definitely explain why the game didn't boot ? Considering that the NUC only has 576K it wouldn't matter if a 1MB version had been made Quote Link to comment Share on other sites More sharing options...
ascrnet Posted March 1 Share Posted March 1 On 2/1/2022 at 11:05 AM, Peruchi said: I confirm it was wrong the file extension should be .car, I updated the github. ? 1 Quote Link to comment Share on other sites More sharing options...
