TGB1718 Posted January 28, 2022 Share Posted January 28, 2022 I set debug mode in Altirra, I load my program into memory, Open the Source Files, press F8 so that I can use the command line, set the program counter to the start of my program, open a memory window to watch data I'm interested in. Then using the 't' command (one step) I start stepping through the program (just press <return> after the first 't', but this happens every time after a load.:- Altirra> r pc 2000 Altirra> t (337783:248, 3) A=00 X=FF Y=00 S=EF P=33 ( ZC) 2002: 8D F5 21 STA $21F5 [$21F5] Altirra> (337783:248, 7) A=00 X=FF Y=00 S=EF P=33 ( ZC) 2005: 8D F6 21 STA $21F6 [$21F6] Altirra> (337783:248, 11) A=00 X=FF Y=00 S=EF P=33 ( ZC) 2008: A9 00 LDA #$00 Altirra> (337783:248, 18) A=00 X=FF Y=00 S=EC P=37 ( IZC) C018: 2C 0F D4 BIT NMIST [$D40F] = $5F It jumps from my program to C018, if I reset the program counter back to (in this case 2008) I can continue to use the 't' command and them press return and it works forever. I know the step is F11, but just pressing return should still work ? Or am I just doing it wrong ? Quote Link to comment Share on other sites More sharing options...
mellis Posted January 28, 2022 Share Posted January 28, 2022 Sure seems like you are observing an interrupt firing, and as a result, you are being carried into the OS. Quote Link to comment Share on other sites More sharing options...
