Can you INC a BCD number?
Just started playing with MAC/65, OMG I wish I had this as a kid! DDT is amazeballs! Anyway, check this out:
10 .ORG $4000
20 .FLOAT 123456789
30 SED
40 INC $4005
When you ASM this and look at $4000, you have:
44 01 23 45 67 89
Now G 4006. This will SED into BCD mode and then increment the last number. The result is:
44 01 23 45 67 8A
THAT'S interesting! Did I miss a step here? Or does the 6502 simply not consider BCD in INC?
12 hours ago, Maury Markowitz said:
44 01 23 45 67 8A
Yup, reading the 6502 specifications for one thing. (-; The decimal flag is only honored by ADC and SBC, and thus not by INC and DEC. If you want to increment a BCD number, the only option is ADC. Or performing a half-carry check manually.
Another thing - you're generally working on numbers greater than 2 figures so would want to carry over to the next significant set of digits.
INC works OK there since you can just do a BEQ to INC the next significant byte.
But with DEC you don't have a single flag to indicate you've underflowed from 00 to FF - so you'd probably end up doing more work than the SEC/SBC operation (for subtracting single-byte constants at least).  With SBC of a single byte value you could do a BCS to skip the next significant byte.
Instead I first check if the number is less than 99, at which point a carry is impossible and INC works fine.
10 hours ago, Rybags said:
But alternatively you could just use binary then look for quick unsigned bin->BCD conversion routines.
If speed is not too much of an issue, use the internal FP routines, I wrote a couple of disk copiers bitd
and wrote the current sector to screen using FP routines which were fast enough to update the
screen between sectors.
The current Sector was in DAUX1 and DAUX2, copy them to $D4  and $D5
call IFP to convert to FP
call FASC to convert to ASCII
if you want to put the ASCII directly to screen subtract $20 from each character,
last character has high bit set, so AND #$7f, then subtract $20
BCD INC in baroque style
     lax BCD
     jsr Baroque_BCD_INC
     sax BCD
     jmp *
BCD .HE 89
Baroque_BCD_INC
     and #$F0
     cmp #$90
     php
     txa
     and #$0F
     cmp #$09
     php
     txa
     sbx #$100-$01
     plp
     txa
     bcs @+
     plp
     rts
@    sbx #$100-$06
     txa
     plp
     bne @+
     ldx #$00
@    rts
Edited by xxl
1 hour ago, ivop said:
Why? All official Atari 8-bit computers run that code just fine. Even Bill Mensch calls them undocumented opcodes. They are not illegal or not allowed or something.
https://ataripodcast.libsyn.com/antic-interview-96-bill-mensch-6502-chip
Upgraded computers may not run properly, though.
That's the joke!
