+Pac-Lander Posted February 4, 2022 Share Posted February 4, 2022 Hello! I am looking for the ROM of "Adventure II" on the 5200 for OpenEmu for MacOS. Does this exist? Many thanks in advance! Quote Link to comment Share on other sites More sharing options...
+Cafeman Posted February 4, 2022 Share Posted February 4, 2022 http://cafeman.www9.50megs.com/atari/5200dev/AdventureII.html Grab the 2 ROMs dated May 2007. Quote Link to comment Share on other sites More sharing options...
+Pac-Lander Posted February 4, 2022 Author Share Posted February 4, 2022 42 minutes ago, Cafeman said: http://cafeman.www9.50megs.com/atari/5200dev/AdventureII.html Grab the 2 ROMs dated May 2007. Thank you for your reply! However, these are .bin files (adv2a.bin), and I believe OpenEMU plays .a52 ROM files. In any event, I am getting this error (see screenshot): Quote Link to comment Share on other sites More sharing options...
+Cafeman Posted February 4, 2022 Share Posted February 4, 2022 Yes, the emulator needs the 5200 BIOS ROM file to be in the BIOS directory or Folder it is pointing at. Google it and you'll find sites that have it. Not sure why it must use games with the .a52 extension, but if this is true, try renaming adv2a.bin to adv2a.a52. Internally it should be the same. Here is a similar thread question, 1 Quote Link to comment Share on other sites More sharing options...
+Pac-Lander Posted February 4, 2022 Author Share Posted February 4, 2022 7 minutes ago, Cafeman said: Yes, the emulator needs the 5200 BIOS ROM file to be in the BIOS directory or Folder it is pointing at. Google it and you'll find sites that have it. Not sure why it must use games with the .a52 extension, but if this is true, try renaming adv2a.bin to adv2a.a52. Internally it should be the same. Here is a similar thread question, Worked like a charm! Thank you! ? 1 Quote Link to comment Share on other sites More sharing options...
0078265317 Posted February 5, 2022 Share Posted February 5, 2022 I download both bin files from 2007. No mods needed it works just fine straight out of the box. I already found the bios a while ago. So did not need that. Everything else was fine. Just say resolve issue then select 5200 and import and walla. Quote Link to comment Share on other sites More sharing options...
leech Posted February 9, 2022 Share Posted February 9, 2022 Hmm, I need to rebuild my 5200 Controllers and plug them into that iCode device and see if I can play it through OpenEmu. Started that process, so got the gold ones (rev10) just haven't had the time to finish that up! Quote Link to comment Share on other sites More sharing options...
