Forth Fun: SNAKE!
Willsy
Nick Morgan has a great github where he teaches some first principles of Forth. The page is particularly impressive because there is a Forth interpreter built in to the web page: You can execute Forth code right on the web page. Very impressive. The page includes a nice little Snake game example. I was particularly struck by the clarity of the code. It took about 10 minutes to convert the code to run in TurboForth, which I think is testament to the clarity of the code - it's very easy to understand. Posted for comments, and hopefully will inspire others to give Forth a try on the TI. There are three great Forth systems available for yout TI: TurboForth, fbForth, and CAMEL99. This particular version is written for TurboForth, but could easily be changed to run on the other systems.
I took the code and made a couple of changes. I added a score feature, and a play again feature.
Enjoy. Here's the code:
\ Attribution: Originally written by Nick Morgan.
\ source: https://skilldrick.github.io/easyforth/#snake
\ Adapted for TurboForth: Mark Wills, 4 Feb 2022.
variable snake-x-head
100 cells allot
variable snake-y-head
100 cells allot
variable apple-x
variable apple-y
variable score
variable delay
0 constant left
1 constant up
2 constant right
3 constant down
24 constant height
variable direction
variable length
variable last-key
: snake-x ( offset -- address ) cells snake-x-head + ;
: snake-y ( offset -- address ) cells snake-y-head + ;
: draw-white ( x y -- ) xmax * +  bl swap v! ;
: draw-black ( x y -- ) xmax * +  ascii # swap v! ;
: draw-O     ( x y -- ) xmax * +  ascii o swap v! ;
: draw-walls ( -- )
      0 0 ascii # xmax hchar
     23 0 ascii # xmax hchar
      0 0 ascii #   23 vchar
  0 xmax 1- ascii # 23 vchar ;
: init-snake
  4 length !
  length @ 1 + 0 do
    12 i - i snake-x !
    12 i snake-y !
  loop
  right direction ! ;
: show-score ( -- )
  score @ n>s dup xmax swap -  0 gotoxy type ;
: set-apple-pos ( x y -- ) apple-y ! apple-x ! ;
: init-apple ( -- ) 4 4 set-apple-pos ;
: initialize
  page draw-walls init-snake init-apple
  0 score ! show-score  1500 delay ! ;
: move-up   -1 snake-y-head +! ;
: move-left -1 snake-x-head +! ;
: move-down  1 snake-y-head +! ;
: move-right 1 snake-x-head +! ;
: move-snake-head  ( -- )
  direction @
  left over  = if move-left  else
  up over    = if move-up    else
  right over = if move-right else
  down over  = if move-down
  then then then then drop ;
: move-snake-tail ( -- )
  0 length @ do
    i snake-x @ i 1+ snake-x !
    i snake-y @ i 1+ snake-y !
  -1 +loop ;
: is-horizontal ( -- )
  direction @ dup  left = swap  right = or ;
: is-vertical ( -- )
  direction @ dup up = swap  down = or ;
: turn-up    ( -- ) is-horizontal if up    direction ! then ;
: turn-left  ( -- ) is-vertical   if left  direction ! then ;
: turn-down  ( -- ) is-horizontal if down  direction ! then ;
: turn-right ( -- ) is-vertical   if right direction ! then ;
: change-dir ( key -- )
  ascii s over = if turn-left else
  ascii e over = if turn-up else
  ascii d over = if turn-right else
  ascii x over = if turn-down
: check-input ( -- ) key? 32 or change-dir ;
: random-position ( -- n ) xmax 2- rnd ;
: move-apple ( -- )
  apple-x @ apple-y @ draw-white
  random-position 1+ ( x)  random-position 22 mod 1+ ( y)
  set-apple-pos ;
: grow-snake ( -- ) length @ 1+ 100 min length ! ;
: check-apple ( -- )
  snake-x-head @ apple-x @ =
  snake-y-head @ apple-y @ =
  and if move-apple grow-snake 1 score +! show-score
    delay @ 20 - 100 max delay !  then ;
: check-collision ( -- flag )
  snake-x-head @  snake-y-head @  xmax * + v@  ascii # = ;
: draw-snake ( -- )
  length @ 0 do
    i snake-x @ i snake-y @ draw-black loop
  length @ snake-x @  length @ snake-y @  draw-white ;
: draw-apple ( -- )
  apple-x @ apple-y @ draw-O ;
: wait ( n -- ) delay @ 0 do loop ;
: centered ( c-addr u y )
  >r xmax 1 >> over 1 >> - r> gotoxy type ;
: game-over ( -- flag )
  s" OOPS! That's gotta hurt!" 11 centered
  s" Game over! Play again? (Y/N)" 12 centered
  key 32 or ascii n = ;
: game-loop ( -- )
  begin
    draw-snake draw-apple check-input move-snake-tail
    move-snake-head check-apple wait check-collision
  until ;
: start ( -- ) begin initialize game-loop game-over until cr ;
That's it. That's all it takes to make a simple game. Enjoy!
Edited by Willsy
code tweaks (thanks Lee Stewart)
  • Like 10
Not sure why game-over does not throw a “stack underflow” error:
key  ascii n =  over ascii N =  or ;       <<---should cause stack underflow
key  dup  ascii n = swap ascii N =  or ;   <<---will do what you intend
Here are some minimal changes I would make [it is always easier to pick apart someone else’s code than one’s own :grin:]:
  32 or                                \ <<---force key to lower case
  key  32 or                          \ <<---force key to lower case
  ascii n = ;                         \ <<---just check for 'n'
...lee
  • Like 4
Kept getting that stack underflow on my attempts at coding Forth yesterday, and tracked each word down by "\" commenting the definition one by one while reloading until I found the culprit. It's pretty easy to find unknown areas that throw errors.
But then you have to fix the error.  Lol
In my obsessive way I took this game and used it to learn how to make my system work better.
I never wrote games so it gave me a good skeleton and poked holes in my system.
It is also politically incorrect since my snake likes to eat mice not apples. ;)  oops!
Anyway here is the source code after 6 interations and blowing up my underlying code. :)
I must confess that it does get a bit addictive trying to go at "Viper" speed.
It doesn't have a remembered scoring system so it's still not a finished product.
I attached an executable program for the E/A cartridge option 5.
Spoiler
\ snake  a simple game in Forth ported to CAMEL99 Forth
\ DERIVED FROM: https://skilldrick.github.io/easyforth/#snake
\ revised to use CAMEL99/TI-99 features
CR .(   \\\\\\ Version 6 \\\\\\\\ )
\   \\  snake sounds and mouse squeak  \\\\\
INCLUDE DSK1.RANDOM
INCLUDE DSK1.GRAFIX
INCLUDE DSK1.CASE
INCLUDE DSK1.ARRAYS
INCLUDE DSK1.UDOTR
INCLUDE DSK1.MARKER
CR .( compiling Snake...)
\ We use direct control of the sound chip
\ rather than sound lists and a player.
HEX
\ noise control words
: NOISE   ( n -- ) E0 OR SND! ; \ n selects the noise type
\ noise envelope control
: NOISE-DB   ( db --) F MIN F0 OR SND! ;
: NOISE-OFF  ( -- )   F NOISE-DB ;
DECIMAL
: NOISE-UP ( speed  -- )
          2 15 DO  I NOISE-DB  DUP MS  -1 +LOOP DROP ;
: NOISE-DOWN ( speed -- )
         15  2 DO  I NOISE-DB  DUP MS    LOOP DROP NOISE-OFF ;
\ channel 1 sound control words
DECIMAL
: f(clk) ( -- d) 46324 1  ;   \ this is 111,860 as 32 bit int.
\ >FCODE re-arranges freq. value nibbles (4bits) for the TMS9919
HEX
: >FCODE   ( 0abc -- 0cab)    \ ASM would make this much faster
          DUP 0F AND SWAP      ( -- 000c 0abc)
          4 RSHIFT             ( -- 000c 00ab)
          SWAP ><  ( SWPB)     ( -- 00ab 0c00)
: HZ>CODE  ( freq -- fcode )  f(clk) ROT UM/MOD NIP >FCODE 8000 OR  ;
\ *TRICKY STUFF*
\ Calculating the 9919 freq. code takes too long BUT we can convert frequency
\ to 9919 chip code at compile time then compile as 16 bit literal number
\ using this text MACRO
: [HZ] ( freq -- fcode ) S" HZ>CODE ] LITERAL" EVALUATE ;
\ sound channel #1 control words
: FREQ!    ( fcode -- ) SPLIT SND! SND! ;
: ]HZ      ( freq -- ) [HZ] POSTPONE FREQ! ;      \ pre-compiled fcode version
: HZ       ( freq -- )  HZ>CODE SPLIT SND! SND! ; \ runtime calculation version
: DB       ( n -- )    90 OR SND! ;
: MUTE     ( -- )      9F SND! ;
DECIMAL
500 CONSTANT MAXLENGTH
\ x/y coordinate storage for the snake
MAXLENGTH 2+ ARRAY ]SNAKE-X
MAXLENGTH 2+ ARRAY ]SNAKE-Y
: SNAKE-X-HEAD  ( -- addr)  [ 0 ]SNAKE-X ] LITERAL ;
: SNAKE-Y-HEAD  ( -- addr)  [ 0 ]SNAKE-Y ] LITERAL ;
VARIABLE SPEED
VARIABLE PREY-X
VARIABLE PREY-Y
VARIABLE DIRECTION
VARIABLE LENGTH
\ characters used
DECIMAL
136 CONSTANT SHEAD  \ use different color set
42  CONSTANT SNAKE
128 CONSTANT PREY
30  CONSTANT BRICK
BL  CONSTANT WHITE
\ Direction #s
0 CONSTANT LEFT
1 CONSTANT UP
2 CONSTANT RIGHT
3 CONSTANT DOWN
HEX
CREATE HEADLEFT  0C16 , 37FF , FF37 , 160C ,
CREATE HEADUP    1818 , 3C7E , 99FF , 7E3C ,
CREATE HEADRIGHT 3068 , ECFF , FFEC , 6830 ,
CREATE HEADDOWN  3C7E , FF99 , 7E3C , 1818 ,
\ array of head patterns
CREATE HEADS ( n -- addr ) HEADLEFT , HEADUP , HEADRIGHT , HEADDOWN ,
\ set head pattern n to snake's head
: ]HEADPATTERN ( n -- addr) CELLS HEADS + @  SHEAD CHARDEF ;
: FACE  ( direction# -- ) DUP ]HEADPATTERN   DIRECTION ! ;
\ shape data for PREY, brick, mouse and snake chars
HEX
CREATE CLAY   007E , 6A56 , 6A56 , 7E00 ,
CREATE VIPER  3C5E , EBF7 , EBDD , 7E3C ,
CREATE MOUSE  0004 , 3E7B , 7FFC , 8270 ,
CREATE MOUSE2 0008 , 3F7B , 7EFC , 8270 ,  \ mouse looking up
CREATE JUMPMS 84BE , FB7F , 3C42 , 0000 ,
DECIMAL
\ get random x or y position within playable area
: RANDOM-X ( -- n ) C/L@  2-  RND 1+ ;
: RANDOM-Y ( -- n ) L/SCR 2-  RND 1+ ;
\ text macros make drawing faster.
: DRAW-WHITE ( x y -- ) S" >VPOS  BL   SWAP VC! " EVALUATE ; IMMEDIATE
: DRAW-SNAKE ( X Y -- ) S" >VPOS SNAKE SWAP VC! " EVALUATE ; IMMEDIATE
: DRAW-HEAD  ( x y -- ) S" >VPOS SHEAD SWAP VC! " EVALUATE ; IMMEDIATE
: DRAW-PREY ( -- ) PREY  PREY-X @ PREY-Y @ >VPOS VC!  ;
: DRAW-WALLS
     0  0 BRICK 31 HCHAR
     0  1 BRICK 22 VCHAR
    31  0 BRICK 24 VCHAR
     0 23 BRICK 31 HCHAR ;
: DRAW-SNAKE
    SNAKE-X-HEAD @  SNAKE-Y-HEAD @ DRAW-HEAD
    LENGTH @ 1
    DO
       I ]SNAKE-X @   I ]SNAKE-Y @ DRAW-SNAKE
    LOOP
    LENGTH @ DUP ]SNAKE-X @  SWAP ]SNAKE-Y @  DRAW-WHITE ;
: INITIALIZE-SNAKE
     6 DUP LENGTH !
     1+ 0
     DO
        12 I - I ]SNAKE-X !
        12 I     ]SNAKE-Y !
     LOOP
     RIGHT FACE  ;
: PLACE-PREY ( y x -- ) PREY-X ! PREY-Y ! ;
: MOVE-SNAKE-HEAD ( n -- )
    DIRECTION @
    CASE
      LEFT  OF  -1 SNAKE-X-HEAD +!  ENDOF
      UP    OF  -1 SNAKE-Y-HEAD +!  ENDOF
      RIGHT OF   1 SNAKE-X-HEAD +!  ENDOF
      DOWN  OF   1 SNAKE-Y-HEAD +!  ENDOF
    ENDCASE ;
\ move each segment of the snake forward by one
DECIMAL
\ : MOVE-SNAKE-TAIL
\    0 LENGTH @
\    DO
\       I ]SNAKE-X DUP @ SWAP CELL+ !
\       I ]SNAKE-Y DUP @ SWAP CELL+ !
\    -1 +LOOP ;
: MOVE-SNAKE-TAIL
\      src addr    dest addr      size
    SNAKE-X-HEAD  DUP CELL+  LENGTH @ CELLS  CMOVE>
    SNAKE-Y-HEAD  DUP CELL+  LENGTH @ CELLS  CMOVE>
: MOVE-SNAKE  (  -- )
             MOUSE2 PREY CHARDEF
             4 NOISE  8 NOISE-DB   \ soft white noise
             MOVE-SNAKE-TAIL
             10 NOISE-DB            \ ramp down noise
             MOVE-SNAKE-HEAD
             12 NOISE-DB            \ ramp down noise
             MOUSE PREY CHARDEF
             NOISE-OFF ;
DECIMAL
: HORIZONTAL? ( -- ?) DIRECTION @ DUP  LEFT = SWAP RIGHT = OR ;
: VERTICAL?   ( -- ?) DIRECTION @ DUP    UP = SWAP  DOWN = OR ;
: TURN-UP        HORIZONTAL? IF UP    FACE  THEN ;
: TURN-LEFT      VERTICAL?   IF LEFT  FACE  THEN ;
: TURN-DOWN      HORIZONTAL? IF DOWN  FACE  THEN ;
: TURN-RIGHT     VERTICAL?   IF RIGHT FACE  THEN ;
( EXIT THEN gets out of the case statement faster than ENDOF)
: CHANGE-DIRECTION ( key -- )
     CASE
       [CHAR] S OF TURN-LEFT  EXIT THEN \ ENDOF
       [CHAR] E OF TURN-UP    EXIT THEN \ ENDOF
       [CHAR] D OF TURN-RIGHT EXIT THEN \ ENDOF
       [CHAR] X OF TURN-DOWN  EXIT THEN \ ENDOF
    ENDCASE
DECIMAL
: SWOOSH   ( -- )
           NOISE-OFF
           5 NOISE
           8 NOISE-UP
           20 NOISE-DOWN ;
: NEW-PREY
    SWOOSH
    PREY-X @ PREY-Y @ DRAW-WHITE
    RANDOM-Y RANDOM-X PLACE-PREY
    DRAW-PREY ;
: GROW-SNAKE  ( -- ) 1 LENGTH +! ;
: DEAD-SNAKE  ( -- )
             NOISE-OFF
             SNAKE SET#  DUP 11 1 COLOR  250 MS   2 1 COLOR
             SHEAD SET#  2 1 COLOR  ;
: HAPPY-SNAKE ( -- )
             [ SNAKE SET# ] LITERAL
             17 3
             DO
                DUP I 1 COLOR
                I 100 * HZ 0 DB
                40 MS
            LOOP
            MUTE
            ( -- 5)  13 1 COLOR ;
DECIMAL
: DECAY       ( n -- ) 16 0 DO  I DB  DUP MS LOOP DROP ;
: SQUEAK      ( -- )
              NOISE-OFF
             [ 3800 ]HZ 0 DB  45 MS  \ pre-computed freq. is faster
               6 DB  25 MS
             [ 3500 ]HZ 75 MS
               8 DB 25 MS
             [ 1300 ]HZ
               11 DB 25 MS
             [ 800 ]HZ
              MUTE ;
DECIMAL
: SCARED-PREY ( -- )
             JUMPMS PREY CHARDEF
             SQUEAK
            [ PREY SET# ] LITERAL  DUP  9 1 COLOR
             2 1 COLOR
             MOUSE PREY CHARDEF ;
: FASTER    ( -- ) SPEED @ 5 -  1 MAX SPEED ! ;
: CHECK-PREY  ( -- )
    SNAKE-X-HEAD @ PREY-X @ =
    SNAKE-Y-HEAD @ PREY-Y @ =  AND
    IF
       SCARED-PREY
       HAPPY-SNAKE
       GROW-SNAKE
       FASTER
       NEW-PREY
    THEN ;
: COLLISION? ( -- ? )
    SNAKE-X-HEAD @ SNAKE-Y-HEAD @ >VPOS VC@
    DUP  BRICK =
    SWAP SNAKE = OR  ;
\ utility words for menus
: WAIT-KEY   BEGIN KEY? UNTIL ;
: AT"        POSTPONE AT-XY  POSTPONE ." ;  IMMEDIATE
: INITIALIZE
    PAGE
    4 SCREEN
    MOUSE PREY  CHARDEF
    PREY SET#    2 1 COLOR
    CLAY  BRICK CHARDEF
    BRICK SET#   9 1 COLOR
    VIPER SNAKE CHARDEF
    SNAKE SET#  13 1 COLOR
    SHEAD SET#  7 1 COLOR
    DRAW-WALLS
    INITIALIZE-SNAKE
HEX
: PLAY ( -- )
      BEGIN
         SPEED @ MS
         DRAW-SNAKE
         DRAW-PREY
         83C8 OFF   \ set continuous key reading
         KEY?  CHANGE-DIRECTION
         MOVE-SNAKE
         CHECK-PREY
         COLLISION?
      UNTIL
      0C SCREEN
      HONK
      0B 5 AT" GAME OVER"
      HONK
      DEAD-SNAKE ;
DECIMAL
: ENDGAME
  5 14 AT" You sure? (Y/N)"
  KEY [CHAR] Y =
  IF    PAGE ABORT
  ELSE  5 14 >VPOS 26 BL VFILL
  THEN
: SETLEVEL     ( n --) SPEED ! ;
: BREAK;    POSTPONE EXIT POSTPONE THEN ; IMMEDIATE
DECIMAL
: MENU
     PAGE
     5 5 AT" Select Start Level"
     5 8 AT" 1 - SNAIL"
     5 9 AT" 2 - WORM"
    5 10 AT" 3 - SNAKE
    5 11 AT" 4 - VIPER"
    5 12 AT" 5 - Quit
    3 23 AT" (It goes faster as you win)"
    BEGIN
      5 13 AT-XY
      KEY
      CASE
          [CHAR] 1 OF 150 SETLEVEL BREAK;
          [CHAR] 2 OF 110 SETLEVEL BREAK;
          [CHAR] 3 OF  75 SETLEVEL BREAK;
          [CHAR] 4 OF  50 SETLEVEL BREAK;
          [CHAR] 5 OF  ENDGAME     ENDOF
                        HONK
      ENDCASE
    AGAIN ;
DECIMAL
: TITLE  ( -- )
      GRAPHICS
      5  5 AT" THE SNAKE"
      5  7 AT" Use the E,S,D,X keys"
      5  8 AT" to move the snake
      5  9 AT" and catch the mouse."
      5 12 AT" The more he eats,
      5 13 AT" the faster he goes!"
      5 20 AT" Press any key to begin..."
      WAIT-KEY ;
: RUN ( -- )
     TITLE
     BEGIN
        MENU
        INITIALIZE
        PLAY
        500 MS KEY? DROP ( wait for key release)
        2 13 AT" Your snake was " LENGTH @ . ." Ft. long"
        2 15 AT" Press ENTER to play again"
        KEY 13 <>
     UNTIL
     NOISE-OFF
     8 20 AT" SSSSSee you later!"
     1500 MS
     GRAPHICS ;
: COLD   WARM  RUN  BYE ;
LOCK
INCLUDE DSK1.SAVESYS
' COLD SAVESYS DSK3.SNAKE6
SNAKE6.zip
  • Thanks 3
